Champion brake pads
Feb 3, 2009
61
SW Iowa
Anyone know what brake pads the Champion uses on solid axle? Have a 2006 kit with toyota axle. Pads have lot of life left, but can't stand the noise when comming to stop they make. thanks bigred
its impossible to find champion pads locally,, D101p,,
no parts jobber could cross this part no.
try 'Varga 113615105 per champion'
while we are on this subject of rear brakes; does anyone know of a BETTER BRAKE PAD for the Rear wheels of a Triglide HD ?? I know my rear brakes aren't the best when just using them alone. any suggestions??? and does replacing the brake fluid with Synthetic fluid help?
Trying to find out what Brake pads are used on the Independent Rear Suspension kits that are used on my 2011 Harley Ultra with the Lehman Trinity LLS kit thanks
The Trinity (looks like a tri-glide) is IRS rear suspension with champion undercarriage. If the calipers look like VW calipers, it is 99% Champion. Not knowing the year that the Kit was manufactured (2012, 2013 or later) it is hard to identify the brake system Lehman used prior to Champion without pictures. Could be a couple different types. Does it have a parking brake ?
During my Champion kit body-off able bearing replacement and repacking spider gears, Iooked for any markings, found part#, searched it and put me at Jbugs site. Had calipers and pads. Brake lines.
2011Case
2011Case
