Likes Likes:  37
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 53
Thread: We need to talk about oil.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Default We need to talk about oil.
    I have a 2017 FW. At my 1,000 service in CA, the dealer put in HD Syn 3 & on my trip back to St. Louis it felt cooler & shifted better. At 3,750 miles, I changed to Lucas 20W-50 full synthetic high performance motorcycle oil in all 3 holes & the improvement in shifting was immediate. Also, the engine operating temperatures dropped about 20 degrees.
    I am glad that I made the switch & I like having the same oil everywhere. I am using the HD 5 micron oil filter. Looking at the specs, it's 1 of the better ones out there IMO.
    Here is what confuses me. I don't know if the notion of running the same fluid in all 3 holes just started with the new M8, but the correct procedure for what oil to use where varies from dealer to dealer & even at the same dealership, it depends on who you ask.
    I would think that as a company with a new engine out, there would be some consensus on the best procedure, but that's not the case.
    1 other oil item of note for new M8 owners. when I had the 1,000 mile service done at the dealer I purchased my FW from, the tech noted it was nearly a quart low on engine oil. He said this is very common in their brief experience with the new engines & mentioned that the MoCo had been getting the same comments. On my 2,000 trip home, the oil was down maybe 4-5 ounces, not enough to worry about, so the oil usage slows/stops after break-in, or at least mine did.
    So, what are you all using in all 3 fluid holes & why. Is it cost, availability or both. Also what filter are you using. I wanted a Mobil 1 (used on my cars for years) oil filter for motorcycles, but could not find them locally & after research, stuck with the Harley 5 micron filter from the dealer. They seem to be well made.
    Oct 2017
    St. Louis, MO USA
    In the area of full disclosure, my son has some connections & does work with Lucas Oil & he got them to send me 3 cases of their oil. I may not have ever tried it, due to the cost, but I'm glad I did. It's comparable to Mobil 1 V-twin oil, price wise, if you shop around.
    I do not sell Lucas Oil or any other oil.
    He also has K&N connections, and I'm working on getting some of their KN-171 oil filters. If I ever do, I will let you know what I think.
    4750+ Posts
    Mar 2015
    Texas
    There have be guys using one oil in all the holes for years so it's not new news. When I had a Harley my personal choice was a different oil for each hole. But it really was a pain. It's so much easier to keep one oil on hand only. And an oil you can pick up at any auto parts house is even better. Todays oils are so much better than just 15 years ago so it almost doesn't matter which oil you use anymore. The key there is almost. Use the correct oil for your engine and you are good for the most part. Harley and their three different holes will always cause people to have very different opinions on what to use. I think Harley did make a corporate statement that Sync3 could be used in all 3 holes. So if they did then they also said any equal oil could as well. I'm just not positive if they made that statement or if it has been the dealers which would make it another opinion instead. One thing to avoid are oils with friction modifiers though for those that only have one hole. So be careful there. Your best bet is to look at the owners manual.
    American Legion Rider
    I use Sync 3 in all 3 holes, And the standard Harley oil filter, 45 k on my 11 T/G And just under 4k on my 17 T/G....With out any problems with excessive heat.. [I do know i'm sitting on top of an air cooled engine] Or shifting problems...Its not a car with a firewall and insulation between my precious parts and the engine....
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    2014 32k miles
    HD Syn 3 in motor
    HD Formula+ in primary
    Bel-Ray 85W-140 in transmission
    Recently got introduced to this company and may try them out > http://stores.buyschaefferoil.com/ca...arley-oil.html
    I interviewed many Dealerships and you will NEVER find any consensus on oils. Everyone has their favorites. Every Dealer has lots of non-HD brand oils in the back to satisfy their customers oil requirements.
    Bob
    Oct 2017
    St. Louis, MO USA
    It's in the manual that you can use Syn3. It's actually their 1st recommendation.
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by HDB0B View Post
    2014 32k miles
    HD Syn 3 in motor
    Bob
    I looked at the Schaeffer Oil website you linked to & I personally have never heard of them & I tried to find a data sheet on their website & couldn't.
    I read a lot & the thing that I picked up on in reading independent oil comparisons is that specific motorcycle oil has a much higher zinc content(ZPD) that regular car motor oils.
