hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn4dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn4Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
SSpoon14hardwickbvNew Member Introduct...Hello from VA
dthorn4nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn4TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
Likes Likes:  6
Results 1 to 11 of 11
Thread: Using a car tire on the front
    30+ Posts
    Jul 2013
    Rosamond Ca.
    Default Using a car tire on the front
    Has any one used a car tire on the front like a 175-55-16 tire. We don't need a curved tire on the front any longer were using car tires on the rear. A little wider front tire may help it handle better. What do think about it??
    Jun 2010
    Indianapolis, In.
    There will be others jump in on this, I'm sure.
    1. There is a difference on the sealing area of a car tire to a motorcycle wheel. Many do it on a rear anyway
    . However, I would be real leery of this w/the side forces put on a front trike tire in a hard turn!
    2. There is still a need for some roundness when a trike front tire is turned. Because of rake, it does lean some.
    3. There is now a trike specific tire marketed by Avon. Why take a chance on an unknown?
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    700+ Posts jjvw's Avatar
    Dec 2013
    Jenison, MI
    https://www.tirerack.com/tires/tires...755WR6AD07LTS2
    This tire is for a Lotus Elan, a hard cornering sports car and needs a 5-6" rim. Looks like it's waiting for a guina pig. If you bring in a wheel they can tell you if it will seal properly, although they may not be allowed to do it lawfully.
    Keep us posted if you try it.
    200+ Posts RTwing's Avatar
    Mar 2014
    Minnesota
    Car tires are standard equipment on mine, front and rear
    Attachment 52892Attachment 52893Attachment 52894
    950+ Posts JaysGone's Avatar
    Nov 2012
    Delray Beach Florida
    Wont fit on most Yamaha front rims. My Roadstar is "doudble dark" 195-65-16 on the rear and rear motorcycle tire on the front.
    A car tire with its flat foot print even if it did fit on a 3.5 inch front rim would probably be to flat footed and handle rather poorly.
    You could make some fender risers rather easily if you want to try it.
    But a 175 anything should be on at least a 5 inch wide rim.
    Just my opinion in 35 years of darksiding. Not based in known fact.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Quote Originally Posted by glenn m View Post
    What do I think ? Why do it ? Not bragging, but I love hard aggressive turns. The front will skip on uneven surfaces. Never brake IN A TURN . Steering friction from a car tire will not be likeable. It’s not a car, it’s still a bike !
    13000+ Posts FuzzyWuzHe's Avatar
    +1
    Mar 2011
    mountain home,ar. USA
    Eurowing uses a car tire on the front. Check with them and find out what size rim, etc.
    40+ Posts slug's Avatar
    May 2008
    Fayetteville, Ga.
    The front rim is 14" on a eurowing. The rim will not fit between a stock Goldwing set of forks. Something else to consider on the front tire is sidewall height if you plan on trying to use a car tire on the front. If its too tall it will rub the front fender.
    1+ Posts Skinel's Avatar
    Sep 2018
    Wilmington
    My research has found no car tire that could mount on our RSV 3.5" rim.
    I'm not going to modify my wheel/rim - too expensive.
    So for anyone who cares, my next front tire for my trike will be -
    Avon Venom p/n 90000000778 AM42 160/80B16
    Load rating = 80
    Speed rating = H
    Tread Depth 11/32
    ...just a little wider (.4") & a little taller (1.1")
    My current Avon Venom AM42 150/80B 16 has over 15000 miles on it now.
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    As of this time there is no car tire that will fit on a Yamaha front rim.Your best bet for the front is to use a rear motorcycle tire. If you you want to spend about $3000 you can get a whole new front end with and earl's fork (leading link) and a car rim that will allow you to use a car tire but that's the only way I know.
    these people will build you one for whatever bike you want.
    http://hedinghamsidecars.co.uk/leading-link-forks.html
    Happy TRAils/NSD
    Paul
    Quote Originally Posted by Skinel View Post
    Load rating = 80
    Speed rating = H
    Tread Depth 11/32
    Hey, Nicolas welcome to Trike -Talk.......
  1. Avon AV-71 Front Trike Tire - anyone using this tire???
    By dadztoy in forum Outrigger Style Trikes
    Last Post: 02-16-2024, 04:24 PM
  2. Front tire???
    By Firea100 in forum General Discussion
    Last Post: 12-07-2015, 07:36 PM
  3. tire size for rear tire on front? 2007 goldwing trike
  4. Car Tire on the front?
    By Strat in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-24-2011, 09:06 AM
  5. Front Tire
    By subeetrikerdon in forum Tires, Wheels, Brakes, Front End
    Last Post: 05-16-2010, 11:22 PM
