Likes Likes:  2
Results 1 to 7 of 7
Thread: tire question
    Nov 2017
    indian lake estates, fl. usa
    Default tire question
    I have a 2005 Suzuki c50 with lehman tramp conversion, it has a 195/65/r15 tires on rear dated 2005, i'am alittle leery about a tire that old, the specs say 205/60/r15 the conversion was factory built question is if I put the 205 on will I have any clearance problems, as of right now I can only fit my index finger between the tire and edge of fender
    Last edited by jack1576; 12-07-2017 at 08:22 AM. Reason: forgot to mention i have lehman wire wheels
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    If there’s no room for error now, then stick with what works now. 195vs205 , yup, it’s bigger.
    700+ Posts jjvw's Avatar
    Dec 2013
    Jenison, MI
    I go to TireRack.com for my tire specs:
    SIZE UTQG MAX.
    LOAD
    MAX. INFLATION PRESSURE TREAD DEPTH TIRE WEIGHT RIM WIDTH RANGE MEAS. RIM WIDTH SECT. WIDTH TREAD WIDTH OVERALL DIAM. REVS. PER MILE COUNTRY OF
    ORIGIN*
    185/65R15
    88H SL
    600 A A 1,235 lbs. 44 psi 9.5/32" 20 lbs. 5-6.5" 5.5" 7.4" 5.9" 24.4" 851 US
    195/55R15
    85V SL
    600 A A 1,135 lbs. 44 psi 9.5/32" 21 lbs. 5.5-7" 6" 7.9" 6.3" 23.4" 888 US
    195/60R15
    88H SL
    600 A A 1,235 lbs. 44 psi 9.5/32" 20 lbs. 5.5-7" 6" 7.9" 5.8" 24.2" 859 US
    195/65R15
    91H SL
    600 A A 1,356 lbs. 44 psi 9.5/32" 20 lbs. 5.5-7" 6" 7.9" 6.2" 25" 832 US
    205/60R15
    91H SL
    600 A A 1,356 lbs. 44 psi 9.5/32" 20 lbs. 5.5-7.5" 6" 8.2" 6.2" 24.6" 842 US
    205/65R15
    94H SL
    600 A A 1,477 lbs. 44 psi 9.5/32" 22 lbs. 5.5-7.5" 6" 8.2" 6.4" 25.4" 817
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    All of the Tramps I have had dealings with had 205/60/15 tires. The 195/65 would be easier to get off and on.
    If you have wire wheels on the rear, be careful when breaking the tires down. There is a sealant strip that covers the spoke nuts inside the wheel to keep a tubeless tire from leaking. Do not disturb that strip or it may start leaking from the spokes
    Jim Murphy
    Iron Butt Rider 2001
    Nov 2017
    the 195's that are on there were made in 2005, bike was stored inside, I don't see any cracking and tread looks like new, should I feel safe using them
    Martinsburg, WV
    Quote Originally Posted by jack1576 View Post
    Look ... the tires cost less than $100.00 each. I would replace them because of their age and the fact you are in Florida where tire temps can easily run over 160 degrees. Peace of mind while riding is another reason.
    Jim Murphy
    Dec 2017
    Brantford, Ontario, Canada
    what Jim said .... there's a reason they put dates on them ...5 years is about as long as the manufacturer is willing to bet the tire won't let you down ...you determine the cost of your own piece of mind
    Ride Safe, Ride Smart, Ride Often
    RD52
  1. Tire question.
    By 520fd in forum Honda Trikes
    Last Post: 03-06-2016, 06:17 AM
  2. Tire question.
    By 520fd in forum Stallion Trikes
    Last Post: 03-04-2016, 02:14 PM
  3. Another Tire Question
    By leo3wheel in forum Yamaha Trikes
    Last Post: 04-20-2013, 08:12 AM
  4. Tire Question
    By RRSCOTT in forum Honda Trikes
    Last Post: 04-13-2013, 08:57 PM
  5. Been a while and now I got a tire question
    By RobTheHillbilly in forum Tires, Wheels, Brakes, Front End
    Last Post: 05-26-2012, 09:29 PM
