Gernerwa10Jack KlarichNew Member Introduct...New Member from Bellingham, WA
Gernerwa10trike ladyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GorillaNew Member Introduct...New Member from Bellingham, WA
Gernerwa10rhino 2New Member Introduct...New Member from Bellingham, WA
Gernerwa10Marc HNew Member Introduct...New Member from Bellingham, WA
Gernerwa10Uncle FesterNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ZammyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10hardwickbvNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ol' schoolNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GernerwaNew Member Introduct...New Member from Bellingham, WA
Speed Bleeders
Too Pa Pa Zook
Likes Likes:  1
Results 1 to 3 of 3
Thread: Assistance needed with GL1500 Voyager installation
    Nov 2017
    San Diego, CA USA
    Default Assistance needed with GL1500 Voyager installation
    Hi everyone, I'm in the middle of installing a Voyager kit on my 96 Gl1500 Aspencade. I've run into a problem with the left axle bracket. Out of the box, the axle hole was too small for the fat end of the axle to pass through, so I enlarged it by about 1mm and that was enough. I removed the spacer between the caliper bracket and the swingarm per instructions (it fell out by itself). After reinstalling the axle with the newly enlarged hole and tightening the axle nut to the prescribed 80 ft-lbs, the axle bracket has a small amount of end play (same direction as axle). The upper brace for the bracket is clamped to the swingarm per instructions. The removed spacer is 3mm wide, the axle bracket is 7mm wide. I'm convinced the problem is connected to the width difference somehow.
    I called MTC Voyager and talked to their Tech about the hole sizing problem. He said the holes are cut by water jet by their supplier and now and then they mess up. Problems are usually caught by the end user.
    Has anyone else run into this problem? I'm not going to finish installation until I get the end play problem resolved.
    10+ Posts KKILASER's Avatar
    Aug 2015
    Gilbert,AZ
    If you move this thread to the outrigger forum someone there with a GL1500 and a Voyager kit might be able to help you. I have a Vulcan nomad and when I installed the kit the left axle bracket was to long where it bolted to the swing arm. I had to do some bending of the arm to make it fit. Hope someone can help.
    Don
    50+ Posts baba67's Avatar
    Sep 2015
    Falmouth, CapeCod,MA.
    Default voyager install
    Hello everyone,
    When I did my install on my 1997 GL 1500, I noticed that after the removal of the factory spacer and after installing the left side axle bracket, that I had some slight movement in the assembly.
    I went to the hardware store and purchased a large thin stainless waser to take up the extra free play.
    After that everything went very well.
    I realy enjoy the Voyager kit.
    80% satisfied with everything.
    Note:
    BE SURE WHEN YOU INSTALLED THE AXLE, YOU REMEMBERED TO TIGHTEN THE AXLE PINCH BOLT ON THE LEFT TRAILING ARM.
    Happy Holidays to all.
    Quote Originally Posted by Gruntled View Post
  1. New Gl1500 Voyager Owner
    By Gruntled in forum New Member Introductions
    Last Post: 12-04-2017, 09:39 PM
  2. Installation Info needed
    By mirider in forum Harley Tri Glide
    Last Post: 03-06-2017, 12:39 PM
  3. Wanted. a used voyager or tow pac for my GL1500
    By kenvb in forum Outrigger Style Trikes
    Last Post: 01-02-2016, 10:03 AM
  4. Roadside assistance
    By GARYD in forum Harley Trike Conversions
    Last Post: 08-12-2012, 05:04 PM
