ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Results 1 to 7 of 7
Thread: DIY Rodesmith conversion kit
    40+ Posts morrishuckeba's Avatar
    Oct 2010
    Alto, New Mexico
    Question DIY Rodesmith conversion kit
    I am looking at the Roadsmith conversion kit to put on 2007 ultra classic. I was wondering if anyone has installed this kid themselves, not a dealer. I am living on a fixed income and trying to save a few bucks. I have plenty of tools and and a shop to do the Installation. I don’t want to get in over my head. I would appreciate your input on this installation.
  2. Roadsmith banner
  3. #2
    550+ Posts Solidbob's Avatar
    Tx
    Default Re: DIY Rodesmith conversion kit
    Unless you have the correct equipt. you could get in over your head getting it put together...remember you'll have to support the Classic mostly disassembled (minus tour box, seat and everything from the swing arm swivel bolt removed) stable enough to line up and mount the 300+# Conversion assembly without body of course. I didn't do mine and I do have all the equiptment needed, lift 4' wide (not standing on my head anymore), numerous jacks and a specialized jack for the center plate behind the rearend assby. as you will have the wheels off an on many times to get it all setup correctly, jack stands (shortys) and lots of assorted tools / some metric and some american.
    I just decided I would rather do what I do and have my installer do what he does and then ride my new trike in a few weeks...if I did it I would get to it inbetween doing other things ahead of this project. Yep it did cost a little more but I sure slept better during and after it was done. Just Fyi / this is not a light weight job done with standard hand tools. Hope that helps..I'm retired also!!
  4. #3
    250+ Posts 07BlueCSC's Avatar
    May 2008
    Gasport, NY
    Many of the TRIKE manufacturers will only sell their kits to distributors.
    Probably a liability thing.....
  5. #4
    40+ Posts old stoner's Avatar
    Mar 2011
    lincoln city , oregon USA
    I went with a Champion trike kit which I ordered through a local dealer but like you I wanted to save money so I built mine myself in about 2 weeks of evenings after work! It isn't a piece of cake but I bought a repair manual and called the dealer with questions when I wasn't sure about something. One thing about it I know a hell of a lot more about gl 1800s than before! So if you decide to go for it, good luck!
  6. #5
    60+ Posts
    May 2011
    grand jct. co
    i haven't had the pleasure of building a harley, but i have installed two roadsmiths and one csc, all good kits.
    the csc took a long time to assemble on a 95 wing, but both roadsmiths were insanely simple. the latest one, a 99 valkyrie took 5 hrs. from two wheels to 3, an additional hr. for the rake kit and i was prepping for paint.
    it took over half of the 5 hrs. to diassemble the old parts. once it is apart it only takes about 1 1/2 hrs. to complete the job. and take my word for it, you certainly don't need to be a rocket mechanic to do one.
    i am very impressed with roadsmith. they definitly got it right. i hope no one ever experiences warrantee work, but man will roadsmith come to your rescue in a hurry.
    SUSANVILLE
    i really like the looks of the csc for the harley were you able to get the csc without being a dealer and install it yourself
    80+ Posts
    May 2011
    Out there
    Smile Re: DIY Rodesmith conversion kit
    I installed my DFT on a GL1800. It wasn't a really hard job, but it required good tools, and a safe way to lift the bike and the trike assembly, at the same time. The hardest part was installing the rake kit, and doing the bodywork and paint. I'm still not done with the paint, winter project. It might easily be harder on a Roadsmith, the DFT almost seemed to be made for DIY. The subassembly they sell is almost completely assembled, and simply bolts to existing holes, and the stock swingarm. Getting things lined up was not a piece of cake, but not that bad. There are no suspension adjustments, other than the antiroll bar, and rear shock preload.
    In addition to seeing whether the trike company will sell to DIYs, you need to check how your insurance company feels. I had to change insurance companies.
    I did it for the experience, and the confidence. I do most of my own work. I'm not sure it would be worth it for the money, particularly if you need to buy tools and lift capability.
  1. Can Anybody ID This Conversion?
    By Trvlngnrs in forum Honda Trikes
    Last Post: 09-19-2014, 07:45 PM
  2. TG vs. Conversion
    By zwerlpe in forum Harley Trike Conversions
    Last Post: 03-21-2013, 02:50 PM
  3. New Conversion
    By Whinny in forum Motor Trike
    Last Post: 02-18-2012, 10:11 PM
  4. FBI conversion
    By dchris in forum Harley Trike Conversions
    Last Post: 09-02-2011, 09:21 PM
  5. BMW Conversion?
    By kkaykk in forum BMW Trikes
    Last Post: 03-09-2011, 06:01 AM
