Anyone have a flush mount axle installed? Which one and how difficult is it to install and remove?
Bill is this posted in the correct forum? You posted under Harley TRI-Glide I am nor aware of any flush mount axle for the Tri Glide. I maybe wrong.
Klock Werks and quite a few others.....but no real skills needed to trade out for a flush mount ~ And I do like the Klock Werks unit:
got it for some reason my brain was thinking rear axle.
I made one for my 12 Road Glide,they are very straight forward to install.Used my buddies Paul Yaffe axle to copy from.
Thanks all. I was wondering, how difficult is it to remove once installed?
Paul Yaffe's Bagger Nation makes one that fits Tri Glides. http://baggernation.com/item.php?iid=257
Adding to my wish list!
The reason they won’t warranty the flush axles on a trike is the side loads while turning. If you think about it the ultras don’t get much side load because you lean the bike in turns but the trikes you turn into the turn and the front wheel and axle sees a high side load. That’s why the large castle nut etc. That being said as an engineer. I might test one anyway.
I have the Yaxle, close to 1000 miles since I put it on, I don't see any problems, everything is tight.
