Likes Likes:  10
Results 1 to 20 of 20
Thread: Rear tire tri glide
    300+ Posts 67wizard's Avatar
    Aug 2015
    Nv.
    Default Rear tire tri glide
    Dunlops 205/65R 15 92T load rate 1400 cost $141.99 most cycle shops. Harley even higher
    Dunlops 205/65R 15 94T load rate 1477 cost $ 77.99 Wal Mart
    Whats the big difference? both speed rate the same, load rate the only diff.
    Just would like to know for my own info.
    CMA member, VietNam 66-67
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
    4750+ Posts
    Mar 2015
    Texas
    That's the difference and an important one to consider. Put a too low a load rated tire on a trike or bike and you risk heat build up to cause catastrophic failure.
    The only reason some people are still alive is it's illegal to shoot them.
    American Legion Rider
    Aug 2015
    Nv.
    Quote Originally Posted by hogcowboy View Post
    The tire from Wal Mart has a higher load rate than the regular tire on the trike now by 77 lbs.
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
    500+ Posts
    Apr 2016
    Vero Beach, Florida
    Other than the Walmart tire having a higher load rating, the only other difference I see is in the 94T's tread pattern. The Walmart tire is rated for 65k miles and supposedly the Signature II at Walmart vs. the Signature tire from Harley is designed to remove more water from wet surfaces for better traction. I would suspect by the designation of Signature II vs. Signature that the Signature II is an improvement on the Signature tire? The price difference is amazingly different between the two sources for the tires and at Walmart, you can get both tires for about half the price of the Harley-sourced tires.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Quote Originally Posted by Capt.Bob View Post
    Not sure what tire is on my 16 without going out & looking, but, it does not look like a good rain tire to me. It is stock & just appears to be a street tire.
  6. DKCustoms postbit
  7. #6
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    https://www.jakewilson.com/wicket/bo...30&id6=0&id7=0
    Check here and also try Discount Tire for better prices
  8. #7
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by PosseRider View Post
    My 11 Tri the stock rear tires were mud and snow rated, And i had 45k on them never had a problem in the rain or snow....My 17 Tri, the stock tires are also mud and snow..
    And i haven't had any problems in the rain , Or the last two snow's...
    2019 Tri-Glide.......
  9. #8
    850+ Posts jc1300's Avatar
    Apr 2015
    Clarksville, TN, USA Via North of Chicago
    Quote Originally Posted by 67wizard View Post
    Whats the big difference? both speed rate the same, load rate the only diff.Just would like to know for my own info.
    About $64.....I have the Sig II on my 15....absolutely no difference so far. Everything is more expensive at the Dealer or MC Shops. And I had them mounted and filled with nitrogen at the local Tire shop for about $25 for both tires. Just remember to tell them the rim / tire are loaded backwards.....jc
  10. #9
    Aug 2015
    Nv.
    [QUOTE=jc1300;536651]About $64.....I have the Sig II on my 15....absolutely no difference so far. Everything is more expensive at the Dealer or MC Shops. And I had them mounted and filled with nitrogen at the local Tire shop for about $25 for both tires.
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
  11. #10
    Apr 2015
    [QUOTE=67wizard;536655]
    Quote Originally Posted by jc1300 View Post
    I'am not sure I know what you mean by this?
    The direction that the tire is mounted. Most "Car" tires are mounted with the Rim facing up....the Trike rims {and others} are mounted with the rim facing down. Why I have no idea...jc
  12. #11
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    [QUOTE=jc1300;536674]
    The rim and tires on the rear stay the same......The tires if you are using a car tire on the front , Are mounted in the opposite direction of the arrow on the tires side wall
  13. #12
    Apr 2015
    [QUOTE=rhino 2;536677]
    The rim and tires on the rear stay the same......The tires are if using a car tire on the front , Are mounted in the opposite direction of the arrow on the tires side wall
    Cool.....I was told by the installer that he was referring to the side of the rim the tire was "pushed" on to the rim......
  14. #13
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Your installer is probably correct. Some tires go on from the front some the rear. It depends on where the clearance channel is. Tires don't stretch thats what that smaller diameter channel is for. Tires usually go on and off from the side closest to the channel.
  15. #14
    200+ Posts
    Nov 2015
    palm bay
    To preclude maring/scratching the side of the wheel that everybody sees.
  16. #15
    Apr 2015
    Quote Originally Posted by Sidecarbill View Post
    Thanks...I surely didn't say that correctly....as usual! lol
    jc
  17. DKCustoms postbit
  18. #16
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    Consider the Goodyear Comfortreads as a replacement. Softer sidewalls for a better ride.
    Bob
  19. #17
    Apr 2015
    Quote Originally Posted by HDB0B View Post
    Bob
    Wouldn't deflection be an issue? Not a lot of room in that fender well....
  20. #18
    Aug 2015
    Nv.
    When the time comes I think I'll go this way.
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
  21. #19
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Bob
    Is this what you are using ? If so, did you notice a great difference?
  22. #20
    Jul 2014
    S.E. PA, USA
    Not THAT SOFT! LOL
    I have 32k and have many more miles to go on the stock Dunlops before I change mine to the Goodyears!
    Bob
  1. Rear Tire Rotation
    By durango9 in forum Honda Trikes
    Last Post: 10-13-2017, 06:14 PM
  2. car tire on rear
    By 3wheelguy in forum Can Am Spyder Trikes
    Last Post: 08-10-2017, 03:09 PM
  3. Rear tire psi
    By GARYD in forum Harley Trike Conversions
    Last Post: 10-12-2015, 09:02 PM
  4. tire size for rear tire on front? 2007 goldwing trike
    By extreme10 in forum Honda Trikes
    Last Post: 01-14-2015, 10:38 PM
  5. Need some rear tire help!
    By flyby8906 in forum Honda Trikes
    Last Post: 07-22-2014, 09:10 PM
