Likes Likes:  5
Results 1 to 17 of 17
Thread: Passenger grab handle digs into wife's leg
    30+ Posts TAC's Avatar
    May 2016
    Old Town, Maine USA
    Default Passenger grab handle digs into wife's leg
    We have a 2017 Tri Glide with HD passenger armrests. The stock grab handle on the right side digs into her leg and makes long rides very uncomfortable.
    The right side passenger floorboard is in it's top position so I can't gain anything there. Strangely enough it is an inch lower than the left side which is also in it's highest setting.
    I'm reluctant to try to bend them either on or off the bike. Don't really want to ruin them.
    Anyone else have this issue and found a fix? (aside from removing them)
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    HD sells the brackets to raise the floor boards up, my wife is 5ft6in and her legs would have marks on them after we rode a little while. I replaced the brackets and all is good. I do have a 2014 but I don't know if there is a difference.
    2019 Goldwing CSC
    150+ Posts lah2420's Avatar
    Oct 2013
    Texarkana, AR
    I put on some Kuryakyn adjustable passenger pegs. My wife loves them. Not sure if they fit the 17s though.
    2015 Tri Glide Vivid Black. Customization work in progress to make it mine-when not riding it.
    200+ Posts
    Nov 2015
    palm bay
    Quote Originally Posted by TAC View Post
    A good riding buddy, now dead, had that problem. He solved it by replacing his "buxom" bride with a new skinny girl friend. YMMV
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Why not remove them, instead of spending $$ on diff pegs.?? If I remember right, just 2 bolts under seat & they are off. Don't think I have ever used then for anything.
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Mitchell, Indiana, USA
    I installed the Kuryakyn adjustable passenger pegs that I got from DK Custom on my 2017.
    They helped a lot. DK Custom is a great company to work with.
    I also installed Passenger Grab Handles PN 1609 from Kuryakyn, these are have a flatter handle than the stock plus rubber for a better grip.
    My wife liked these better when we rode the dragon. Only problem we've had so far is the rubber turned her hands black if she doesn't wear gloves and it will also come off on the back of her pants if they are not a darker color. Kuryakyn said that sweat would attack the rubber and to clean them occasionally with a Windex type cleaner. We still have to try that out Other than that they are great.
    Bob
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    That was the first thing to go on both my 16 and the 17,threw them in the attic and reinstalled it on the 16 when i traded it on the 17.
    May 2016
    Old Town, Maine USA
    Default Hope I solved it.
    Thanks for the replies. I hope I have it solved with the 724-238 raised floorboard mounts from J&P Cycles I ordered yesterday. They raise the floorboards 2 1/2 inches so if I use the lower holes, it should be just right.
    She has the HD armrests but uses the hand grips on twisty roads so I didn't want to just remove them.
    Thanks again..
    100+ Posts Rev J's Avatar
    May 2016
    NC
    Removed mine, one problem solved. However now wife says she doesn't feel as secure with nothing to hold on to. Probably add arm rests later and hope to solve that problem.
  11. #10
    400+ Posts
    Feb 2008
    RADCLIFF, KY
    The stock ones are raised on the sides, I found a set that's flat and this doesn't bother the wife at all....not sure of brand, I think HD but could be wrong. I'm out of town and can't take a picture.
    2017 Tri Glide, Bonnieville Blue / Fathom Blue
    2005 Bushtec Roadstar Trailer
    BLUE KNIGHTS, KY II
    AMA, HOG, Iron Butt Member
  12. #11
    May 2016
    Old Town, Maine USA
    I thought about that too but my wife has to reach for the floorboards a bit, especially the right one that's an inch lower than the left with both of them in the top mounting holes.
    By the way, the HD floorboard risers will not work (according to them) on the trike.
    The Kuryakyn grips with the rubber looked like an option but the HD armrests already hit the HD rails and I was afraid they wouldn't come in far enough for my wife.
    She's a little thing. 5' 3" & 115 lbs. I think the risers from J&B will work fine.
    They also sell an adapter block which gives you several mounting positions for height & also lets you angle the floorboards for comfort. I thought about them & decided against them as they set the floorboards out a bit and I didn't want my bride to have to reach out further for them.
    I'll report on the results after installation.
  13. #12
    550+ Posts
    520fd's Avatar
    Aug 2010
    Davenport, Iowa USA
    Well, I bought my trike out in the Black Hills during Sturgis. Those passenger hand rails were the first thing that came off when we got home. My wife is also long legged. So I adjusted the passenger floor boards down to the last hole. Wife very happy. Me good. Looks like I get to live another day.
  14. #13
    May 2016
    Old Town, Maine USA
    Thanks again..
    Replaced the RH bracket only last night. Used the lowest set of holes and there is no longer any contact with her leg on the grab handle. Easy to change after you find that ball bearing that shot out when you pull the pins out of the floorboard. Problem solved..
  15. #14
    850+ Posts jc1300's Avatar
    Apr 2015
    Clarksville, TN, USA Via North of Chicago
    I'm curious if anyone has turned them around - Never looked at it closely. but as the hand rails seem to angle uphill {into the back of the leg}. If you could just turn them 180 they would then slop down in the front.....anyone....Ferris......
  16. #15
    Sep 2017
    Villa Rica, ga usa
    Default Grab handles
    Quote Originally Posted by jc1300 View Post
    I just removed them on my 17 TriGlide problem solved
  17. DKCustoms postbit
  18. #16
    If it were me, I'd take them off and tell her to hang on to me ... I kind of miss the co rider thing ... ... I really enjoyed her groping me ... used to call her my little pervert. Maybe that's why she left me .
  19. #17
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    2014 - My wife holds on to them when riding. She is 5' 4" and my grab rails have the H-D grip covers on them. No problems at all. I need them to move the trike around.
    Bob
    Name:  grab rail grips.jpg
  1. Passenger Assist Handle
    By ttanthony in forum Harley Trike Conversions
    Last Post: 11-20-2014, 07:02 PM
  2. Passenger Grab Handles
    By aussie in forum Lehman Trike
    Last Post: 09-05-2013, 11:07 PM
  3. Passenger Grab Rails
    By Smoken'JOE in forum Honda Trikes
    Last Post: 06-29-2010, 02:48 PM
