Results 1 to 13 of 13
Thread: SBC Hardtail a slow build
    5+ Posts sleepyonthree's Avatar
    Oct 2010
    G-ville , Fl
    Default SBC Hardtail a slow build
    A few pics of where I started and the point currently at.
    Donor axle from 77 chev wagon, cleaning up the lumps n bumps, axle cut down and kinda sorta fixtured for welding. Welded cleaned up and primer-ed with acid etch primer and the frame attach plates. Getting started on the frame, the double U-joint is the cut down drive shaft.
    All this over a too much else to do packed year.
    1250+ Posts katfish16's Avatar
    Feb 2008
    Gallion, Alabama
    Default Re: SBC Hardtail a slow build
    Looks like U have it well in hand... thanks for the pictures keep us posted on the build.
    By the way welcome to the board........
    Steve & Cathy
    Alabama
    U.S. Coast Guard (retired)
    100+ Posts BIBS's Avatar
    Oct 2010
    vineland NJ USA
    GOOD GOIN!!!!! I admire anyone that does his own bildin and fabricatin....cant wait to see the end result!!
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Welcome to the forum.Looking good so far just keep it up.Pics are great keep them coming
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Welcome SOT. This is gonna be interesting. Thanks for posting.
    Zook
    100+ Posts
    Feb 2010
    Pekin, IN. U.S.A.
    looking good, i built a small block chev trike a couple years ago, fun build & a fun ride, will be watching for pics of it coming to life, CAVEMAN
    50+ Posts Terry Trikedude's Avatar
    Oct 2010
    Anderson, SC, USA
    I agree with zook... do you have a drawing of the finished look of your trike that you can post?
    7250+ Posts Nana's Avatar
    Apr 2008
    Ohio
    Thanks for the pictures! This is going to be fun to follow along with.
    Trike Talk Membership Map
    No matter the storm, when you are with God, there is always a rainbow waiting.
    http://i440.photobucket.com/albums/q...andana-1-1.jpg
    Oct 2010
    G-ville , Fl
    Thanks for the good words guys, lookin forward to the future completion myself
    Trikedude, What I've got in my minds eye as a guide is the The Barbarian V8. never have put things down on paper when buildin.
    Barbarian V8 Motorcycles
    Sep 2010
    tayler bay wa
    Did you cut/weld the axle's yourself? I would like to see your welding fixture for the axle's.
    Good job on the housing.
    Fred
    Oct 2010
    G-ville , Fl
    Hey Fred
    Kinda homebrew approach. Picked up a six foot 1 inch threaded rod with nuts and washers at the local screw and fastener place. A neighbor with a wood lathe turned up a set of maple hardwood inserts with a 1 inch hole centered to replace the bearing races. 3/4 inch ply for the outside crush plate as seen in the pic. The same neighbor is a plumber and let me use a pipe cutter
    to score cut marks at the decided upon spots which were a visual guide for the hacksaw work. This was followed up with judicious use of a hand file and machinist square to true up the facing surfaces. 4 1/2 inch hand held grinder to bevel the joints leaving right about 1/8 in mating surface. Plugged it all together using the threaded rod and (only one showing in pics) two vice grips
    on each side to keep them registered inline to tighten the rod down way tight.
    Used a big ass propane blow torch to warm the housing up to about 500 f then (one side at a time) tacked the front and back of the joint, hit it with the blow torch again for a moment pulled the other vise grip and tacked the top and bottom. Hit it with the blow torch again then proceed with a two pass weld front/back then top/bottom in sequence. Snugged the nuts down some then did the other side. Left it all snugged up until it had cooled
    Once cool the welds were ground flush, a 2 inch long chunk (per side) of cold rolled tubing was split in half, centered and clamped over the weld. Warmed everything up one side at a time and welded the tubing as extra insurance.
    Sep 2010
    tayler bay wa
    Thanks for the housing pictures however my question is about cutting the axle shafts.Did you cut/weld them?
    Thanks Fred
    Oct 2010
    G-ville , Fl
    Oh! Well in that case. Gonna send them out and have them cut/resplined. Haven't Decided where yet but here's some places I've come up with.
    Service Charges
    Moser Engineering - Moser Engineering - Home
    Dmmsports.com Development Site
    Rearend Installation Service - Currie Enterprises
  1. V8 hardtail?
    By VaBob in forum Home Built Trikes
    Last Post: 05-01-2014, 05:00 PM
  2. This site is slow
    By Lakeman in forum General Discussion
    Last Post: 09-22-2013, 07:37 PM
  3. Slow Down - May thru Aug
    By 87Trike1200 in forum General Discussion
    Last Post: 08-16-2013, 02:21 PM
  4. Slow build!
    By Windblown in forum Home Built Trikes
    Last Post: 01-27-2011, 10:19 PM
