Results 1 to 3 of 3
Thread: Motor question
    200+ Posts
    Apr 2015
    pineville, la
    Default Motor question
    Does anyone know if a svda distributor will work with a Brosol 30/31 carb on a single port motor. I have a 1600cc dual port with a Solex 30/31 carb and it works. It pulls enough vacuum but I don't know if the single port will. I The motor has the 009 distributor in it now and it runs fair but still has the little stumble. Any suggestions.
    Apr 2015
    Batesville, AR. 72501
    Aircooled.net tech article says no. http://www.aircooled.net/vw-distributor-options/ . Don't know personally.
    Easy way to find out is swap distributors from dual port to single port and drive it. 009 and SVDA distributor stems should be the same.
    200+ Posts
    Apr 2015
    pineville, la
    Default motor question
    Yeah that's probably what I need to do. I guess I could do that and check for total advance. Thanks for the info.On my dual port the carbs pulls 10 inches of vacuum and it has a port on the intake just below the carb and I checked it and it pulled 21 inches of vacuum. I'll swap them tomorrow and see what happens. Wonder if I put a port below the carb on the single port if it would pull enough vacum.
    Quote Originally Posted by vwbug72501 View Post
  1. A question about Motor Trike shocks.
    By JaysGone in forum Honda Trikes
    Last Post: 05-19-2019, 03:33 PM
  2. Motor Trike question
    By bjelliott in forum Honda Trikes
    Last Post: 09-01-2016, 03:21 PM
  3. Question on Motor trike Exhaust
    Last Post: 11-30-2015, 07:21 PM
  4. Motor question
    By starrider1946 in forum VW Powered Trikes
    Last Post: 05-11-2015, 06:30 PM
  5. Motor Trike Kit Question
    By Rebel in forum Honda Trikes
    Last Post: 08-24-2011, 10:41 AM
