14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  21
Results 1 to 20 of 38
Thread: Oil and transmission drain plugs
    200+ Posts
    Nov 2016
    groesbeck texas usa
    Default Oil and transmission drain plugs
    2016 twin cam tri glide. I give up I want to change all the fluids in this bike but for the life of me the under neath side of my pan doesn't look no where near what the owners manual shows. Can some one please show me where the engine oil and transmition drain plugs are located? I know see your dealer, not happening.
    300+ Posts 67wizard's Avatar
    Aug 2015
    Nv.
    This is looking at the front of the motor.
    Arrow on the left side of picture, their is a hole in the cross member to get to that plug. Other plug u should be able to see on the lower front of motor. If not I can't help u.
    CMA member, VietNam 66-67
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
    Aug 2015
    Nv.
Size:  371.3 KB primary plug
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
    200+ Posts
    Nov 2016
    groesbeck texas usa
    don't look like that pan either. If it's weird I get it.
    Aug 2015
    Nv.
    What kind of tri glide do u have? Must not be a harley motor.
    PM me and we'll talk.
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
    200+ Posts
    Nov 2016
    groesbeck texas usa
    it's a 2016 Harley-Davidson twin cam tri glide
    Aug 2015
    Nv.
    So is mine and thats the way it looks.
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
    Aug 2015
    Nv.
    I got this from the tri glide pictures.
    4750+ Posts
    Mar 2015
    Texas
    Quote Originally Posted by lightnin View Post
    Could you take a picture of it so others that have similar issues might also be helped as the guys here help you. This is what forums are all about. Friends helping friends. Sometimes it's just the way a person is looking at something and with a key pointer they get it. But I guarantee you are not alone in this. I see it especially with first time Harley owners. But returning owners get turned around as well. phone camera pictures can truly help the folks here help those just not seeing the same thing.
    American Legion Rider
  11. #10
    200+ Posts bronxbill's Avatar
    Jan 2016
    Raleigh NC
    Mine looks like 67 Wizard's picture also; I have a 2016. In the picture, the nut on the front is the oil drain; you can barely see the transmission drain nut. In the picture it is on the left side, you have to go thru the hole in the frame member to access it.
    2016 Tri Glide Black and Silver, VIEDS, LRS, DK Comfort Lift, DK 2" Tank Lift Kit, Road Zepplin Seat, Black CVO mirrors, K&N Air Filter, Wards Fans, Khrome Werks 2+2 Wide Sweepers.
  12. #11
    Dead animals deserve balloons... MikeyTX's Avatar
    May 2016
    Big Bend Country, TX
    True this.
    2021 Mustang GT Premium A10 Handling Pkg
    Red White and BBQ Texas, it's whole whole nother country .........
    [SIGPIC][/SIGPIC]​
  13. #12
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by 67wizard View Post
    My 2014 Twin Cam Tri-Glide looks like this also.
    The transmission drain plug is accessed via the cut out in the cross-over brace.
    One thing that may be confusing...the engine oil drain plug is NOT below the engine...it is behind the engine by a good 6-8 inches (or more). This is because the engine uses a remote oil reservoir, and that is where the oil is drained from.
    The engine oil does not sit in the bottom of the engine like most automotive engines.
    When looking for the above pictured drain plugs, look under the trike, further back than the bottom of the engine.
    www.DKCustom.com
  14. #13
    Sep 2016
    Springfield, Mass. USA
    Ahhhhhhhhhhhhhh Honda Goldwing is "easy pizzy" only remove plug, drain oil, replace plug, refill with oil. DONE!
  15. #14
    Aug 2015
    Nv.
    How about changing your air filter? LMAO
    I had four goldwings, now my third Harley. would never change back.
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
  16. #15
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Uhhh...that's what I do on my TG, except I also have an oil filter. Surely GW's have an oil filter also?
    www.DKCustom.com
  17. DKCustoms postbit
  18. #16
    Does this look like your pan?
    If it does #6 on the right side bottom of pan is the tranny drain
    It is identical to the LS oil drain
  19. #17
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    This 'Harley Davidson Sportster-How To Change Transmission Fluid' article on HD forums is the source of the above picture. Says its a late model Sportser and from the width of the rear tire and the tapered exhaust pipe in the picture it looks to be one, but the article's author could be mistaken and used a picture of a Dyna, which would make more sense. I dont own a Sportster nor a Triglide so I cant say for sure.
    https://www.hdforums.com/how-tos/a/h...n-fluid-412992
    Name:  HDF Sportster Tranny Oil.jpg
  20. #18
    I know its splitting hairs here, But #6 is the washer , #16 is the plug....
  21. #19
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    This 'How To Change Transmission Fluid' article on HD forums is the source of the picture. Says its a late model Sportser and from the width of the rear tire and the tapered exhaust pipe in the picture it looks to be one, but the article could be mistaken and used a picture of a Dyna, which would make more sense. I dont own a Sportster nor a Triglide so I cant say for sure.
    You are correct, that photo in the above article is inaccurate....that is a photo of a Twin Cam. The Sportster (evolution engine) oil tank is up under the seat and the way you drain the oil is from a hose that hangs down below the oil tank.
    Also, on a sporty the transmission and primary share the same oil (only 2 holes on a sporty vs. the 3 holes on the Twin Cams), which is drained from the bottom of the primary cover, in a similar spot of where you drain the primary on a Twin Cam.
    www.DKCustom.com
  22. #20
    Aug 2015
    Nv.
    Sorry for the post I was only trying to give him a general idea where to look and what they looked like. I won't post again. It still sounds like the OP don't know what to look for and proly should not be working on his trike. I only have 75 years messing around but still in the learning stage. If this bothers u please delete my account. God Bless.
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
  1. Drain plugs
    By Hawg in forum New Member Introductions
    Last Post: 05-24-2017, 03:01 PM
  2. Oil Filter Drain M-8
    By hddocfl in forum Harley Tri Glide
    Last Post: 05-21-2017, 07:05 AM
  3. Drain plug
    By howardg in forum Honda Trikes
    Last Post: 05-03-2017, 08:08 AM
  4. Battery drain need help
    By skipg in forum Honda Trikes
    Last Post: 10-14-2014, 01:35 PM
  5. Battery drain?
    By Harry2u in forum Honda Trikes
    Last Post: 08-16-2013, 08:08 PM
