Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  10
Results 1 to 20 of 24
Thread: Throw out bearing
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    Default Throw out bearing
    Busted the tab on my throw out bearing
    will order a new clutch kit today to include new springs
    Thank you
    Bob
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Ouch.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Well, that sucks, Bob!!!
    Did you have to drive it home without a clutch? Always a treat.
    Sep 2014
    Moneta VA
    Quote Originally Posted by stinger608 View Post
    I was about 100 miles away and could not get it into gear. So I had it towed home. Cost a lot of $$$
    Now I have coverage on the trike so if something like that happens again AAA will tow it home.
    The new clutch arrived today. I have it on the engine and the throw out bearing on the Trany.
    Now have to wait for my son to help me lift the engine in place tomorrow.
    Thank you
    Bob
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Quote Originally Posted by Fowler View Post
    I usually put the tranny in first gear with the engine off and start it in first. Then just compression shift the rest of the time.
    Sep 2014
    Moneta VA
    There must be a trick to do this. I tried it several times with no luck. People have told me in he past it can be done but I can not get it to work
    Got the new clutch and bearing installed and the engine back on the trany
    Took it for a ride today
    Need to do some other maintenance while I have the back seat off.
    Everything should be back together tomorrow
    The Ol'Lady and I have a trip planned for Sunday.
    I am cleaning things up while I have it apart.
    I don't have any leaks that I know of (not loosing oil from the engine or trany or have oil on the shop floor) but the under side of the engine, trany and frame were very dirty. Not oily dirty, thick, black greasy stuff, had to scrape a few areas clean before wiping and painting
    Thank you
    Bob
    Sep 2014
    Moneta VA
    My Trike has been back together and was running good since my last post.
    Now I have a howling noise every time I push in the clutch. It just started the other day.
    It does not howl when the clutch is ingaged
    It sounds like when I have had a wheel bearing go out on other cars
    I think it is the new throw out bearing.
    I will have to pull the engine and look at it soon
    Thank you
    Bob
    Bob's Curmudgeon Apprentice
    consitter's Avatar
    Jun 2015
    Ashland, KY
    That sucks.
    Best of luck in finding the problem and correcting it.
    your on the right trail I believe also throwout bearing.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Yep.
    It is hard to find a good one anymore.
    I picked one that was supposed to be the good one.
    But it looks like any other cheapo...
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Yep.
    Yep, I think most all are either China built or Brazilian built. Both are usually garbage.
    Sep 2014
    Moneta VA
    I ordered one but it is a little different then the last one I put in
    It has a rounded mating surface like this one
    The last one had a flat surface like this
    Can I use this or do I need to order a different bearing?????
    Thank you
    Bob
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    The flat one used to be considered the good one.
    The stamped round face was considered the cheepo.
    The last one I got was advertised as a good hd one for the high pressure clutches. It came in as a round face. Used it anyway. Seems to be ok.
    Sep 2014
    Moneta VA
    I will give it a try
    Thank you
    Bob
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    I'm sure you know there are two different style bearings for the vub. Depends on pressure plate style and or whether your trans has the snout for the bearing to ride on.
    Sep 2014
    Moneta VA
    Yep knew that.
    I have a standard clutch
    This is the type of bearing that is in there now
    I ordered the same but got one in that has a rounded surface
    Thank you
    Bob
    400+ Posts
    Feb 2015
    Sussex nj usa
    Well that picture is the style that goes to the pressure plate with what looks like a big washer on it. The rounded ones I always thought went directly on the clutch fingers. And that style needs the snout to keep it centered. Of course I've been wrong before.
    Sep 2014
    Moneta VA
    my pressure plate does have the "big washer" on it
    I made my old clutch (from a previous replacement) into a table but you can still see what it was
    I do not want to do the work another time after this.
    I will just order 1 that I know is correct.
    Anyone have any suggestions on a quality one to order
    Thank you
    Bob
  19. #19
    400+ Posts
    Feb 2015
    Sussex nj usa
    Ok just wanted to be sure you knew. Can't help with parts, there are no quality parts far as I know. I had a brand new chinese bearing make noise immediately, took it out cut it apart. Wow no grease at all nothin and thats probably 20 years ago. You would think they would've gotten better over the years but apparently not.
  20. #20
    Sep 2014
    Moneta VA
    Can I upgrade the cross shaft to this http://vwparts.aircooled.net/HD-Cros...-p/5035-12.htm
    then use this type of T/O Bearing http://vwparts.aircooled.net/HD-Thro...3-141-165b.htm
    would that work and would it be better?
    Thank you
    Bob
  1. Downtube bearing
    By Ed Hobgood in forum Stallion Trikes
    Last Post: 01-09-2017, 08:05 PM
  2. Throw Back to DK Custom Snow Trike Ride
    By jc1300 in forum Harley Tri Glide
    Last Post: 12-04-2015, 02:13 AM
  3. You may be a red neck if your throw rug throws you
    By Rev Ray in forum Thoughts & Prayers Sanctionary
    Last Post: 06-07-2015, 03:00 PM
  4. Ill throw my hat in
    By J.D. Squire in forum Home Built Trikes
    Last Post: 05-04-2010, 06:31 PM
