Papa Zook1Papa ZookHarley Tri Glide2024 Harley Trikes Lineup - Laidlaw...
Bonsai4rhino 2New Member Introduct...New member from Texas
Bonsai4GorillaNew Member Introduct...New member from Texas
Rawhideken1714TGHarley Tri Glide2024 Tri glide
kj5ix32trike ladyHonda TrikesMotor Trike Service Manual Finished
Bonsai4trike ladyNew Member Introduct...New member from Texas
Bonsai4BonsaiNew Member Introduct...New member from Texas
Sunman4BowdenTrikeHonda TrikesF1 Warning Light
LD-Ordie10Marc HNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13ZammyNew Member Introduct...New member from FL
DrCrazyTrain4rhino 2Harley Freewheeler /...True Dual Header
LD-Ordie10ZammyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10Uncle FesterNew Member Introduct...Newbie from the Mojave Desert
DrCrazyTrain4Ron BaxterHarley Freewheeler /...True Dual Header
Burnerboy10rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
DK Custom Products362PosseRiderHarley Tri GlideWhat did you do to Your Tri-Glide T...
Sunman8PuckoachHarley Freewheeler /...Value of 2015 Freewheeler
dthorn5rhino 2Harley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack7rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn5dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack7ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
LD-Ordie10ol' schoolNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17KoolbreezeHarley Tri Glide2024 Tri glide
LD-Ordie10trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie10SullyNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13SullyNew Member Introduct...New member from FL
LD-Ordie10Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17LD-OrdieHarley Tri Glide2024 Tri glide
ADSavarese13Jack KlarichNew Member Introduct...New member from FL
ADSavarese13woodyNew Member Introduct...New member from FL
LD-Ordie10LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13hardwickbvNew Member Introduct...New member from FL
SSpoon14hardwickbvNew Member Introduct...Hello from VA
ADSavarese13ol' schoolNew Member Introduct...New member from FL
gfaltersack7TFNCHarley Tri GlideDK Customs remote oil filter kit in...
ADSavarese13GorillaNew Member Introduct...New member from FL
ADSavarese13Marc HNew Member Introduct...New member from FL
ADSavarese13ADSavareseNew Member Introduct...New member from FL
ADSavarese13Phu CatNew Member Introduct...New member from FL
ADSavarese13trike ladyNew Member Introduct...New member from FL
ADSavarese13Uncle FesterNew Member Introduct...New member from FL
dthorn5nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
kj5ix32ADSavareseHonda TrikesMotor Trike Service Manual Finished
ADSavarese13rhino 2New Member Introduct...New member from FL
gfaltersack7Phu CatHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
gfaltersack7DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
DrCrazyTrain4powerhaulicHarley Freewheeler /...True Dual Header
DrCrazyTrain4DrCrazyTrainHarley Freewheeler /...True Dual Header
Likes Likes:  5
Results 1 to 8 of 8
Thread: Vw Roth Trike shifter linkage question
    20+ Posts
    Dec 2016
    Canyon Country
    Default Vw Roth Trike shifter linkage question
    I'm rebuilding am old Roth Trike. It came with no shifter linkage at all. I realize the linkage must be modified as it sticks out the side (off center) from the original beetle location. Does anyone know the usual answer?
    Thanks.
    Meme Master
    Jan 2014
    Farmington, NH USA
    Not knowing how yours is currently set up, there are commercially available universal type shifter boxes that can be mounted in off center positions to accommodate almost any mounting position. A stock VW shifter is typically used in these mounting boxes, although aftermarket shifters can also be used or made to work.
    It will be easier to operate through the gears if you keep the shifter linkage rod aligned as closely as possible to the input shaft on the transaxle.
    If possible Dave, post up a pic of what you're working with & maybe we can give you more accurate info on what you're looking to do...
    Apr 2015
    Batesville, AR. 72501
    Quote Originally Posted by DaveO98 View Post
    Thanks.
    Is the main frame tube round or square?
    Is there a plate that looks like the shifter mounting surface on a VW tunnel welded vertically to the tube behind the body shifter hole?
    As far as I know, the original Roth trike used a stock VW shift lever assembly mounted at 90 degrees. The offset from center left and vertical was handled by a shifter tube fabricated from the stock VW shift rod ends and a couple of universal joints from a socket set.
    Pictures of the frame and shifter area would help.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    If you have nothing....
    Get a buggy super shifter and the swivel joint link rod. Mount it where you need it to be.
    Apr 2015
    Here's some pictures of the Stires Stinger Trike. It was the closest "Roth Clone" that I'm aware of.
    Here's the frame:
    Here's the shifter:
    These pictures are from a 1973 Stires Catalog. Hope this helps.
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    I use a EMPI side shiftier setup
    Thank you
    Bob
    20+ Posts
    Dec 2016
    Canyon Country
    Thanks guys.
    All input is helping.
    Today I'm meeting with a guy named Dave Shuten. He's restored a number of Roth pieces for the Galpin museum in San Fernando Valley.
    He's going to show me how they did the shifters on those.
    I'll post pics later today.
    20+ Posts
    Dec 2016
    Canyon Country
    [QUOTE=vwbug72501;500290]Is the main frame tube round or square?
    Pictures of the frame and shifter.
    Dave Shuten. (One of the head restoration guys at Galpin Auto Sports) let me take a good look at a couple of Roths personal trikes they have on display there. And another one they are restoring. Pretty crazy setups. But I did come to realize that i may had been overthiinking it a bit. My friend at Prowlers (buggy and sandrail builder here in Santa Clarita, Ca) modified a stock bug shifter box to be supported on the front and the rear with heavy duty bearings. That, combined with two u-joints (kind of like you suggested) should work fine. I hooked it up and tested it (static). And it seems to work fine.
    Thanks guys.
  1. Ed Roth trike on ebay
    By Rsw in forum VW Powered Trikes
    Last Post: 02-18-2018, 04:38 PM
  2. Gear Shifter question
    By Trike in forum VW Powered Trikes
    Last Post: 02-13-2012, 11:35 AM
  3. Big Daddy Roth Trike
    By stray catalyst in forum Other Brands Trikes
    Last Post: 08-04-2008, 03:16 AM
