Get Into DTC Viewing Mode:
  1. Make sure the ignition and Boom Box have been off for at least 15 seconds
  2. Press & hold the power/mute button on the Boom Box
  3. While holding the power/mute button in, turn ignition to accessory position
  4. Keep holding the power/mute button down
    1. Wait until the Boom Box boots up
    2. Wait for the Boom Box main warning screen to appear
      1. Hold and additional 2 seconds
      2. Press the “accept” button to enter the Boom Box back-end
Viewing and clearing DTC's: (Clear codes at your own risk)(Make sure you know what you are doing or consult a Harley mechanic)
  1. Select the “DTC” button on the Boom Box screen to enter DTC mode
  2. If not DTC codes it will immediately say “No logged DTCs” and you are done
    1. If there are DTC's it will list them
    2. Select each one using the touch screen or your right joy stick/toggle on your right control cluster to cycle through the process
  3. To exit the DTC and back-end of the Boom Box system just turn the ignition to the off position
