Likes Likes:  5
Results 1 to 7 of 7
Thread: Battery Tenders and Lithium Batteries
    Default Battery Tenders and Lithium Batteries
    Why you should not use a Battery Tender® on a lithium battery
    Here is the simple answer: A Battery Tender® can not measure State of Charge (SoC) of a lithium battery. It simply does not have this capability. While they work great on lead acid batteries, they are not able to accurately “read” lithium batteries. So, they will never properly charge a lightweight lithium battery.
    Beyond SoC, the Battery Tender® is looking for a 6 cell battery, with each cell having roughly 2 volts. All lithium lightweight batteries are based on 4 cell packs, with each cell having roughly 3.3 volts. This sends the Battery Tender® a reading that is outside of the safe charging window, and contributes to the incompatibility.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    So is there a charger designated to charge lithium battery’s?
    Yes , And the people that sell the lithium battery, Will gladly sell you one......
    Yes, due to the construction of these batteries the makers will all suggest you use their type of charger
    Heat sees to be a big factor withy the charge rate along with amount of time needed
    100+ Posts Tynker's Avatar
    Jun 2016
    Rosharon, Texas
    How then, does the bikes charging system charge the battery ??
    Quote Originally Posted by Tynker View Post
    The bikes charging system will do the same as with a convetional battery
    In fact most makers of these batteries say put it in and run it
    Lithium batteries hold a shelf life charge a lot longer than acid batteries
    That said most bike rgulators\ rectifiers will shunt not needed electricity to the atmosphere as heat
    I hope the splains it cuz thats all I got
    4750+ Posts
    Mar 2015
    Texas
    But those chargers are more expensive too than your standard battery maintainer. It's just the growing pains of switching to that technology if you will.
    American Legion Rider
  1. A Good Read on Lithium Batteries
    By Jack Klarich in forum General Harley Chat
    Last Post: 08-16-2018, 06:46 PM
  2. Lithium Ion Batteries
    By roadking2 in forum General Harley Chat
    Last Post: 12-20-2017, 09:49 PM
  3. Replies: 5
    Last Post: 07-06-2017, 02:37 PM
  4. Lithium Battery
    By Springman2007 in forum Harley Freewheeler / Road Glide 3
    Last Post: 01-16-2017, 09:34 AM
  5. Lithium Iron Battery
    By alienwulf in forum General Discussion
    Last Post: 09-13-2016, 10:03 AM
