Likes Likes:  6
Results 1 to 10 of 10
Thread: M 8 Spark Plugs
    Default M 8 Spark Plugs
    NGK part number for M8 engines is
    CR9E
    Iridium # CR9EIX
    I dunno if I can justify paying the extra for Iridium
    This is an alternative to the HD plugs
    Seems these odd ball plugs fit a lot of Japanese made bikes HMMMMMMMM
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I have always liked NGK plugs, but I'm so happy with the way this new 107 runs, I may stay with the stock ones if they look good after 2 years.
    Oct 2017
    St. Louis, MO USA
    Have you pulled your plugs yet & if so, how did they look?
    Its not like the old days plugs last 30 thousand plus miles...When gas was leaded maybe 12 thousand miles...I checked the plugs on my 2011 Tri..[103] at 40 thousand they were like new, And the gaps were within specs... The M8 Should last at least that long what with two plugs per cylinder...
    Back in my drag racing days i would change them out after 4 or 5 1/4 mile runs, But they were moderfided by me. [Cut back] Should have patented the idea...
    Oct 2017
    St. Louis, MO USA
    Regarding the M8, Has anyone pulled the plugs yet & if so, how did they look?
    Oct 2017
    St. Louis, MO USA
    CR9E
    Iridium # CR9EIX
    I notice your insinuation there, but I don't see Made in Japan stamped on the M8.
    My 2005 Honda Sabre has 2 plugs per cylinder. Honda has been doing it for awhile on a lot of their bikes.
    I have looked @ my plugs
    They are burning light gray not white The M8 runs not as lean as the Twin Cams that is good for us
    I probably wont change em til 30K
    I believe NGK is a good global company
    They make many apps for their plugs
    Aug 2015
    Pella
    Default Plug gap
    CR9E
    Iridium # CR9EIX
    Jack what gap did you use for the iridium plugs. Thanks
    Oct 2017
    St. Louis, MO USA
    This is from the 2017 service manual
    Table 2-18. Spark Plug-
    All Models M8
    TORQUE
    GAP
    PLUG TYPE
    89–133 in-lbs
    (10–15 N·m)
    0.031 –0.035 in
    (0.8–0.9 mm)
    HD-6R10
    Quote Originally Posted by HDMAN View Post
    My gap was @.032 That was my 15 Freewheeler with the 103 engine
    Not changing plugs in my 17 M8 til I have a problem
    All Models M8
    TORQUE
    GAP
    PLUG TYPE
    89–133 in-lbs
    (10–15 N·m)
    0.031 –0.035 in
    (0.8–0.9 mm)
    HD-6R10
    Good post Michael
  1. Spark Plugs
    By lightnin in forum Harley Trike Conversions
    Last Post: 12-05-2016, 09:34 PM
  2. spark plugs
    By DJS in forum Honda Trikes
    Last Post: 06-03-2012, 04:26 PM
  3. spark plugs
    By geraldlanc in forum General Discussion
    Last Post: 03-24-2012, 09:03 AM
  4. Spark Plugs
    By drumdoctor in forum Home Built Trikes
    Last Post: 09-21-2011, 03:19 PM
  5. Spark plugs
    By John Luciano in forum General Discussion
    Last Post: 07-29-2010, 06:41 AM
