LD-Ordie3SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie3Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie3LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Results 1 to 5 of 5
Thread: Audio Problem
    Jul 2017
    POTTSVILLE
    Default Audio Problem
    I need help from you electronic gurus. On my 94 1500 the passenger headset lost the right side input. I've tried known good headsets, tested the headset junction wire, and even swapped out the audio system with my 92. The external speakers all work properly. I realize I have a wire problem but don't know what wires to check or how to test them. Thanks in advance for any help.
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Sorry ... I don't work on anything other then GL1800s. However, if it were an 1800, I'd tell you that in almost all cases, headset audio problems are almost always due to either the 2 cords going to the helmet (the one connected to the bike, and the one connected to the helmet), or the audio stuff within the helmet itself. Occasionally there is an exception to that, but it is rare.
    FYI ... on a GL1800, the external and internal systems have separate amps. But there is no such thing as left or right.
    Hopefully something there helps.
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    +1 What Gregg sez. Almost always Helmet equip. or two cords connecting it to the bike.
    Jul 2017
    POTTSVILLE
    I realize most audio problems are caused by headset or cable issues, but as I said I've tried known good headsets and cables.
    JustWings.com
    May 2016
    Quote Originally Posted by Benchman View Post
    I've never had to call them myself, but have heard Sierra Electronics is very helpful over the phone. Apparently they also repair our radios. Please let us know what you find so we can all learn too.
    https://www.sierra-mc.com
  1. Spedometer Problem & Emergency Brake Problem
    By JohnT1949 in forum Harley Freewheeler / Road Glide 3
    Last Post: 08-20-2016, 12:29 PM
  2. audio
    By Dragon in forum Stallion Trikes
    Last Post: 02-01-2015, 10:42 AM
  3. audio speakers?
    By sonny8l3 in forum VW Powered Trikes
    Last Post: 11-23-2014, 04:35 PM
  4. 2004 Wing Audio Advance Problem
    By FRR in forum Honda Trikes
    Last Post: 06-10-2013, 05:46 PM
