Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  2
Results 1 to 8 of 8
Thread: Mikuni Carb
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Mikuni Carb
    As I was working on my Ural today, I came across two extra 26mm Mikuni carbs for it. Does anyone know if they would work on the VW engine? If one would be sufficient for two cylinders, I'm thinking on getting two dual intake manifolds fabricated for them. Just one idea I'm pondering. More questions will arise, I promise.. Oh yea, pictures of the build will follow too.
    IMO 26mm is pretty small, I would run both of them
    Bob's Curmudgeon Apprentice
    consitter's Avatar
    Jun 2015
    Ashland, KY
    I had 4 Mikuni carb on my Yamaha Royal Star Tour Deluxe. They worked quite well for it. However, it was only an 80 square inch 4 cylinder engine.
    YMMV
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Mikuni Carbs
    So as I see it, I could get two additional 26mm Mikuni Carbs and put one on each cylinder or purchase two 50mm carbs and install one on each side? One per cylinder would require a bit fancier linkage but I could overcome that. One carb per side is easier to link and I know how to balance them as I do that on my Ural already.
    Four carburetors would look pretty interesting. More thinking to do. More thinking...................
    Not looking for hot rod performance, believe me. The bikes owner should not be allowed to drive ANY motor vehicle!!!! I DO NOT ride with him...
    Even tho @ 26mm a small carb I think 2 of them will be fine
    That carb is very tune able
    Be it round or flat slide
    If I remember these are CV type pre dating the HD CV carb
    The venturi changes with slide height similar to the HD CV carb
    http://www.sudco.com/mikuni_carburetors_diagram.html
    Have a look here
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I have seen it done.
    There is no guide to the jetting. If you ain't scared of the tuning aspect of it then go for it.
    I hope they have accelerator pumps.
    Aug 2015
    fresno
    Default It should work
    Last time I posted here was before I built my trike! Been a while!
    I have a 1776 VW that I'm running a Keihin CV 40mm on ( just a single carb) and it does the job just fine.
    I think you'll be fine- a 1600 VW is 99 cu in (referring to the Square Four comment), original carb for a 1600 was a 34mm Solex. You should be just fine.
    My $.02
    100+ Posts
    Dec 2017
    Chauvin, La
    Default Carb's
    Placed them in the box of parts I'm getting together for the trike. Box of ideas!! Since it is raining hard I'll probably take the engine apart today.
  1. Need a Mikuni for a Servi-Car HELP!
    By Papa Jack in forum Home Built Trikes
    Last Post: 04-15-2017, 07:47 AM
  2. Carb ID
    By reverand2000 in forum VW Powered Trikes
    Last Post: 04-28-2016, 10:54 AM
  3. Carb Q&A
    By Doug D. in forum VW Powered Trikes
    Last Post: 02-15-2016, 12:41 PM
  4. p 34 carb?
    By skeeter in forum VW Powered Trikes
    Last Post: 06-29-2012, 10:51 AM
  5. Help with new carb.
    By vwjoe in forum VW Powered Trikes
    Last Post: 03-30-2011, 04:30 AM
