Likes Likes:  4
Results 1 to 13 of 13
Thread: U-Joint Grease Fitting(s) Location
    10+ Posts Ruothere's Avatar
    May 2017
    Westford, MA
    Default U-Joint Grease Fitting(s) Location
    Ok I give up, looked at the sorry excuse for an owners manual and did several searches on this forum, no luck. I've got a 2017 Motor Trike Razor kit on my 2010 GL1800 and I'm trying to identify where my u-joint grease fitting(s) are. I believe I have one where the drive shift enters the engine. Getting to it looks difficult unless there is some trick that doesn't require a lift. Is there a second grease fitting back at the rear end?
    Have about 5K on the conversion looking to make sure the install filled the joints and lubed where necessary.
    Thanks all, sure wish there was a Fred Harmon GL1800 set of "How-To" DVD's available for us newbies and do-it-your-selfers"
    Sep 2012
    Lakeland, FL
    Last I heard ya had to drop the drive shaft, maybe that has been improved and updated. Perhaps some expert will get into the conversation.
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    If there is a zerk at the front u-joint, some are able to get a grease gun on theirs by looking through the rear brake m/c. If you remove the 2 bolts for the m/c, it will allow for a little more access. Depending on the shaft, there can be another 2 on the shaft. One at the rear u-joint, and one in the middle of the shaft. To check, lift the RR tire so that the shaft can be turned by hand while looking for zerks. As bikerbillone indicated, sometimes the shaft has to be removed to get to any of them.
    May 2011
    San Angelo
    Quote Originally Posted by Ruothere View Post
    Kevin your '10 with the Razor conversion has one fitting on one of the end caps of the front U-Joint. It will point straight out the side so if you remove the side cover (the one you remove to check the oil) and look for a green U-Joint coupler assembly near the rear brake master cylinder. Roll the trike until the fitting rotates around and you should be able to grease it... There is also one fitting on the rear U-Joint that you'll have to raise the rear end a bit to get underneath. Some owners jack the rear end up and put it on blocks. Others use jack stands. In either case rotate the drive shaft until you see the fitting. Just a couple squirts of grease is all you need. Don't blow the seals....
    Here is a simple ramp arrangement I built and use regularly if I need to get under my trike.
    Name:  All Ramps.jpg
    2015 GL1800/Roadsmith HTS1800
    1500+ Posts Dockem's Avatar
    Jul 2011
    Cville, IN / Leesburg, FL
    Geez Jerry, that garage looks way too clean! I could only find 2, maybe 3, leaves that got in the door!
    The human race has only one really effective weapon, and that is laughter. - Mark Twain
    People who drink light 'beer' don't like the taste of beer; they just like to pee alot. - Capital Brewery, Middleton, WI
    TOI #01585 VRCC #506 Iron Butt #10256 NRA Life Member
    May 2017
    Westford, MA
    Thanks Jerry, that's the info I was looking for.
    May 2011
    San Angelo
    Quote Originally Posted by Dockem View Post
    I wish it was always that clean Jim. That photo was taken several years ago. A lot has changed. I now have a lift table planted in that space and shelves along one side. Still room for me and the trike but add one person and it gets crowded!!
    150+ Posts jredman's Avatar
    Jan 2014
    Leander, Texas, USA
    Hi Ruothere, I have a 2014 Motor Trike Razor and I grease mine every oil change at 4000 miles. I have a video of one my oil change and I grease the shaft, shows where they are. If you're interested it is here.
    Jim's Motor Trike (YouTube)
    http://www.youtube.com/c/JimMotorTrikeRazor
    Sep 2016
    Springfield, Mass. USA
    Thank you, oil changes to engine were no problems BUT I did learn where those greese zirks were located...Thank you!
    May 2017
    Westford, MA
    Quote Originally Posted by jredman View Post
    Thanks Jim, that's what I was looking for. Next question, to raise up the rear end where is the correct location to position the jack, just in front of the cross members (X)?
    Thanks.
    Jan 2014
    Leander, Texas, USA
    Thanks.
    I jack mine on the Trike frame in the rear.
    Sep 2016
    Thank you for this video, I too also change my oil ~n~ filter on a 3,000 rotation . and grease my drive shaft, (under bike) BUT I did not know about the fitting inside, behind the oil fill cover, (thanks for that "new" knowledge) looks like I gotta shoot some grease in that area also, today...
    I have a Roadsmith model (not a Motor Trike) but I'm assume'n the grease jirk, is located in the same area (???)
    6/25/23
    JustWings.com
    May 2016
    6/25/23
    I believe RS drive shafts have no zerk for the front ujoint.
  1. Which U-joint grease?
    By Mick in forum Honda Trikes
    Last Post: 12-25-2023, 08:24 AM
  2. Drive Shaft U-Joint grease
    By Red Wing One in forum Honda Trikes
    Last Post: 08-03-2022, 06:48 AM
  3. Pre-fitting these $60 wheelie bars...
    By CaveManDave in forum VW Powered Trikes
    Last Post: 06-09-2016, 01:47 AM
  4. I found a grease fitting On my 2014 Trike
    By Side by side in forum Harley Tri Glide
    Last Post: 03-15-2015, 01:20 AM
  5. Universal Grease Fitting
    By Yogisan in forum General Discussion
    Last Post: 07-20-2011, 07:42 AM
