14TG114TGHarley Tri GlideInstallation of a new Fuel Filter &...
BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  6
Page 2 of 2 FirstFirst 1 2
Results 21 to 25 of 25
Thread: Is this normal overheating ???
  1. #21
    JustWings.com
    Tech Contributor
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    All GL1800 fans push air forward. The fans on the 2001-05 will cycle on/off from 0-14mph. On the 2006+ they cycle on/off from 0-20mph. The fans on the 2006+ blow considerably stronger, and at times will be variable speed.
    Please keep in mind that anytime I share or give advice about a motorcycle, unless I state otherwise, I am always referring to GL1800's and no other.
  2. #22
    JustWings.com
    Tech Contributor
    May 2016
    Quote Originally Posted by Tricycleman View Post
    So depending on the mounting collar on the fan one might be able to flip the fan blades over to reverse air flow.
    Why would you want to do that ???
  3. #23
    100+ Posts
    Jun 2017
    Moville, IOWA
    Quote Originally Posted by GoldWingrGreg View Post
    I wouldn't want to mess with the engineering aspects that Honda has incorporated it's just one of the gentlemen remarks in this tread talked about the stagnant air that it was creating. On my 08 I know once I get into 2nd or 3rd gear the fans will shut off haven't paid much attention to what speed I'm traveling. At a lower speed like first gear they will cycle in and out and I figured this was related to a sensor in the water jacket somewhere that would sense the heat and once the air was cooled in the radiators and made it into the engine this turned the fans off until that portion of cool water heated up.
    06 are variable speed???? I assume that speed is determined by temperature of the coolant??
    I know on the V8 trike I built I had this issue with radiator fan and found that sucking the air through the radiator was more efficient and better results than trying to push the air through.
  4. #24
    JustWings.com
    Tech Contributor
    May 2016
    The 2006-current have variable speed. Unfortunately, knowing exactly what determines fan speed is not known for sure at this level, but I would guess it has to do with temperature. The reason Honda pushes air forward with their fans is to hot air off the rider.
  5. #25
    500+ Posts
    Feb 2008
    Planet Earth, Alpha Quadrant
    Okay I got a question here reversing the flow of the fan. I assume this is done by turning the fan blades around? Electrically this is not a 3-phase motor thus unless I'm not understanding the electrical portion there's no way electrically you can switch the wires to make that motor run the opposite way correct?
    The pitch angle of the fan will not blow air backwards if the motor polarity is reersed
    Rake...
    Never had it....
    Never will...
  1. overheating
    By glaswurks in forum Harley Freewheeler / Road Glide 3
    Last Post: 06-25-2017, 11:20 PM
  2. Stallion Overheating
    By deanone98 in forum Stallion Trikes
    Last Post: 10-26-2016, 03:12 PM
  3. Next rookie question, regarding overheating
    By dartref in forum Harley Tri Glide
    Last Post: 06-10-2016, 10:59 PM
  4. Overheating Problem
    By Tigercat in forum Stallion Trikes
    Last Post: 03-18-2016, 06:13 PM
  5. overheating trike
    By rtired in forum Honda Trikes
    Last Post: 03-17-2014, 05:56 PM
