AriNV5AriNVRider Safety Discuss...Maybe silly but serious question, s...
AriNV5pawsRider Safety Discuss...Maybe silly but serious question, s...
AriNV5Pegasus1300Rider Safety Discuss...Maybe silly but serious question, s...
AriNV5cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
AriNV5Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  1
Page 2 of 2 FirstFirst 1 2
Results 21 to 37 of 37
Thread: Trailer Hitch
  1. #21
    10+ Posts rvtriker's Avatar
    Jun 2009
    Antwhere, USA
    Default Re: Trailer Hitch
    T40 was craftsman, going to try the heat, a hand impact, they might have used permanent thread lock. Thanks
    RVtriker
    "No Good Deed Goes Unpunished"
    09 HD Triglide
    Fulltime RVr
    Our Blog
  2. #22
    150+ Posts
    Feb 2008
    Kansas
    I know this is a thread about hitches but I think this needs to be said. If you actually plan to pull a trailer behind either a TriGlide or a late model (6 speed) HD you should think seriously about a gear change. This may not effect the 2011 TriGlide as they have changed the front pulley to a 30T. My 09 TriGlide, loaded for a 10 day trip, two up, struggled to maintain legal speeds with any kind of wind blowing. Many miles of this trip were done in 5th gear. For reference I weigh 215, the missus weighs quite a bit less (CYA guys). My 07 Ultra/CSC kit suffered through the same problems until I changed the gearing. The new CVO/Champion conversion that I'm building will start out with the 30T front pulley for the above reasons. I did have a trailer hitch on the CSC but only used it for a cooler mount.
    Dwight
  3. #23
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Quote Originally Posted by Dwight View Post
    Dwight
    You have a very good point, I know my 2010 was the same way when I 1st bought it and boy was I ticked. Last winter I installed the SE255 cams, Fuelmoto jackpot head pipe and tuned it with a SEPST. Talk about night and day different, took the same trip with the wife and the hills the trike was sucking wind on going up the previous year it sailed up last year. This winter I swapped out the SE255 for the Woods TW-555 and changed the transmission sprocket to a 30 tooth, switched the tuner to a TTS so I could calibrate the speedometer. A couple days ago I took it for a short little jaunt so I could heat it up and change the oil to get the assembly lube out of it. My 1st impressions is this thing is going to rip once its tuned.
    http://i1347.photobucket.com/albums/...pswnuweejq.jpg
    Red Ultra Powered By Head-Quarters 120, Easy Clutch Pull By ClutchWIZ. 2012 GL1800 Hannigan. I've yet to ride a stock Harley which wasn't in need of a mechanical intervention.
  4. #24
    30+ Posts cewhit1's Avatar
    Dec 2010
    Logansport, IN. USA
    Quote Originally Posted by nolafishr View Post
    I found this site that sells the Trailer Hitch for the Tri Glide Models, Not cheap but the only I came across so far, I will be adding one to my trike later on after I get it.
    rivco.com
    I found one from for $200. that bolts on to my 09 Tri-Glide.
  5. #25
    Dec 2010
    Logansport, IN. USA
    Quote Originally Posted by BlueTrinity View Post
    Yep...and installation must be by your authorized dealer or your warranty is void.
    You'll also have to buy the $79.95 special ball mount to slide into the Harley 1.75" receiver. Of course there will be the Chrome version with laser engraved bar and shield for $125.95.
    Your warranty will be void if you install or the dealer installes the hitch.
    Chuck
  6. DKCustoms postbit
  7. #26
    50+ Posts
    Apr 2011
    CenCal
    The Magnuson-Moss Warranty Act says that a manufacturer cannot deny a warranty claim because of an aftermarket part, unless the part in question actually CAUSED the problem that the warranty claim is about.
  8. #27
    Sep 2009
    NE Ohio
    Quote Originally Posted by grapenuts View Post
    You are correct, but how many successful out comes have you seen where someone battled the MoCo and came out on top. I have first hand experience on what happens when the dealer or the MoCo rep is unhappy about a modification even with their own parts. My dad had issues with the dealer and a MoCo rep not willing to trouble shoot his Triglide with SE255 cams installed by me. When mention of legal action and the MM act was brought up the owner of the dealership said my dad was more than welcome to persue any legal means he wanted. He also went on to state he would not allow any of his technitians to work on the engine. The MoCo rep flagged the power train warranty with a note that all claims had to be reviewed and cleared with the MoCo on a case by case basis.
