Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  18
Page 4 of 4 FirstFirst 1 2 3 4
Results 61 to 70 of 70
Thread: 107 engine stalls ocassionally at idle
  1. #61
    70+ Posts RAHRAHJR's Avatar
    Sep 2017
    GLEN ROCK, PA
    2 things, I had my 2018 in for a simple warranty issue, and they updated the ECM flash. It now idles at 900 or 950. The other, I had this issue after I updated my intake to a stage 1. It ended up being I did not have the backing plate installed correctly to the Throttle body and it had an air leak. Once I removed the black bracket behind the backing plate and re-installed the backing plate, it ran fine.
  2. #62
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by RAHRAHJR View Post
    Do you have the Harley Tuner on your Trike?
  3. #63
    70+ Posts Ronbo's Avatar
    May 2017
    richardson tx
    Quote Originally Posted by 2UP3DWN View Post
    I bought my 2018 Tri-Glide in October 2017. Right out of the gate I found myself stalling with RPM's idling around 800 or below...
    I thought it was me and tolerated it for a short bit. Never had a problem with my clutch skills with my previous 7 bikes all Harley's.
    In January of this year I had a Stage II Torque kit installed and never looked back. I like the added power and the bike feels solid and strong. For the most part I can keep up with my 2-wheeled friends. No stalling.
    After having been through a few earlier motor upgrades on previous bikes I'm somewhat familiar will air fuel maps...
    This issue reeks of mapping issues... just my 2 cents
    Hi Matt, I was looking putting the Stage II Torque kit on my 107 17 freewheeler and when the dealer looked it up it says that the cam will not work with 17 later trikes. He was surprised and verified that all the 107's use the same stock cams. The only thing he could come up with is that they don't have an SE map for stage II trikes. What tuner do you have?
    Thanks,
    Confused in Dallas
  4. #64
    30+ Posts TAC's Avatar
    May 2016
    Old Town, Maine USA
    Just had my second clutch switch replaced about 6000 miles after the first one. Same symptoms as before. Intermittent stall when stopped, in gear with the clutch pulled. Will not start in gear, you have to find neutral.
    12000 miles on the bike. We'll see what happens at 18K
  5. #65
    100+ Posts Koolbreeze's Avatar
    Oct 2018
    Stewartstown, PA, USA
    Quote Originally Posted by TAC View Post
    I had no problem for the first 5000 miles or so but every now and then the engine will stall out during stop & go traffic or when you pull into a parking lot with the clutch pulled in & no throttle.
    It might do it once on a ride but I try to keep blipping the throttle as I come to a stop to avoid the problem or it might do it more.
    It normally idles at 800 rpm which is normal I presume..
    The bike starts and runs great other than that issue.
    Any thoughts?
    Will the bike start in gear with the clutch pulled in? There have been some issues with the safety switch not working and causing idle issues. If the bike will not start in gear with the clutch pulled in the dealer will replace the switch/unit.
  6. DKCustoms postbit
  7. #66
    May 2016
    Old Town, Maine USA
    Quote Originally Posted by Koolbreeze View Post
    No it won't. Makes it fun to find neutral with a line of cars waiting for you to move. That's how I knew right away what the problem was this time...
  8. #67
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    If you lightly apply either brake, it will start in gear with the clutch engaged.
  9. #68
    May 2016
    Old Town, Maine USA
    Quote Originally Posted by MDO View Post
    Normally it does but not when the switch fails. That's how you know it's the switch....
  10. #69
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    After a lot of riding in the rain mine did not start in gear with clutch pulled in
    I removed the clutch handle, cleaned the inside of perch area good, lubed the clevis pin with white Lithium grease and have NO problems
    I think the switch half's have gotten better, tho not great, I also think the switches will work better and longer if a little care is taken over time JMO
  11. #70
    50+ Posts
    Oct 2015
    Merritt Island
    Any thoughts?
    I fixed mine pretty easily, When I got the bike I went to the screaming eagle high flow air cleaner, so I went in there and pulled the oil breather tubes out of the air intake, I have the DK breather kit but waiting to put it in since they are coming out with a newer collection can. Either way stop the oil from going back in and problem solved. The idle never waivered the entire Biketoberfest even sitting in the main street traffic.
  1. M 8 Idle
    By Jack Klarich in forum Harley Freewheeler / Road Glide 3
    Last Post: 08-30-2017, 07:47 PM
  2. Rough Idle/engine stops
    By paid4c4 in forum Honda Trikes
    Last Post: 10-22-2016, 03:40 PM
  3. Engine Idle Temperature Management System (EITMS)
    By dfpk in forum Harley Tri Glide
    Last Post: 10-28-2013, 03:03 PM
  4. Engine Idle temp.
    By lboos in forum Harley Trike Conversions
    Last Post: 09-03-2013, 04:26 AM
  5. Rough idle.....
    By krooozn in forum Honda Trikes
    Last Post: 03-29-2011, 05:11 AM
