Likes Likes:  5
Results 1 to 17 of 17
Thread: 2010 Stallion Electric trunk lock
    150+ Posts ODDOMAN's Avatar
    Aug 2010
    EFFINGHAM, SC
    Default 2010 Stallion Electric trunk lock
    How many of you have hooked up your electric trunk lock?
    just checking...MINE WORKS GREAT...
    MERRY CHRISTMAS....
    ODDOMAN
    #667
    SOUTH CAROLINA
    Oct 2015
    Sherman Texas
    Default Electric trunk lock
    Did yours come equipped with one or did you have to install one? Any details would be appreciated.
    Oct 2015
    Sherman Texas
    Default Thanks for the reply????
    Thanks for not answering.
    I tried to PM you but that doesn't work either.
    I read some where on this page that all you had to do was hook it up but I don't want to start drilling holes before I know if this is really true. Since the wiring and controls are from a pickup I really can't believe there would be provisions for an electric trunk release.
    Aug 2010
    EFFINGHAM, SC
    Talking Electric trunk...
    Quote Originally Posted by KE5WL View Post
    Sorry for the delay....the electric switch came with it.....but wasn't hooked up....I ran a wire to the Inside light switch....turn it on then off again....trunk unlocked...
    Oddoman
    #667
    South Carolina...
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    As far as I know, all the trunk releases have an option to run a power wire to it and be able to open the trunk. I have one also. I would not personally wire it direct to the inside lights as if you need the lights for something, you open the trunk and now have to get out and close the trunk. Hide a push button trunk release switch so that just anybody can't open your trunk when you aren't around and possibly help themselves to whatever is in the trunk! Just my opinion.
    Tomg
    350+ Posts Doc7402's Avatar
    Mar 2013
    Thonotoassa ,Fla ,USA
    Quote Originally Posted by tomg View Post
    Tomg
    Tom you say all the Stallions were made with the elect lock ?
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Mine doesn't have one. Might only be the newer ABS bodies. Rick
    Stallion #378
    Suzuki Burgman 650
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by Doc7402 View Post
    The mechanism in the trunk is there but, you have to add your push button and power wire to the trunk latch
    Tomg
    100+ Posts 1 triker's Avatar
    Dec 2018
    Hempstead,tx,Waller County
    Tomg
    Trying to figure out which pole is negative and positive.
    # 796
    Oct 2015
    Sherman Texas
    Dec 2018
    Ok, got it figured out and done. The plastic housing under the trunk lid where the light is has to be removed , it is held on with snaps , mine had two rivets holding it also, not sure if they all do. I used the ground wire from the light to connect to the bottom post/ connector on the latch, there are three of them, then connect a wire from the middle post of the latch to my push button switch, also from there I ran a wire to a hot wire in the fuse box. NOTE: If you have to remove the latch , it is screwed into a plate that will move around making hard to get the screws back in. That's it you find it hard to plug the wires into the latch. My push button is located on the interior light switch panel. The latch is from a 2007 Ford Focus.
    Any questions ?
    # 796
    Dec 2013
    Hot Arizona, USA
    Just for info, my fiberglass body does not have an electric trunk latch. Rick
    Stallion #378
    Suzuki Burgman 650
    Dec 2018
    Quote Originally Posted by rocket1lf View Post
    Mine is fiberglass also, but it has it. Did you very close, because it's hard to see the male connectors.. What year is it?
    # 796
    300+ Posts
    Signal Mountain Tn
    Quote Originally Posted by 1 triker View Post
    1 Triker, if you have #796 it should be ABS. The ABS numbers began in the mid 500's. Also I can see the sidestep on yours has the black rubber mat which is common for the ABS models. The fiberglass models do not have it, unless it is applied after market. Mine is fiberglass and it does have the electric mechanism in the trunk, but I never connected it.
    Dec 2018
    Quote Originally Posted by trikervet View Post
    Sorry, made a mistake, yes it is ABS. But if someone really want that feature I'm thinking they can buy the electric latch and wire it up.
    # 796
    Dec 2013
    Hot Arizona, USA
    Mine broke and I had TMS send me another one. It was different from the one you have and doesn't have an electric release. Mine's a 2008. Rick
    Stallion #378
    Suzuki Burgman 650
    Dec 2018
    The electric unit is very handy, if I had the older model I would definitely try to replace the regular one with an electric one. Ebay has them cheap.
    # 796
  1. trunk lock
    By lightnin in forum Harley Tri Glide
    Last Post: 09-20-2019, 02:20 PM
  2. Trunk Lock ?
    By mirider in forum Harley Tri Glide
    Last Post: 01-26-2017, 10:24 AM
  3. Trunk lock ??
    By Beorn of Ga in forum Harley Trike Conversions
    Last Post: 01-08-2017, 12:55 PM
  4. Trunk Lock
    By Deeman in forum Harley Trike Conversions
    Last Post: 11-28-2016, 10:41 AM
  5. TG Trunk lock
    By Bones in forum Harley Tri Glide
    Last Post: 12-06-2011, 10:13 PM
