Likes Likes:  0
Results 1 to 11 of 11
Thread: brake problem !800 trike champion kit
    20+ Posts
    Sep 2013
    Grass Valley CA
    Default brake problem !800 trike champion kit
    Help I am Have a problem with my rear brakes they just feel like they are not stoping the bike like they should. I no that when they put the kit on that they take the link brakeing so the front work of the front hand grip and the rear work off the foot peddle. but it just dose not stop like it should. have bleed the system. have the recall master cylender done. seems like it got worse after they changed the master. but have bleed after that, still the same. Any help would be Appreciated. Halftrack
    JustWings.com
    Tech Contributor
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Quote Originally Posted by halftrack65 View Post
    What trike kit do you have ???
    Please keep in mind that anytime I share or give advice about a motorcycle, unless I state otherwise, I am always referring to GL1800's and no other.
    1000+ Posts mhgoldwing's Avatar
    Mar 2011
    mountain home,ar. USA
    You might try to find a more aggressive brake pad to replace the OEM. That's what I did on my Roadsmith and am now using EBC Yellowstuff pads. IMO, improved stopping by 30%.
    Also, install a foot brake lever pad to increase the surface area. Also helps. Something like this: http://wingstuff.com/products/21100-...ver-for-gl1800
    Wing with Roadsmith kit, Traxxion Ak20 cartridges and Accuride System.
    07 ST 1300 for two-wheeled fun!
    20+ Posts
    Sep 2013
    Grass Valley CA
    Quote Originally Posted by GoldWingrGreg View Post
    Hi I have a champion trike kit.
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    I haven't tried these, but I think I may keep a set in stock.
    EBC Yellow Stuff DP4105R between $60 - $100 per set on eBay.
    Several reviews say they are good stopping cold too............
    Jim Murphy
    Iron Butt Rider 2001
  6. #6
    80+ Posts
    Oct 2015
    Foresthill, Ca
    I too ride a Goldwing 1800 with a Champion trike conversion. When I first made the conversion I also was concerned that the braking did not seem as responsive as I thought it should. I took it back to the dealer and had it checked out.....all appeared to be OK. After getting used to the trike I no longer felt the brakes were and issue. I have put over 12,000 miles on the trike and have not run into any problems with the conversion. Loving the Trike.
    I am in Foresthill, Ca., not far from Grass Valley, maybe we will be able to take a ride sometime in the future. :0) Take Care.
    Roy
  7. #7
    Dec 2014
    Grand Junction, Co. USA
    I bled my rears (2008 gl1800 w/Champion kit) a full pint of fluid. half each side. This effectively replaced all the fluid. The was a little emulsification from water in the old fluid. Brakes are much more solid now. Might try a complete flushing.
  8. #8
    10+ Posts
    Aug 2015
    Priest river
    My brakes on my Goldwing with the Champion kit aren't that good. The front brakes are disconnected like others. But when I stop, I always use my front brakes with my back brakes, it stops good then. I think I will try the EBC pads that were mentioned.
  9. #9
    JustWings.com
    Tech Contributor
    May 2016
    Quote Originally Posted by Cruiser1800 View Post
    Here the problem some trike manufactures have with their kits. Both master cylinders can only push a limited volume of fluid. For example, Honda designs the front brake m/c to push on 3 front caliper pistons (the middle piston on the LF caliper, and the upper and lower on the right one). When the front and rear brakes are separated and no longer linked, usually the front master cylinder has to provide brake pressure and fluid volume to 4 front pistons (both upper and lower on the front calipers). The reality is that it's only designed to push fluid for 3 pistons and not 4.
    Therefore, the rider has to pull further on the front brake lever to push more volume of fluid to engage the pads. The same can be true for the rear. Most manufactures use aftermarket calipers with larger pistons. However, Honda's rear brake m/c seems to push enough volume to provide adequate braking when using the rear peddle. In the case of Champion, they are able to do it well because the rear brake m/c starts off by pushing the volume of 1 less front piston.
    Another thing to remember is that a trike is 400-500 lbs heavier, and more brake effort is always required to stop something that is heavier.
    If the brakes have been inspected and are working as designed, the best thing to do is use front and rear brakes when stopping the trike.
  10. #10
    Dec 2014
    +1, the extra weight is huge, especially when your load up your new huge trunk !!!
  11. #11
    50+ Posts
    Apr 2019
    Fort Myers, FL
    Educate me please. The brake system has no air in it and fluid does not compress so there is actually no movement of oil, or "volume" of oil being moved as I see it. Only pressure being applied. Kinda like pushing on one end of a pencil and the whole thing moves. What am I missing?
  1. Spedometer Problem & Emergency Brake Problem
    By JohnT1949 in forum Harley Freewheeler / Road Glide 3
    Last Post: 08-20-2016, 12:29 PM
  2. gl1800 champion trike need rear brake pads
    By GrandpaDave in forum Honda Trikes
    Last Post: 02-24-2015, 11:02 AM
  3. Brake Pads on a 2005 Champion Trike
    By Lone Wolf Top in forum Honda Trikes
    Last Post: 12-11-2014, 03:51 PM
  4. Champion trike rear brake bleed advice
    By scribe5 in forum Honda Trikes
    Last Post: 01-20-2014, 05:00 PM
  5. champion trike brake light ????
    By BLUZMAN in forum New Member Introductions
    Last Post: 05-10-2010, 04:51 PM
