Likes Likes:  9
Results 1 to 20 of 22
Thread: Stage 2 woes
    100+ Posts Trikesyke's Avatar
    New York
    Default Stage 2 woes
    A fellow triker was saying he had a Stage 2 put in but said he has no power and going up hill the trike bogs down. Also he has lost gas mileage. I did not get to ask him to explain. My thought is maybe he got the high end cam stage 2 instead of the mid range stage 2 and he doesn't know to keep the rpm's up. Any other thoughts? I am considering a stage 2 mid range myself. I believe he has a 2013.
    2015 Tri Glide Ultra Classic - White Hot Pearl / Blue Hot Pearl
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by Trikesyke View Post
    Its hard to say what his problem is without knowing what cam he installed and what tuner & tune he did after the cam install.
    It might help if you ask the fellow triker to join Trike-Talk and then let everyone know exactly what was done to his trike.....Otherwise you'll have 20 speculative answers and you still won't know more than you know now....
    Agree, we need more info
    Hard to say what cam would do this let alone how much fuel is running in the engine
    What the compression ratio is ETC
    Aug 2015
    Pella
    Default Stage II cams "goodbye warranty"
    Allow me to throw another hat in this ring. I have a 2017 M8 Freewheeler with a Pro Street Tuner, Screamin Eagle Smart Pro Tuner, Extreme Flow air filter, and Street Cannon mufflers with cats, all Harley approved accessories.I went to my dealer a month ago and asked them to install the stage II cam that is approved by Harley, but I asked them to call the factory to see if they would cover the setup. The dealer was told that they (HD) would void the warranty because it states in the accessory book the stage II cam does not fit trike models. We were shocked to say the least.
    I called the factory a few days later to confirm this and was told that they will void the warranty if you install a cam because they have not tested the setup in the trike models, I asked why when it is the same powertrain as the rest of the vehicles. The answer was they just haven't, so I asked the tech why, he said if you look in the accessory book it states the cams don't fit the trike models, Bottom line is your local dealer will probably cover you but if you have a problem on the road they could advise the factory and your warranty is gone!
    By the way the factory also flagged my warranty because I have a Dakota Digital speedometer.
    It is nice to buy a product that the manufacturer is so confident in that they are constantly looking for ways to void your warranty.
    New York
    Papa Z,
    You and others have valid points. I need to get more details before we can continue this discussion.
    New York
    Quote Originally Posted by HDMAN View Post
    I called the factory in a few days later to confirm this and was told that they will void the warranty if you install a cam because they have not tested the setup in the trike models, I asked why when it is the same powertrain as the rest of the vehicles. The answer was they just haven't, so I asked the tech why, he said if you look in the accessory book it states the cams don't fit the trike models, Bottom line is your local dealer will probably cover you but if you have a problem on the road they could advise the factory and your warranty is gone!
    HD,
    I am confused. The 2017 Harley 'book of gifts' parts catalog does list a cam set up for the trike. Is the accessory book different?
    The reason they' Harely haven't tested it in the relativity low volume trike is because it would have to be certified by the EPA.... A time consuming and costly testing processes....They would have to test it on a few trikes before the EPA would certify it...
    You can't just tell the EPA, Well it works on the two wheelers, So why shouldn't work on the trike...The EPA doesn't work that way...
    Aug 2015
    Pella
    On page 587 of the 2018 Parts Accessories catalog part 92500047 states
    I think that the trike model production numbers exceeds some of the softail models, so I'm not sure that argument holds up regarding EPA testing.
    I should have treated this one like I have several in the past. I should have gone with the TTS tuner, Fullsac Performance exhaust and forgot about the warranty.
    I know, I'm just venting because I can't have it my way.
  11. #10
    New York
    HD,
    Stage 2 IS available for Pre Milwaukee 8. A little confusion here....
  12. #11
    400+ Posts
    Jan 2015
    Barrington, NH USA
    HD,Stage 2 IS available for Pre Milwaukee 8. A little confusion here....
    Probably because they do have an approved cal/download tune for it.
    I just bought a SE58 TB for my 14 Tri. In the 14 SE Catalog it said it would fit. In the 17 Se Catalog it now is not for a 14 Tri. The EPA spanked HD so now they have to be very careful.
  13. #12
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    I see that notation about the Stage II kits on page 587. But look at page 586 which lists just cams and several are offered for '17-later Touring models and there is no notation regarding not fitting trike models. And the caution icon is a go light which indicate the part is 50-state U.S. EPA compliant.
    Appears to me that the kits on p. 587 give you the cam and pushrods whereas on p. 586 you can buy just the cam . . . then get the pushrods spearately I guess. It sure seems to me that if the State II kit is not compliant on a trike then the cam alone would also be non-compliant. What am I missing here?
  14. #13
    Quote Originally Posted by ultrafxr View Post
    I don't think the MOCO has done much real time testing these upgrades on Trike models
  15. #14
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Probably less than the millions of pre-production miles they tested the M8 motor, lol. In any case they need to be consistent about whether a swap to an EPA compliant cam voids the trike power train warranty or not. This is a pretty big deal for anyone wanting to do a performance upgrade.
  16. #15
    Agree, plus the M8 with 4 valve heads will be more compliant with the EPA
    The cams in them from the factory IMO already have a low profile
    This means to me their should be moocho wiggle room for cam selection and still be EPA OK
    This new engine breaths good, but needs more help for 2 up Trikes IMO
  17. DKCustoms postbit
  18. #16
    New York
    Somewhat of an update: in talking to the shop techs, the individual has an SE255 CAM (low to mid range torque) with race tune, on a 2011. This combo would be expcted to produce some noticable response to the throttle. However, this person apparently has a history of riding in higher gears at lower speeds, ie lugging down the engine. Hence, needing ' a handful ' of throttle to get any response. That expains it....
  19. #17
    Unless the fellow triker you speak of joins Trike-Talk and explains what he did or didn't do its all going to be speculation from this point on...
  20. #18
    New York
    That is true.
  21. #19
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    I put a 254 cam in my 103 in my tike with V&H headers, stock mufflers, TTS tuner, SE AC and it ran quite well until it blew up. Then I put what I call my Stage 20 kit, SE 120 ST engine which came with 259E cam and 58 mm TB. It runs quite well in the trike
    Rear lift kit, and tour pak relocation, Road Zepplin Air seat, Chrome front forks, SE 120 ST engine, Headers by V&H, Stock mufflers, SE 259E cams, TTS tuner and SE Air Cleaner, 58 mm Throttle Body, Tank lift, Wind Deflectors, DIY Crankcase Breather, Floorboard Ext.
    Amateur Radio : W4WNG
  22. #20
    200+ Posts
    Nov 2015
    palm bay
    Thank the EPA! H-D got seriously burned not long ago. By "testing" they mean that the same cam in the same motor isn''t EPA approved in a different "platform", ie trike vs bike. EPA testing is expensive and H-D may feel that the Triglide market is too small to amortize it.
    Wanna help? Whack a tree hugger and vote Republican.
  1. CL woes--nobody there knows what a Stallion is {sigh}
    By Wingdesigner in forum Stallion Trikes
    Last Post: 07-23-2017, 12:39 AM
  2. Brake woes
    By stinger608 in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-15-2014, 05:22 PM
  3. Gas Tank Woes
    By Doug D. in forum VW Powered Trikes
    Last Post: 02-10-2013, 09:22 PM
  4. Electrical Woes
    By Ozarkryder in forum Honda Trikes
    Last Post: 06-15-2009, 08:54 AM
