Likes Likes:  26
Results 1 to 13 of 13
Thread: Stealth LED Lights
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Default Stealth LED Lights
    Lights by DK Custom Products, Installation by Jerry AKA Gold Rush
Size:  126.4 KBName:  IMG_0714.JPG
Size:  135.8 KBName:  IMG_0716resized.jpg
Size:  119.3 KBName:  IMG_0718resized.jpg
    Nice ... Do you feel like you see better?
    May 2011
    San Angelo
    When night riding, she can't help but see some better. We adjusted them a bit lower than driving light level since they will be on full time. The real object is to be seen and believe me those suckers sure fill that bill!! Man are they bright. Mounted down low and toward the engine guard outside presents a MUCH larger image to oncoming drivers. Sort of like comparing a VW to a Buick Roadmaster....
    2015 GL1800/Roadsmith HTS1800
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Quote Originally Posted by Gold Rush View Post
    Hi Jerry,
    How did you run the wire? (Drill the crash bar and snake it) And what did you connect into?
    Pat
    May 2011
    San Angelo
    Quote Originally Posted by nucseal View Post
    Hi Jerry,
    Pat
    Yes on the drill and snake routine.
    We took the engine guard off so I could drill into both mounting plate faces way low then did a hole up higher right under the two light mounts. Ran wires inside tubing then spliced on to the light pigtails. Heat shrink on the joints and pulled the wires back into the engine guards. We removed the head light and hooked directly onto the low beam power feed and ground wires. LEDs draw such little current the OEM wires don't even know they are there. Especially since the headlight is also LED.
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Great Job!
    Nuc
    May 2011
    San Angelo
    Thanks for the kind word guys!!! That is why Lola rode all the way up here to my place. Well that and she needed some saddle time in preparation for a long ride in a few weeks.... It takes some creative thinking sometimes but keeping wires out of sight and out of danger usually is worth the extra effort.
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    That really is nice.
    Well, what can I say....leave it to Jerry to make an application unique, functional, and good-looking!
    Carla
    Sep 2014
    Box Elder, SD
    The stealth lights made a difference for me. I was more concerned with day time lights than night. My led headlight and passing lights would wash out with the bright sunlight in the desert. The 2 steaths added on the guard rail added that nice pattern that was different, eye catching. Jim
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by LadyonaMission View Post
    Just saw this. Glad you're liking them. Super clean install Jerry!
    www.DKCustom.com
    Nice job on the install
    Very professional job
    Guess we dont have to worry like the fear folks said about the low voltage lights reeking havoc with can bus wiring
    Thank you Jerry 4 a clean install
    Me thinks you made a lady rider VERY happy
    May 2011
    San Angelo
    Update on install..
    Lola called the other day to tell me she noticed the pass/drive lights went out when switching to High Beam head light. HUMMMM .. We just knew we had looked to see if the low beam stayed on along with the high beam. Only thing we can think of was that this is managed internally in the LED head lamp cluster - not requiring actual 12 volt input on both wires.
    Anyway, She rode back to San Angelo this morning and I successfully installed a power routing circuit I'd designed. I'll attach a copy for anyone that might want their LED Stealth lights on full time.. Everything still is contained inside the head lamp bucket so the installation stays neat and out of harms way.
    Name:  Pass - Drive wire diagram.jpg
  1. ***DK Custom Products Stealth LED Driving - Passing Lights***
    By DK Custom Products in forum DK Custom Products
    Last Post: 08-21-2023, 09:26 AM
  2. ***Stealth LED Run-Brake-Turn Lights- True Plug-n-Play Sportster***
    Last Post: 07-01-2019, 11:49 AM
  3. DK Custom Stealth LED Driving Lights
    By hardwickbv in forum Harley Tri Glide
    Last Post: 08-03-2017, 03:54 PM
  4. ***DK Custom Products Universal Fitment - Stealth LED Run-Brake-Turn Lights***
    Last Post: 06-27-2017, 11:43 AM
  5. DK stealth lights install help
    By uppercaseJC in forum Harley Tri Glide
    Last Post: 04-18-2016, 09:15 AM
