Likes Likes:  8
Page 2 of 2 FirstFirst 1 2
Results 21 to 29 of 29
Thread: VW Mid Engine Trike
  1. #21
    Apr 2015
    Batesville, AR. 72501
    I'm with Larry on the spark plug. Doesn't look as new as the other 3. Check and see if it has a different p/n on the porcelain insulator. If the same #, inspect the threads closely and you will see the helicoil threads under the gunk. You can probably install a new helicoil with some Loctite and be good.
    I'm with Rex on the check the heads for cracks too. Typical cracks are from valve seat to spark plug hole or between valve seats. They can be very obvious or teeny-tiny hairlines so inspect carefully. If they're cracked, scrap the heads. Check out "Need VW type3 DP 1600 heads" thread for pix.
    Welcome to the world of old VW engines.
  2. #22
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Bearing
    Finally got the Gland nut off today. Snapped the drive off of my 3/8" ratchet, but got it. Split the engine case in two and a quick inspection found only one problem. The rear crankshaft bearing looks like it tried to spin. Once the block is cleaned up, I'll be examining it and the heads as best I can. That one "oversize" spark plug did not have a helicoil on it, so it makes me believe the prior owner had a helicoil in it, probably came out, and just stuck this spark plug in it to sell the bike.
  3. #23
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Ouch.
    Hopefully the case can line bore.
  4. #24
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Case
    The case has a small raised portion where the pin tried to bend over. Other than that (from what I can see) it looks fine.
    I removed the jug bolts and noticed each one has a helicoil in the block. One did come out with the bolt, but other than sitting just above the block, the others look good.
    No grooves or damage on the crankshaft and the rod side clearance came up at .012" which is well within the books spec's.
    Measured the crankshaft mains at (front of engine to back) 1.573" / 2.165" / 2.165" & 2.166"
    The connecting rod journals measured at cyl 1=2.165", cyl 2=2.166", cyl 3=2.165" & cyl 4=2.165"
    Since it has been a long day between trying to get rid of this cough, working on my Yamaha trike parts, rebuilding my media blast cabinet, and this VW engine, (a little bit on each one), I'll be bumping these measurements against what my book says about in/out of spec's.
    No visually detectable cracks in the heads, but three of the four spark plug holes (including the one oversize diameter plug) have/had helicoils in them. From what I see on the internet about helicoil type thread repair for spark plugs not being an optimal fix, I plan to remove the helicoils and install spark plug repair inserts.
    After getting a broken tooth fixed tomorrow (tough spaghetti), I'll get back on cleaning the muck out of the engine block.
  5. #25
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Check that bore for the thrust main carefully.
    I have not ever seen one with a bearing damaged that bad that the case was not loose on.
    A good used case might be stained on the bearing saddle but you can not feel any step to it. No step feel? Then it is time to torque the case and get out the micrometer.
    If you can see or feel a step then it is most definitely bad and needs a line bore.
    Case head stud inserts are a good thing.
  6. #26
    Apr 2015
    https://dunebuggywarehouse.com/https...y-engines.html
    Looks like stock bore crank. Need to measure the OD of the bearings (the Bore Measurement referenced in the chart) to see if case has been align bored before. If you're lucky enough to have a virgin case you will have a lot of rebuild options available to you.
  7. #27
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Line Bore
    The bearings fit nice and tight except in the center. That one slides in and out of place quite easily. Waiting for my new dial caliper to arrive for proper measurment.
    Does anyone have a shop or business to recommend sending my engine case to for line boring? Can't find anyone withing 200 miles of my house. Or, directing me to a line boring set/kit that a DIYer can do it himself?
  8. #28
    Apr 2015
    Try these guys: http://neworleansaircoolers.com/
    Local VW clubs are usually great resources.
  9. #29
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Thanks
    Quote Originally Posted by vwbug72501 View Post
    Thank you. Didn't think about clubs. Contacting them right away.
  1. Engine Temperature Sensor on M8 Engine
    By sjambok in forum Harley Tri Glide
    Last Post: 08-14-2017, 07:42 PM
  2. Trike with GPZ500 Engine
    By atilacarmen in forum Home Built Trikes
    Last Post: 07-04-2014, 02:32 PM
  3. Mid engine Trike ?c
    By KennyK in forum VW Powered Trikes
    Last Post: 04-01-2014, 07:34 PM
  4. GW Trike Engine Oil Over-Filled
    By Goldrush in forum Honda Trikes
    Last Post: 10-16-2013, 08:10 PM
  5. Mid Engine Trike
    By ralco in forum General Discussion
    Last Post: 09-10-2011, 08:52 PM