    An example of this is Mobil 1 full synthetic oil (15w50) compared to Mobil 1 V-twin (20w50) motorcycle specific oil. Both these oils are very good at what they are intended for.The motorcycle specific oil has nearly double the Zinc that the car oil does.
    Reading on motorcycle forums, many bikers use the Mobil 1 oil because its a good oil & you can get a 5 quart jug at Walmart for $23
    Zinc is added to the oil to decrease wear. This is most likely due to the fact that many motorcycle engines can run at double the RPM that a normal car engine runs at.
    Oil is like a religion to alot of folks
    I have always run dino oil til now
    http://www.quicksilver-products.com/...otorcycle-oil/
    I am running this oil with good results
    I run Lucas gaer oil in the tranny
    Formula + in the primary\An HD filter up front
    I cannot find any filter supplier to go on record stating their filters are 5 microns
    I have always run HD dino oil in ALL my other bikes
    Seems this Quicksilver oil tests as good as Mobil1 HMMMMM
    Get it @ Walmart for 6bucks a quart
    Oct 2017
    St. Louis, MO USA
    Thanks Jack. That's good to know info on the Quicksilver oil in case I loose my Lucas Oil connection.
    On the 5 micron filters, the HD is the only 1 I know of & they say it on the box. I read who makes them for HD, but can't remember.
    4750+ Posts
    Mar 2015
    Texas
    Well who reads the darn manual???
    100+ Posts Tynker's Avatar
    Jun 2016
    Rosharon, Texas
    If it is as good as Mobil 1, why would pay more for it ??
    Mobil 1 = 5 qt's for $23.00
    Quicksilver = 5 qt's cost $30.00
    Quote Originally Posted by Tynker View Post
    Mobil 1 can be had @ that price when on sale,
    Not trying to defend Quicksilveroil, I buy it on sale @ Walmart
    Thanks Jack. That's good to know info on the Quicksilver oil in case I use my Lucas Oil connection.
    Champion Labs had the last contract for the filters that I remember
    They are big in the filter bussiness making lots of other filters also
    Did I say how much I hate oil threads?
    I do
    Like I said before Oil is like a religion
    Go with what makes you feel comfortable
    Most modern day oils ( synthetics) are manufactured in labs
    They are made to a high standard with chemical altered additive packages
    Some better some cheaper
    It is your ride You decide how much you will pay
    The only thing I stick with OEM is a HD filter
    I have yet to find any filter that can measure down ( according to HD) 5 microns
    Oct 2017
    St. Louis, MO USA
    You need to remember you are comparing a Mobil 1 car oil to a Quicksilver motorcycle specific oil.
    Oct 2017
    St. Louis, MO USA
    I do
    Don't like oil threads! It was you who told me to start this.
    OOPS, I dared you
    I think Tynker was talking about Mobil1 motorcycle oil
    It is a good oil
    I just dont like it
    Too many TC owners have some top end noise with this oil, my brother included
    Any modern day full synthetic is OKIMO
    I chose Quicksilver
    I have seen a Blackstone Lab test on it and it faired good
    After the test the zinc and other GOOD additives held up as good as Mobil 1
    Not bad IMO
    Oct 2017
    St. Louis, MO USA
    OOPS, I dared you
    It is a good oil
    I just dont like it
    I chose Quicksilver
    Not bad IMO
    I may give Quicksilver a try. When I get down to my last 4 quarts of Lucas, I may keep them for the transmission & primary & put Quicksilver in the motor. I'm kind of strange in that I plan things out, like what battery I will get for a replacement & what tire I will get, then when the time comes, I just look at my list & I don't have to shop & compare.
  19. #19
    Planning ahead, I like that
    Have you tried gear oil in your tranny? If not you should try it
    In almost every HD gear box I have had it makes for better shifting
    More cushion for the gears and bearings
  20. #20
    Oct 2017
    St. Louis, MO USA
    The Lucas Oil I'm using is doing great for me, but I'll look into it.
  1. Old vet just wants to talk
    By Oldveteran in forum Military & Veterans
    Last Post: 06-15-2017, 04:11 AM
  2. TV Talk
    By Papa Zook in forum General Discussion
    Last Post: 02-08-2013, 07:53 PM
  3. A GPS you can talk to
    By BlueTrinity in forum Accessories
    Last Post: 06-30-2009, 03:31 PM
