2015 HD Tri-Glide Master clutch cylinder and clutch plates and reverse issue
Advise please - about a year ago while riding on the freeway, 70-75 mph, my RPMs started jumping and I was loosing power. Took trike into the HD dealer for repair. They replaced the mater clutch cylinder and clutch plates.
Same problem again a couple weeks ago, but not as bad. This time replaced JUST the clutch plates, they say with Scream's Eagle clutch plates but that isn't what the invoice says, I need to check out the PN. While riding home, once in 6th the bike just didn't sound right; like it was working too hard, same in 5th. Continue home with cruise on, 70-75 mph, jump in RPMs again, twice, kicked off the cruise. Then ran fine but cruise wouldn't reset. Had to turn cruise off/on to reset. Rode immediately back to the dealer, waiting on them to look at it again.
Additional issue, maybe related....SOMETIMES when I use reverse then put in 1st, the bike does not want to go, the gear is fighting. Sometimes I can put back in reverse then 1st and it will go fine, sometimes not. This past time I had the RPM jump clutch issue, it was after the reverse/1st issue. The HD dealer can not recreate the reverse/1st issue so they can not fix.
Also, BOTH times I had the RPM jump loss of power I was in cruise mode. So so long I want to give you all the info. I have been riding trikes for 10 years, over 50k miles, so not rider error. Thanks for any info.
