Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
Thread: Ticking noise in engine or transmission
  1. #21
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Quote Originally Posted by Tricycleman View Post
    Okay mentioning loose baffle is that not part of the end piece that can be removed on the muffler? If that's the case then I believe I'll just remove the two end pieces and check the baffes For looseness. I've never heard of this being an issue.
    On a GL1800, I've not heard of a loose baffle either. But since it has been mentioned, it's always a possibility and would only take a second to eliminate as a possibility. However, baffles are inside each muffler and not are not inside the exhaust tips. The fastest way to eliminate such noise it the method I mentioned in post #6.
    Also, since this is a trike forum, it's possible that the trike no longer has OEM mufflers.
  2. #22
    100+ Posts
    Jun 2017
    Moville, IOWA
    Thanks for the clarification on the location of the baffles guess I could have pulled that up on my service CD disc for an exploded view wihich would have the told me that. As far as the Mufflers being OEM they are as I did this trike conversion myself and reuse the existing stock mufflers. As you mentioned in Post Number 6 I will keep that in mind if this ticking noise comes back to do that procedure to see if that eliminates the noise.
  3. #23
    350+ Posts
    Jul 2016
    N Ky USA
    While I strongly suspect some additives are nothing more than a “witches brew” collection of chemicals that claims to clean a build up of deposits that has formed in our engine by just riding. However with all the choices on the shelves it’s unfair to say not one of these products work as advertised or could be beneficial to us without causing harm. I myself have noted on here am a fan of Techron and after listening to 2 different auto call-in shows (different cities) where the so call auto experts said the only additive they would be OK recommending would be Techron. One that gets mentioned often on forums is seafoam. My personal experience....... I bought a can. It smelled very strong of isopropyl alcohol. I checked the data sheet and sure enough it did contain isopropyl alcohol. I think it was 10-20%. At that time alcohol related problems were a common place and I didn’t want to compound my problem as alcohol attracts water, and isn’t alcohol corrosive? I still have that can of seafoam unless it has evaporated.
  1. Engine noise....lifter???
    By JIMSFLH in forum Harley Trike Conversions
    Last Post: 11-05-2015, 07:08 PM
  2. 2010 tri glide 103 ticking noise sounding like a lifter
    By waynerid1 in forum Harley Trike Conversions
    Last Post: 06-07-2015, 12:49 AM
  3. Hearing a ticking noise
    By mikestrike in forum Harley Trike Conversions
    Last Post: 12-19-2013, 05:46 AM
  4. Transmission Noise?
    By johnnie1 in forum Honda Trikes
    Last Post: 10-17-2013, 05:45 PM
  5. Noise from engine or transmission.
    By RobertW in forum Honda Trikes
    Last Post: 10-05-2012, 08:24 PM
