Likes Likes:  17
Thanks Thanks:  2
Page 2 of 2 FirstFirst 1 2
Results 21 to 25 of 25
Thread: Please Help with an Error Code I Cant Track Down!
  1. #21
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I replaced my switch, but alas the damn code came back
    I have checked my pressure with a master gauge, it looks fine
    Not much faith in this can bus system so far
    I'm just not sure whether I should let them mess with it or let it go. I had convinced myself to forget about it & it's been 8 months since the last one.
    My logical brain is telling me it can't be anything serious if it's popping up every 8 months or so.
    My anal side is thinking, if you blow it off & the warranty runs out in 6 weeks, you will be stuck with the bill.
    Any thoughts?
  2. #22
    Any thoughts?
    Let your dealer handle this now, that way you have a paper trail started
    Chances are good HD has another batch of new sourced units for the dealers
    This has happened before when they got a bunch of defective Chinese units
    You can also ask your dealer to run a master gauge on your trike and record the PSI for you, they will already have the old sender out so it only takes another 5 minutes to run this test
    A good tech and service manager should IMO agree on this
  3. #23
    Oct 2017
    St. Louis, MO USA
    Jack, I enjoy bouncing my thoughts/ideas off of you because we tend to think alike. Thanks
    I talked to the service manager at Doc's HD & I'm bringing it in next Sat. & they will check it out & verify everything is OK, oil pressure wise & if that checks out, replace the sensor.
    They stated that the issue is documented & even when my warranty expires, if it becomes a problem again, they will take care of it.
    He still thinks it's no big deal & just an overly sensitive sensor, which is what he said a year ago.
  4. #24
    Thanks Michael
    Good on you for the great relation have with your dealer
    I hope they have a NEW and improved sensor now in stock
  5. #25
    Oct 2017
    St. Louis, MO USA
    I'm hoping this problem is corrected. The oil pressure sensor on my 17 had a bare spot on the sensor wire. My dealer tested my engine oil pressure & replaced the sensor.
  1. Round da Track
    By dawingrider in forum Trike Travel
    Last Post: 04-17-2015, 12:00 PM
  2. Hello all, trying to get back on track
    By BenO in forum Stallion Trikes
    Last Post: 06-26-2012, 05:57 AM
  3. tri-glide track width
    By dyna_rider98 in forum Harley Tri Glide
    Last Post: 05-29-2012, 06:50 PM
  4. rear wheel track ( Axle widths)
    By sophtayl in forum Harley Trike Conversions
    Last Post: 05-14-2009, 08:39 PM
