Likes Likes:  2
Results 1 to 19 of 19
Thread: Antenna base corrosion
    100+ Posts Trikesyke's Avatar
    Oct 2016
    New York
    Default Antenna base corrosion
    I removed (unscrewed) both antennas and discovered the FM base threads were clean where they were covered by the antenna, but rusty where exposed to the elements (I presume). The CB base threads were however, corroded, not rusted, from top to bottom. I realize the corrosion is not good, a non conductor, but I wonder why the antenna did not protect the base like the FM antenna did. Anyone have an idea/answer? Also, would non conductive lubricant grease protect the connection? And how about cleaning the antenna and base threads?
    2015 Tri Glide Ultra Classic - White Hot Pearl / Blue Hot Pearl
    200+ Posts
    Nov 2015
    palm bay
    Quote Originally Posted by Trikesyke View Post
    A wire brush would clean the antenna. Not sure hot to clean little hole. Grease would help keep it from happening again, Don't worry about conductive or not at the frequencies they work on.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Use a dab of Die- Electric grease on the threads and screw on, good to go. Do both
    Use the grease on butt connectors also.
    Oct 2016
    New York
    Quote Originally Posted by vito View Post
    Thanks Vito. Wire brush sounds good. Are you implying that I don't have to clean off the corrosion? I would think there needs to be an electrical metal to metal connection between the base and antenna in order for the antenna to be the 'extension' of the wiring.
    Oct 2016
    New York
    Quote Originally Posted by 1dn5up View Post
    I couldnt think of dielectric. Thanks 1dn. Are you saying the grease will cut through the corrosion?
  6. DKCustoms postbit
  7. #6
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Yup, it’s only brass. If it was that bad you would of struggled to unscrew the antenna.
  8. #7
    200+ Posts
    Nov 2015
    palm bay
    Metal to metal is best but if insulated by a very thin layer of grease it forms a capacitor that has very little impedance at FM or even CB frequencies - probably not enough to matter. Generally, the first/last thing you'll find inside your radio is a capacitor that's there to protect the rest of the circuits from external voltages.
  9. #8
    Oct 2016
    New York
    Actually, I did have some difficulty unscrewing the antennas....
  10. #9
    Oct 2016
    New York
    And this is why I wanted to ask on this forum! Thanks vito.
  11. #10
    60+ Posts
    Mar 2010
    Western NY
    Default Clean internal threads.
    If you want to clean internal threads, a small bore gun brush works quite well.
    '15 TG Red Sunglo/Cayenne, Chrome Forks & Wheels, LED's, TGlide Stuff Lift.
    Patriot Guard
    Previous HD's: '13 TriGlide, '13 Fat Bob, '05 Super Glide, '00 Heritage, '96 Heritage, '94 FLHTC, '77 FXR
  12. #11
    Dead animals deserve balloons... MikeyTX's Avatar
    May 2016
    Big Bend Country, TX
    So true. stuff is great.
    2021 Mustang GT Premium A10 Handling Pkg
    Red White and BBQ Texas, it's whole whole nother country .........
    [SIGPIC][/SIGPIC]​
  13. #12
    200+ Posts
    Nov 2015
    palm bay
    Quote Originally Posted by MikeyTX View Post
    dielectric grease is an insulator that has a place but that place is not between two conductors that are supposed to pass current. It is good for keeping moisture out of connectors. So is Vaseline.
  14. #13
    4750+ Posts
    Mar 2015
    Texas
    Quote Originally Posted by hocnsoc View Post
    There ya go. I knew I'd seen a brush that would be perfect for cleaning those threads. Right there in my gun cleaning kit. DUH!!!
    The only reason some people are still alive is it's illegal to shoot them.
    American Legion Rider
  15. #14
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    I agree. I hate the stuff. A friend who is a heavy equipment mechanic with Caterpillar told me they were instructed to NOT use dielectric grease. After a while it dries out, gets hard and sticky and is just a general mess. Keep it clean and dry and you'll be OK.
  16. #15
    May 2016
    Not sure who told you that. There is a reason it is on the base of every damn bulb Harley installs at York. Dielectric grease is used on spark plug terminals, and many other electrical applications because it does not inhibit current flow. Google it !
    [SIGPIC][/SIGPIC]​
  17. DKCustoms postbit
  18. #16
    May 2016
    Default Is Vaseline a good conductor of electricity?
    "Petroleum jelly is not a conductor - though it might have very slight conductivity, even air does. It is not a good thing to put on electronics as some wire insulation deteriorates in the presence of grease and oil. It is also messy and I'd expect that if there are high temps present it may melt and leak." ​ Direct quote from a google search.
    [SIGPIC][/SIGPIC]​
  19. #17
    Oct 2016
    New York
    Thanks Hoc. I'm thinking 9mm isn't the correct size then........
  20. #18
    May 2016
    A bore brush for the M108 ought to work just fine ....................
    [SIGPIC][/SIGPIC]​
  21. #19
    200+ Posts
    Nov 2015
    palm bay
    We used to use it inside high voltage coaxial RF connectors because other greases would short the inner conductor to the outer. Use is also recommended to prevent 'fretting' where there is vibration. Maker describe it as "electrically neutral" whatever that means. I use it on handlebar switch assemblies of older HDs to keep rain from shorting switches.
  1. Rear wheel base measurments.
    By Barry in forum Outrigger Style Trikes
    Last Post: 06-07-2017, 09:36 AM
  2. Wheel base width
    By Hank62 in forum Harley Trike Conversions
    Last Post: 03-24-2017, 10:49 PM
  3. Rushmore Boom Audio Base
    By FuzzyWuzHe in forum Harley Tri Glide
    Last Post: 07-14-2015, 11:03 PM
  4. wheel base n v8ers
    By ratrodney in forum General Discussion
    Last Post: 05-08-2013, 08:20 PM
  5. Ramada Sarasota Base for Snowbird Welcome!!
    By Big Dog in forum Other Rallies & Rides
    Last Post: 07-29-2012, 10:09 AM
