Sunman8PuckoachHarley Freewheeler /...Value of 2015 Freewheeler
dthorn5rhino 2Harley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack7rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn5dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack7ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14hardwickbvNew Member Introduct...Hello from VA
gfaltersack7TFNCHarley Tri GlideDK Customs remote oil filter kit in...
dthorn5nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack7Phu CatHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
gfaltersack7DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
Likes Likes:  2
Results 1 to 11 of 11
Thread: Avon Cobra AV71 identification and Trike Ride Height
    Jun 2017
    Marshville,NC,USA
    Default Avon Cobra AV71 identification and Trike Ride Height
    Hello Everybody,
    This is my first post.
    I just bought a 2004 Motor Trike Adventure with only 4K on the bike and 600 miles on the trike.
    Want to replace the front tire because it is original. Read on these pages that the Avon is the way to go. Is the trike version of this tire have something on the tire that identifies it specifically for a trike? Also on the Dennis Kirk website I see 130/70R-18 with an H, V4.00 3, and V4.00 2. Any application that is preferred? And finally the best place to buy?
    Also the trike sits low. The support system for the aqua shield rides just 4 inches off the ground. I had the Traxxion Dynamics AK-20 front end in my 2001 that I just sold and loved it. Retired now and money is more scarce and the AK-20 is $1200. What modification will raise the trike? Traxxion Dynamics springs? Progressive springs?
    Thanks for you opinions.
    Tom
    950+ Posts JaysGone's Avatar
    Nov 2012
    Delray Beach Florida
    The Avon your looking for is specifically for trikes and marked as such.
    Example:https://www.amazon.com/Avon-Tire-70R.../dp/B00T6J2H4I
    Motor Trikes of which I have an Adventurer do sit awfully low to the ground.
    Watch out for speed bumps. I try to go around most of them. Im not aware of any way to raise the trike except to increase the air pressure in the rear end.
    That makes for a more uncomfortable ride. Other then with a full tank of gas. Ive never had it over 35psi and lower it to 25 psi at half a tankful.
    My rear tires are at 22.5psi.
    Im sure you have read some of my posts on the Avon. Im probably the only one here that prefers a rear tire on the front.
    Im not liking the Avon one bit. Feels like a regular bike front tire to me. I cant wait till mine wears out. Any day isn't fast enough.
    Welcome to Trike-Talk 'Tom.......
    welcome aboard Tom
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Quote Originally Posted by Tourer View Post
    Raising the front end will probably require new springs and fork cap extension. The reason I say probably, is because it depends on what your have now. Both Progressive and Traxxion will raise a naked GL1800's front end about an inch. Most trikes have a rake kit, so an inch on a trike is usually less. Between the 2 brands, I prefer the ride quality of Traxxion over the Progressives. Fork caps extend the over all length of the forks allowing them to be pushed down about 1.5" in their mounts. However, you may already have those.
    Sep 2016
    Springfield, Mass. USA
    I have the Avon on my trike (Roadsmith) 1800 Honda, this is my first year/season of riding a trike, so I'm not coming on like an expert, BUT I took to a trike like a duck in water, LOVE it!
    I put an Avon on because my builder recommended this type of tire for a trike (and my old D-3 was wearing out anyways w/ 10,000+ miles on it) BUT I have found this tire rides wonderful, and I would not hesitate to replace it with another Avon when the time comes... I have approx. 5000 miles on my new trike'd out bike now since converting... MAN O' MAN, how I love trikes, why did I wait over 50 years to try a trike.......I just turned 41,000 miles on my bike (approx. the last 5000 miles of it was trike'd riding...
    Springfield, Massachusetts
    100+ Posts wingit's Avatar
    Jul 2015
    Richmond Mn.
    Quote Originally Posted by JaysGone View Post
    That makes for a more uncomfortable ride. Other then with a full tank of gas. Ive never had it over 35psi and lower it to 25 psi at half a tankful.My rear tires are at 22.5psi.
    I have the Michelin for traveling spare Cupped Bad with 20k compared to my Avon Trike with 20k no cupping. Mich rode like a dump truck, even though that's all I want on my Dodge diesel. I Don't see another choice to try. I won't put on a cheap brand to save $30. I like the Avon ride. I don't like any trike handling, Its a high speed lawn mower. Trikes are safer,I wont wear a helmet so Im stuck with it.
    Jun 2017
    Marshville,NC,USA
    Default Thanks
    Thanks for taking your time for the responses and thanks for the welcome posts. Going to order the tire today.Ride Safely.Tom
    After using MPA rear tire mounted in reverse for my front trike tire I switched to the Avon Trike tire and WOW what a difference. You will be happy with it.
    Apr 2010
    Shenandoah Valley of Virginia
    Hello Everybody,
    Yes ... it will say so on sidewall:
  1. Avon Cobra Trike Tire
    By rhino65 in forum Honda Trikes
    Last Post: 05-02-2017, 08:33 PM
  2. Update Avon Cobra Trike tire
    By Hocky in forum Honda Trikes
    Last Post: 12-03-2016, 11:44 AM
  3. AVON COBRA 71 TRIKE Believer !!
    By Gold Rush in forum General Discussion
    Last Post: 07-16-2016, 09:16 PM
  4. Avon Cobra Trike Tyre
    By Johnlyn in forum Harley Trike Conversions
    Last Post: 06-13-2016, 03:34 PM
  5. Avon Cobra Trike front tire #2
    By mhgoldwing in forum Honda Trikes
    Last Post: 12-04-2014, 08:02 AM
