ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Likes Likes:  8
Results 1 to 11 of 11
Thread: C-Cab Design Question
    Aug 2017
    Johnsonville, NY USA
    Default C-Cab Design Question
    I have always like the C-Cab design. There are some concerns like the "parachute" effect going down the highway but some folks have solved that by placing a large window in the back to get good airflow.
    There are several fiberglass C-Cabs on the market but hey seem to be designed for cars not trikes. I was thinking of making one from scratch, and thought of using wood.
    I have seen several wood bodied trikes but wondered about the issue of the body being so close to an air cooled engine (the heat).
    Does anyone have experience with using a wood body? Are there steps you can take to maybe coat the lower part of the body closest to the engine to make it flame resistant?
    Thanks for any help
    Paul
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Default reply
    I have no experience with wooden bodys....but you can get foil backed insulation for underhood/firewall/floorpan etc. I would consider good ducting and airflow to the engine, when driving. so as to minimize heat soak when stopped. the exhaust pipes would need the most attention, so select exhaust with your body work in mind.......always liked the looks of a C-cab, and a roof overhead with a sunvisor would be nice. I keep thinking about a vinyl top of some kind for my trike....you got me thinkin again lol................welcome to trike talk......you came to the right place! Larry
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    A few a years ago I met a guy at a local hardware store.
    He had a C-Cab VW trike.
    We talked a bit.
    He said the C design did catch the wind a lot. He said he was going to remove the glass windows to see if that helped.
    He also had a idea of taking the hard top off and making it a rag top/convertible with back window
    I would think that would make the parachute affect even worse but who knows
    Never seen the guy after that so I do not know how it turned out
    Thank you
    Bob
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default C-Cab Trike
    Name:  Steampunk C-Cab.jpg
Size:  26.1 KBName:  ScottRods.com.png
Size:  372.1 KBCut to size? ScottRods.com
    JakeJacobsen@Pinterest.com
    Sep 2014
    Moneta VA
    Quote Originally Posted by TomyJ View Post
    That is assume!!
    I could adapt something like that to my trike build
    I will have to look into it when I get to that point
    Thank you
    Bob
    Jun 2016
    milnor n.d. usa
    that c-cab would be super cool.....have thought of using fiberglass legend stock car bodies also.
    I have a 37 Dodge sedan body, bad condition, but have considered cutting the 2 little back windows and part of the roof to make a top for my trike. the hump back trunk could cover the engine.
    just another random thought, probably won't happen.
    Sep 2014
    Moneta VA
    Thank you
    Bob
    May 2016
    Hemet, Ca. USA
    Default C-Cab
    Name:  c cab motorcycleth23FRXEF2.jpg
Size:  7.8 KBI like the shape of this one...
    Sep 2014
    Moneta VA
    found this pic here on TT
    Thank you
    Bob
    Jun 2016
    milnor n.d. usa
    must have a steering box with linkage on other side? or ?
    Sep 2014
    Moneta VA
    Thank you
    Bob
  1. Fork design
    By Fowler in forum General Discussion
    Last Post: 05-28-2017, 12:51 PM
  2. Looking for Design Ideas
    By Shadow Dreamer in forum Trike Builds
    Last Post: 05-24-2017, 08:39 PM
  3. New TG Compensator design
    By Bikerbozo in forum Harley Tri Glide
    Last Post: 09-20-2013, 07:15 PM
