Likes Likes:  13
Results 1 to 20 of 32
Thread: Starting in gear?
    30+ Posts
    Sep 2016
    Tam[a Florida
    Default Starting in gear?
    New problem showed up just yesterday. I usually park in-gear and then use Neutral for starting. But I decided to start in first since I was just going 2 blocks to the store. Pull clutch, set hand brake and it started just fine.
    Exit grocery, pack items in trunk, hop on and nuttiin. Pulled clutch several times, pushed brake couple times, zip, zilch, nada, ain’t happening. So I put in neutral and started and got home.
    This AM, first thing, started in-gear fine. After 10 min ride to Lowe’s, nothing, zip, zilch, nada. Had to use Neutral again.
    Dealersays probably the handlebar cluster on Left side.
    Good news, it starts in Neutral. Bad news, left Handlebar cluster backordered till 8 Dec for dealer.
    Jun 2010
    Coram, NY USA
    Even though my TG is older, I would recommend turning the ignition switch OFF then back ON. Never did it at dealer, but I usually can start after doing that once if at first it didn’t start.
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    I have had my left switch pack replaced because of poor idle issues.Unless I hold both brakes tight mine wont start in gear.The switch packs are a issue because everything runs thru the ECM and or the Canbus system.
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Mitchell, Indiana, USA
    Just had my Left switch pack replaced under warranty last Friday.
    It was on backorder for 6 weeks before I got it.
    Tech said that although Harley won't admit they are having a lot of trouble with that switch pack.
    It is the clutch switch that is in it that is the problem
    Bob
    Jul 2017
    usa
    Default start in gear
    My 17 TG had to have the switch replaced.
    Would not start in gear.
    Now no problem.
    have the dealer replace the switch.
    ride safe
    Geo
    80+ Posts wiltat2's Avatar
    Yuma, Az.
    Mine has had to be replaced 3 times in the year and 2 months I have had it. It definatly is an issue that HD needs to do something about.
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by wiltat2 View Post
    Yep, this problem has been going on for years. I've had at least one replaced on every bike I've had since I first experienced the problem on my 2009 Ultra. Did not have this problem before 2009.
    You would think HD could save some money by purchasing a bit higher quality components.
    www.DKCustom.com
    Yuma, Az.
    I never had this problem on my 2009 Tri-Glide or my 2010 Ultra. The 2017 Tri-Glide is the first one I have had the problem with.
    Out side of the labor.$.....They 'Harley just sends the defected part back to the Manufacture and they they the Manufacture has to eat it....
  11. #10
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    China..
  12. #11
    Harley outsmarted itself again
    In 2009 with the frame change to the baggers along came new switches
    These switches are all micro switches built in to the switch half module= non serviceable
    If 1 or circuit goes bad the whole switch needs to be relaced
    If HD had them in stock they would be admitting they have a problem IMO
    I have had 2 failures on my 15 Freewheeler
    None yet on my 17
    However I am pretty sure my clutch switch is heading South
  13. #12
    200+ Posts pioneer11's Avatar
    Jun 2016
    Occupied Kingwood Tx
    So why is puttting it in neutral to start such a bad thing?
    Keep your eyes on the road and your feet on the floorboards.2016 Freewheeler
  14. #13
    Quote Originally Posted by pioneer11 View Post
    I can only answer for me.....I never use the park-brake, And so i always park in first gear....So its easy just to pull in the cluch step on the brake hit the start button and go...
  15. #14
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    It's probably preferable most of the time...although, like rhino 2, I park in gear and most of the time start in gear.
    BUT...I have read of guys that have been in an intersection and inadvertently stalled (and could only start in neutral). When that happens, one is vulnerable to getting hit, having to go thru the extra step of finding neutral before starting just lengthens the time to get out of that dangerous situation.
    Related to the above...on the new bikes, the brakes need to be applied if starting in gear...not such a good idea if in traffic and rolling...then you have to slow/stop to get moving again.
    www.DKCustom.com
  16. #15
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Good points all and I do agree. But from a cold start I always do start in neutral since the clutch plates tend to drag after sitting a while. May not notice it on newer bikes that require you to hold the brake when starting in gear but if you've ever done a cold start on a bike that did not have the lock out feature and you did not hold the brake you no doubt noticed how the bike lurched forward a bit when doing a cold start in gear. I think this is added strain on the starter. But once everything is warmed up if I have to stop I do start up in gear.
    BTW I have gotten in the habit of using my parking brake even though I do always park in gear. I guess it's a belt and suspenders kind of thing. Just added insurance I guess.
  17. DKCustoms postbit
  18. #16
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by ultrafxr View Post
    Agree with you 100%. Just lazy sometimes.
    Directly related...my Softail has had a weak factory starter from day 1. If it is cold, I pretty much have to start in neutral, since the starter has a really hard time turning over with the extra drag from the cold oil on the clutch plates.
    www.DKCustom.com
  19. #17
    2250+ Posts
    Ocala, Florida
    Absolutely no doubt about there being extra strain on the entire starting system when stating in gear. I ALWAYS park my bike in gear, hop on and move the bike slightly in which ever direction it needs to go to take the strain off the drive train then hit the starter. Over the years it's become 2nd nature to find the sweet spot.
    PC
    Beware of liberals posing as Americans.
  20. #18
    30+ Posts
    Sep 2016
    Tam[a Florida
    Update! On 6 Dec I went in to dealer to ck on status of switchpack. ( 8 Dec was backorder date). The switchpack was still backorder with 20 Dec as the new date. TODAY, just for something to do, I stoped again to check and the backorder date is now the 29 of December.. Seems every time I check the update, the backorder date moves another 10 days farther.
    Hope thisis just just a temporary problem with the part.
  21. #19
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Snickers1948 View Post
    Hope they get you fixed up soon.
    Moving backorder dates are usually an indication of a widespread issue. I've been thru it in the past with compensators and rear brake light sending units...this is when they were having a high rate of failures.
    Also, sometimes HD changes suppliers, which can cause a hiccup in their inventory levels.
    www.DKCustom.com
  22. #20
    70+ Posts topsgt75's Avatar
    Jul 2015
    Lexington, Ky
    Had the same issue develop on my '17 Tri Glide last month. Dealer "could not duplicate" the problem first time. Second time in they could duplicate it.. Switch pack was on "backorder" then, so I opted and paid a little in difference and had illuminated switch packs put on!!!! Dealer had them in stock!
  1. Replies: 32
    Last Post: 10-31-2017, 12:47 PM
  2. Starting off in Scond Gear?
    By bikerbillone in forum General Discussion
    Last Post: 07-15-2016, 03:45 PM
  3. Starting my 14 TG In Gear
    By Alan Oakley in forum Harley Tri Glide
    Last Post: 09-27-2014, 07:33 AM
  4. starting a 2014 in gear
    By Beorn of Ga in forum Harley Tri Glide
    Last Post: 10-19-2013, 09:25 PM