    Take it for what its worth, if you want to try the MM act I hope you have deep pockets and willing to spend years in court fighting it while you bike or trike sits broken or you fix it out of pocket.
  9. #28
    1+ Posts
    Nov 2010
    MIMS,FLA
    I just bought a 2011 tri-glide and a mchitch for it but the bolt holes are not threaded and the rear holes are partialy blocked so you cannot put bolts in them unless you drill them or grind some of the plastic or fiberglass brace out. Both mchitch and dmc said i have something odd because the holes should be threaded to install the hitch. I think harley changed it so you can't mount the hitch.
  10. #29
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    Quote Originally Posted by Oldmsocko View Post
    Mu dealer says no way. It all depends on who you talk to. Call HD Customer Service and ask them.Their # is 414-343-4056
    Liability, liability, liability !!!!! That's all I heard, every other word. If they haven't tested it it will void your warranty. Actually told me that somebody might put a hitch on and pull a lawnmower, warranty voided. ??? Serious !!!!
    I said something about putting a 300# rider and a 300# GF on there and having a wreck. Have they tested that??? Actually told me there is a posted weight limit on each bike and if that limit is exceeded they could void the warranty...!!!!
    I said they could basically void just about anything and he said yes....!!!!
    8~\o
    "Anybody can become an American but ya have to be born a TEXAN"
    "Ya know I haven't been everywhere but it's on my bucket list"
  11. #30
    350+ Posts
    RickDeVon's Avatar
    Jun 2010
    Pine Mountain,Ga
    Not only the hitch but also the lift kit will void the suspension...
    Miss Mysterious...
    2015 Mysterious Red Tri Glide...
    Vance&Hines head pipe w/Rhinehart slipons...Slipstream Collection...DK Lift...11" Clearview w/ recurve...HD chrome Enforcers w/Goodyear Triple Tread Assurance...just a touch of chrome & LEDs...
  12. #31
    350+ Posts
    RickDeVon's Avatar
    Jun 2010
    Pine Mountain,Ga
    As told to me by a HD dealer but not the one that did the install ...
    Miss Mysterious...
  13. #32
    TOI - Idaho BinIdaho's Avatar
    May 2009
    Caldwell, Idaho
    You all responded to a 4-year thread? Boy, must be really slow around here!!!!
    Barbara
    2020 HD Tri-Glide
    River Rock Gray/Black Accents
  14. #33
    Jun 2013
    Texas
    Quote Originally Posted by BinIdaho View Post
    Yep, might be old but when circumstances arise that effect you directly it becomes a current issue. I read thru all the 'old' responses and they could have been posted yesterday. Felt instead of starting a new thread to just add to the old. There are some 5-6 threads here addressing the same issues, re-inventing the wheel.
    AND at my age "old" is good.
    8~\o
  15. #34
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    That is why we tell everyone to do a search for the information they are looking for !
    Agree 200% !!
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
  16. #35
    20+ Posts
    Jan 2022
    Wellsville NY USA
    Default Trike hitch plans
    Thanks for your reply. Is your hitch designed for a certain trike? Mine is a home built V 8 with the usual automotive frame.
  17. DKCustoms postbit
  18. #36
    80+ Posts Oldrodder's Avatar
    Mar 2018
    Sudbury, on. Canada
    It's interesting that this thread is posted in the Harley Conversions page where all manufacturers of conversions offer a trailer hitch option, rather than the triGlide page!
  19. #37
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    I had a hitch for my 2014 Triglide and I would install it when needed but take it off when going to the Harley service because once a dealer flags your vin it is in the system. I never pulled a trailer only used it for a flag holder a few times. My Harley dealer just shrugged his shoulders and said hitch I don't see no hitch but all dealers are not the same.
    2019 Goldwing CSC
  1. Trailer Hitch
    By gbsb in forum Harley Trike Conversions
    Last Post: 04-28-2013, 07:56 PM
  2. Trailer Hitch
    By trikermutha in forum Harley Trike Conversions
    Last Post: 06-23-2011, 01:59 PM
  3. Trailer Hitch
    By Trick in forum Trailers / Campers
    Last Post: 08-22-2009, 07:25 PM
