Twin Adjustable Bitubos
Custom Tuned to Your Bike & Your Riding Style/Loads
Sportster ~ Dyna ~ Touring ~ Trike
Check out this REPORT LINK we did on Rear Shocks. Lots of Dyno Charts and very useful information!
-These Top of the Line Shocks give superior ride quality. Not only do they smooth out the bumps, large & small, it is amazing how much more stable your bike/trike will feel going thru the curves. It is confidence inspiring.
-Nitrogen pressurized with a oil/gas separating piston, these dual chambered shocks improves riding comfort and vehicle control thanks to the internal hydraulic system. The large adjustment Rebound range offers excellent performance in every riding condition. Coupled with coil over springs that have an adjustable pre-load, you will be amazed how much smoother and more stable your bike/trike will ride.
-These Twin Adjustable Shocks are available in 3 lengths: 11", 12" & 13". The travel is 1.7", 2.7" & 3.7" respectively. Combined with less sag than the stock shocks, this gives an average of 33% - 50% MORE Travel. (Unless otherwise requested, we will send the OEM length shocks for your bike to you)
-When you order you will be asked some easy questions. Your answers give us the information needed to use the correct springs for your shocks, as well as giving us the info needed to adjust the pre-load and rebound for you. This way when you receive the shocks they are already set-up for you. Simply bolt them on and ride!
Click HERE for more photos and details!
