Likes Likes:  18
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 40 of 70
Thread: 107 engine stalls ocassionally at idle
  1. #21
    10+ Post Club
    Apr 2017
    Davenport, Fl 33937
    Default Just filed complaint
    Been reading this thread and just completed my complaint on the NHTSA website. Same issue as mentioned by others. Hopefully, HD will send out a recall.
  2. #22
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I am still not having this problem & am good with that.
    My FW will hunt around a little at idle, ranging from 830-870 rpm, but not 1 stall, so I guess I'm lucky in this regard.
  3. #23
    70+ Posts
    Oct 2014
    kearney mo.
    Default 107 stalling
    Just took my 2018 in to shop yesterday with the same problem will be worked on Monday. Hopefully they can duplicate the problem but the cold weather made it run great on the way over, only stalled once when I was at the gas station
  4. #24
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    I had mine in the shop for the same issue said they couldn't duplicate the idle issue.I asked if they rode it and they said no.I told the tech if you don't ride it it will not stall,he called me back about a half hour later and said yep you were right as soon as he rode it it stalled.The issue is the clutch safety switch,so they have to replace the complete switch pack.Have had no issues since.
  5. #25
    70+ Posts
    Oct 2014
    kearney mo.
    got a call from dealer yesterday said bike was fine idle was ok no codes. They
    rode it in mid 20s weather it never got out of cold mode. Talked to service manager said he would try in wednesday when it was in the 50s. will wait till then, tried to get him to call Harley because they are having problems with the left switch pack
  7. #26
    30+ Posts TAC's Avatar
    May 2016
    Old Town, Maine USA
    Quote Originally Posted by TAC View Post
    HD Dealer checked it out last week. Apparently, it is the clutch safety switch and they are on back order.
    Let you know after it gets changed out. Might be next season!
    So I've put about 250 miles on this Spring and the stalling issue seems to have been fixed. The clutch switch was changed out at the end of last year and I put it to bed right after. No problems at all, even yesterday where it was 90 degrees. Apparently, it is the clutch switch causing the problem. FYI
  8. #27
    30+ Posts
    Apr 2018
    Pa.USA
    Quote Originally Posted by chiefdave View Post
    Just did this, to spend money on a machine that in fact the manufacture knows there is an issue, to me is absurd. I have been around bikes as a kid and had several as an adult. I have never stalled a bike out anytime, but now thru research after the after the fact , I kind proved it yesterday with a 2014 trike. sine having this 17 m8 I have stalled it a total of 5 times 3 days after having it 4 times, once at an intersection with traffic and once two days ago. Thought it was just me, but I have tried myself, after reading research and it goes back to the dealer next Monday for an insp and the starting issue , at this point I am not very happy! and the dealer will know this! I realize the dealerships don't build these machines, but training ect and working on the same if not the same types of machines day in and out and then some dealers say they know of nothing of this is just an excuse to pass the buck. If I could I would go back to a metric, Sorry for the rant, but this just upsets me. Taking a trip later this month and at this point looks as though the 17 will stay at home and the 14 will go.
  9. #28
    Quote Originally Posted by triker Ron View Post
    The idle on the M8 is set at an ridiculously low 850... [As per EPA dictate and out of the dealers hands] And the cluch action is very abrupt, So if you don't get on the throttle fast enough it will stall... I solved my problem with an adjustable cluch lever......I reported it to the NHTSA, How many others have???...Enough complaints and they will look into it..[Recall maybe]
  10. #29
    Oct 2017
    St. Louis, MO USA
    I'm curious if most M8 owners have this issue? I must be very lucky. The only thing I modified is adding a K&N air filter & an external breather of my own design.
    Neither seem to have effected the idle, but they sure made it run better.
  11. #30
    30+ Posts
    Apr 2018
    Pa.USA
    Neither seem to have effected the idle.
    I guess your one of the lucky ones so far. What upsets me as I would like to do my add ons at times ,but with issues I will not being its still under warranty. I have the option to add to the existing warranty , thinking now warranty this one it maybe a good idea.
  12. #31
    Oct 2017
    St. Louis, MO USA
    I'm considering an extended warranty also, but have a little over a year to decide. If need be, I could remove my mods & return it to stock in 10 minutes.
  13. #32
    One of the best things you can do for your engine IMO
  14. #33
    30+ Posts
    Apr 2018
    Pa.USA
    As a follow up, I just got off the phone from the nhtsa about my complaint, do not know if any others that posted issues with their 17 trike, but I explained that to me, its a safety factor and even give them the name of this site to do some research, so as with others that had some questions on a possible future recall it may help, I had told this rep that I filed a complaint when finding that others have had issues as well and found out about finding how to submitting a complaint. I really hate to complain, but this is just out of question when the manufacture knows of this and basically does nothing about it.
  15. #34
    Good that makes at least two.....You And me...
  16. #35
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    From the touring service manual:Never install a switch from a different model( i.e.cable clutch),...features are different.And this:"A motorcycle with the wrong switchpack installed can start in gear" Oh my.Wouldnt want THAT to happen.
  17. DKCustoms postbit
  18. #36
    30+ Posts
    Apr 2018
    Pa.USA
    After our conversation, I asked if he received any other complaints, He said no he hasn't so at this point it appears as though we are the only ones, unless other reps have filed as well. I find it really inconcievable that two of us had issues with this.
  19. #37
    Quote Originally Posted by Old Road Dog View Post
    I guess they mean, It could start in gear without applying the brake... With the standard switch-pack they Will start in gear as long as the brake is applied...
    The problem arises if you stall it going though an intersection , Then you have to apply the brake to restart...Unless you can pop it into neutral fast enough..
  20. #38
    250+ Posts
    Nov 2012
    Bradenton, FL.
    My 2017 Tri has the same problem neutral safety switch. Back ordered . Bummer.
    2019 Red and Silver Tri Glide
  21. #39
    IMO, give it enough time and miles in the rain and the clutch switch will rear its ugly head
    My 15 Freewheeler went thru 2 ls switch paks, and 1 brake switch
  22. #40
    150+ Posts Colleydog's Avatar
    Feb 2018
    Kingsport, tn. Usa
    Has anyone noticed this issue with a 18 Tri glide, I have not noticed it with mine
  1. M 8 Idle
    By Jack Klarich in forum Harley Freewheeler / Road Glide 3
    Last Post: 08-30-2017, 07:47 PM
  2. Rough Idle/engine stops
    By paid4c4 in forum Honda Trikes
    Last Post: 10-22-2016, 03:40 PM
  3. Engine Idle Temperature Management System (EITMS)
    By dfpk in forum Harley Tri Glide
    Last Post: 10-28-2013, 03:03 PM
  4. Engine Idle temp.
    By lboos in forum Harley Trike Conversions
    Last Post: 09-03-2013, 04:26 AM
  5. Rough idle.....
    By krooozn in forum Honda Trikes
    Last Post: 03-29-2011, 05:11 AM
