ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Speed Bleeders
Likes Likes:  8
Results 1 to 11 of 11
Thread: Harley Trike Muffler Swap
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Default Harley Trike Muffler Swap
    I think I have found an easier way of changing the mufflers on Harley Trikes, once you get the old ones off
    I put 5/ 16th studs in the rear holes of the mufflers
    I found this easier to align them and easier to turn a wrench on than a bolt
    The front bolt is not bad to start
    With the stud in you can massage a flat washer a lock washer and start the nut with your finger tips, then tighten it up
    I hope this helps
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Good tip Jack
    900+ Posts
    Apr 2011
    Bellville, Texas, USA
    Sounds like a good idea. I am going to try it next time. Getting the rear bolt started and tightened is a pain in the rear (no pun intended).
    Sunman
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    I tried flipping the rubbers and mount brackets also, this makes starting the rear bolt easier, however it puts more strain on the mufflers IMO the height changes albeit just a bit, but that is all it takes to put a bind on the exhaust and cause a ringing harmonic
    The stud IMO is easier 4 me, it may not be 4 everyone
    I looked at this from a lifetime of turning wrenches
    I have just about every 1/2 wrench u can imagine
    That rear bolt aint 2 bad if U have a distributor wrench
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Wow, Distributor wrench haven't used mine since the 70's...
    2019 Tri-Glide.......
  6. #6
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Never sell a classic
  7. #7
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    I will have to dig mine out. another great idea
  8. #8
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Good tip,speaking of old tools i happened to see the other day my flexible allen wrench for setting the points on a chevy dist.
  9. #9
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Quote Originally Posted by Mykneesbehurtin View Post
    I just used mine the other day to align the headlight on my trike. Been setting in the drawer for years
  10. #10
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    I never sell any tool even if i only used it one time, Because if you live long enough you will find a use for it again, And if you don't live long enough to use it again...Well.....
    Itdontmatteranymoreanyway!....
  11. #11
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Gorilla View Post
    Mine is older than me, A hand me down from my dad
  1. What are you running for muffler's on your HD Trike ?
    By Rollin Thunder in forum Harley Tri Glide
    Last Post: 01-15-2018, 02:36 AM
  2. Motor Trike (2011 FLHTCU) header pipe swap
    By dllowery in forum Motor Trike
    Last Post: 07-01-2014, 10:19 AM
  3. Help 93 trike muffler question
    By MACHINIST15 in forum Honda Trikes
    Last Post: 01-26-2013, 01:14 AM
  4. Vtx 1300 mtr trike muffler prblm
    By tipper in forum Honda Trikes
    Last Post: 07-04-2012, 10:47 PM
  5. V8 Trike Trans. swap
    By haigcomp1 in forum Home Built Trikes
    Last Post: 06-01-2012, 02:45 AM
