Likes Likes:  1
Results 1 to 9 of 9
Thread: Charging question
    30+ Posts
    Aug 2016
    Fort Mill, South Carolina, United States
    Default Charging question
    Since I completed my trike last June I have noticed that the lights flicker at higher rpm's. I do have a alternator so I did not think I needed a voltage regulator. I have a head light, tail lights, turn signals and 2 55w driving lights. Is my alternator going bad?
    Thanks in advance for your thoughts.
    Every vehicle I ever had
    with an alternator also had a voltage regulator ??📞
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Do they flicker brighter or dimmer ? If dimmer,ck your grounds. If brighter you might need a regulator unless it’s built into the alternator like GM has. If you have a volt meter, check the reading when it happens.
    Like Bob said , you DO need a regulator or smoke will appear !
    Try That
    30+ Posts
    Aug 2016
    1dn5up, they are getting brighter. Ithe alternator is putting out 13 V at idle and 15 V at higher rpm.
    30+ Posts
    Aug 2016
    I believe VW alternators have an internal regulator.
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    got to agree with the others.....if lights get brighter than normal, sounds like a bad regulator. voltage should hold around 13.5 to 14.5 and hold steady at cruise rpm. Auto parts stores should be able to check this out if you bring the alternator in to them. good luck
    15 volts is getting on the high end
    This depends on battery draw and how the state of charge on the battery is
    Charge your battery over night first
    check it with a volt meter the next day
    If u have at least 12.7 volts, turn your lights on with the meter on the battery
    count to ten
    If the battery holds at least 10 or above u can pretty much rule out the battery
    Next will be to find out what kind of alternator u have
    Many have integral regulators
    Many of these are cheap and easy to replace
    Once you verify this and check back in some one can walk u thru this
    Is this an older VW with a generator?
    If so it will have a seperate regulator
    You will also need to flash the fields on the generator ( polarise) each time you break a connection between the gen and the battery
    100+ Posts Tynker's Avatar
    Jun 2016
    Rosharon, Texas
    If he has a GW trike, it has a alternator,with built in regulator, just like your car/truck.
    30+ Posts
    Aug 2016
    Quote Originally Posted by LarryA View Post
    First off I do Have an alternator and I believe it does have an internal regulator. it was on the trike and working fine (no flickering) when my Dad originally built it.
    Now the battery voltage is 13.5 V disconnected. Battery voltage holds at 11.8 with all lights on without the engine running. I am pretty sure it is time to replace the regulator.
  1. Charging problem Stallion
    By Triker Rob in forum Stallion Trikes
    Last Post: 09-29-2017, 08:40 AM
  2. Potential charging problem
    By pddgm in forum VW Powered Trikes
    Last Post: 01-28-2015, 09:43 PM
  3. Battery charging prob.
    By lboos in forum Harley Tri Glide
    Last Post: 12-17-2014, 06:00 PM
  4. Roadhawk Charging Problem ?
    By 2blackbelts in forum VW Powered Trikes
    Last Post: 05-09-2012, 11:14 PM
  5. my t/g battery charging fix
    By eagle1 in forum Harley Tri Glide
    Last Post: 03-07-2012, 11:52 AM
