Likes Likes:  1
Results 1 to 14 of 14
Thread: Trike pulling right
    200+ Posts
    May 2013
    Mackinaw Il usa
    Default Trike pulling right
    My 1800 trike is pulling to the right even if I get in the other lane. Any ideas? It is a Lehman kit.
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Default Pulling to the right
    Howard,
    Is this something that just started ???
    What changes have you made recently ?
    First, check rear tires for same type, size and equal air pressure.
    Make sure you have between 20-22 psi in each.
    Second, check the coil-over shocks and make sure they have the same pre-load.
    Third, check rear axle bearings.
    Fourth, check front wheel bearings.
    Fifth
    , rear brakes dragging ???
    Lastly, does the trike sit level on level ground or does it lean ?
    Measure the distance between wheel well opening and the ground. Should be within 1/4" of each other.
    A cracked swingarm may be causing this as well.
    Inspect all welded connections.
    Jim Murphy
    Iron Butt Rider 2001
    200+ Posts
    May 2013
    Mackinaw Il usa
    Jim, it has always pulled since I bought it in 2008 but seems to be worse. It is the Monarch not the ll so it doesn't have the coil-over shocks. I checked the rear tires and they have the same air and there is 1/4 " difference. I then measured the mirrors and the right is 1 1/2 lower than the left. What would cause this.
    JustWings.com
    Tech Contributor
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    That's a pretty severe pull ... also, if it has the same rear tires since you've owned it, have you tried rotating the tires left to right and re-test drive.
    Please keep in mind that anytime I share or give advice about a motorcycle, unless I state otherwise, I am always referring to GL1800's and no other.
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Sounds like something is wrong. Had the trike ever been wrecked ?
    I agree with GREG check it out !
    Is your front tire wearing on one side, more than the other ?
    If you stand in front of the bike with the front wheel pointed directly straight ahead on level ground, is the front tire and wheel perpendicular to the ground ? It is not leaning is it ?
    If it is a Monarch it has 2 coil-over shocks outboard. Need to remove the wheels to see them.
    Jim Murphy
  6. #6
    200+ Posts
    May 2013
    Mackinaw Il usa
    The front tire looks like it is straight and is wearing even but the whole trike is leaning to the right. It is a 2003 and to my knowledge it hasn't been wrecked. When I put it on the center stand and measure the mirrors they are the same.
  7. #7
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Quote Originally Posted by howardg View Post
    Inspect the swingarm for cracks and rear shock(s) preload settings.
    Putting it onto the center stand, doesn't really tell you much. Park the trike on LEVEL ground, remove the seat and put a level across the top of the frame. This will tell you if the rear axle and frame are parallel. While you have it there, measure the rear fender openings to the ground on both sides.
    DO THIS OFF THE CENTER STAND.
    Jim Murphy
  8. #8
    200+ Posts
    May 2013
    Mackinaw Il usa
    Thanks Jim, I have measured from the ground too the fender and there is a difference of about 1/4" I will take the seat off tomorrow and check it.
  9. #9
    200+ Posts
    May 2013
    Mackinaw Il usa
    Jim, I took the seat off this morning and put a level across the frame and it is off a full bubble meaning the trike is leaning to the right. Do you have any tips on what to check. Just look from the top under the seat I can't see any adjustments or coilover springs. Thanks
  10. #10
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Howard did you see Jim's post where he said you have to remove the wheels to see the shock that can be adjusted?
  11. #11
    200+ Posts
    May 2013
    Mackinaw Il usa
    Thanks ,Yes I did, but I can look down on the shock with the seat off. I haven't had a chance to take the tire off yet but I really don't know what I am looking for. Does anyone have a pic.
  12. #12
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Name:  Monarch I rear shock.jpg
    Jim Murphy
  13. #13
    200+ Posts
    May 2013
    Mackinaw Il usa
    Jim can you explain what I am looking for, I did measure at the wheel wells and there is 3/4 difference, thanks
  14. #14
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    jim can you explain what i am looking for, i did measure at the wheel wells and there is 3/4 difference, thanks
    call me at the shop 304-262-6200
    Jim Murphy
  1. pulling to right
    By Vegas99 in forum Honda Trikes
    Last Post: 07-11-2013, 10:52 AM
  2. new trike pulling to right
    By slick rick in forum Home Built Trikes
    Last Post: 11-08-2012, 06:14 PM
  3. pulling to the right
    By jcolson in forum General Discussion
    Last Post: 07-31-2012, 08:30 PM
  4. Trike pulling trailer Class is available
    By Boscoporp in forum Honda Trikes
    Last Post: 04-06-2011, 09:17 AM
