Results 1 to 12 of 12
Thread: Which is best the Champion Independent Suspension or Solid Suspension.
    Nov 2010
    Blythewood, SC USA
    Default Which is best the Champion Independent Suspension or Solid Suspension.
    I've just joined and I'm in the process of purchasing an 1800 Honda Gold wing trike within a year. I would like to know which is the best. It does not matter the cost, I just want a very good ride for my wife and I. Thanks in advance.
    Director-Trike Owners International
    TrikeTalk Moderator
    trikeleader's Avatar
    Feb 2008
    Imperial,Missouri
    Default Re: Which is best the Champion Independent Suspension or Solid Suspension.
    glawrence7,
    First I want to welcome you to Trike Talk. You do not have to own a trike to become a member of Trike Owners International "TOI" It is FREE and easy to do on this site.
    The best trike is the one you like, they are all good. I would suggest you go to a few dealers and test ride each. Make sure the wife is with you on the ride so she can give her input on what she thinks. The solid suspension usually gives you a little more lower trunk space, but it is the ride that counts. Also remember that the suspension can be adjusted hard or soft by adjusting a control on the dash area of the trike. The lower the number the softer the ride. It is all a matter of choice.
    Tom
    Tom Goettl
    St. Louis, MO
    Trike Owners International Director
    phone: (262) 672-0258
    email: tjgoettl@gmail.com
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    welcome glawrence.You have found the best trike forum around.Good folks and info.You have started off with a tough question.The answer is all about personal pref.I have a Motor Trike that I really like,but I would look for a dealer/installer that is close to you.You have an advantage over me in that money is no object.
    7250+ Posts Nana's Avatar
    Apr 2008
    Ohio
    glawrence, Welcome to TrikeTalk!
    If I am not mistaken, you are specifically asking about the two suspensions that Champion offers. First of all, the solid suspension has fewer moving parts, so always will have fewer potential issues. That said, when a product is well built, history has shown that the IRS can be just as reliable and trouble-free as the solid suspension.
    I have their solid suspension on mine and love it! Never a moment of problem with the trike kit, handles corners with ease, solid on the road. I keep my rear tires inflated to about 18 psi which is crucial for riding comfort. With that, I never have a problem with a rough ride. Note that I ride solo 99% of the time, so others have a different tire pressure that is best for them. I suspect that a passenger might feel the bumps a bit more as they are sitting right over that rear axle, however with the right tire pressure and shock adjustment that should not be an issue.
    I understand that the IRS can make the passenger's ride more smooth, so you may want to consider it if you carry a passenger most of the time. I have never ridden one, so I can't speak for any difference myself.
    As with almost all new vehicles/kits, Champion IRS had a few bugs to be worked out over their first year, and you may hear from some owners who got one of those kits. But Champion is very committed to quality and customer satisfaction! I am confident that they have those issues corrected, and I would not hesitate to go with either their solid or IRS suspension, if I were you.
    Trike Talk Membership Map
    No matter the storm, when you are with God, there is always a rainbow waiting.
    http://i440.photobucket.com/albums/q...andana-1-1.jpg
    5+ Posts Robo's Avatar
    Nov 2010
    henderson, ky usa
    My wife and I have a 06 Goldwing converted in April with a Champion IRS and variable sway control. We took a 1200 mile trip in June with all kinds of road condition (curves, mountain and hills) and couldn't ask for a better ride. We were fully loaded and pulling a trailer and have no complaints at all. I would recommend the IRS to anyone.
    I have the Champion solid axle kit.
    We have over 20,000 miles of great riding.
    Not one bit of trouble with it and it rides great.
    You should try them both and make your choice.:yes:
    In Memory of Bob Reeves trikes4ever's Avatar
    Aug 2010
    Lake Livingston, TX, USA
    I have no direct experience with IRS, but have seen the Mystery Design up close and talked to a guy who uses them in his conversions. They are not cheap, but appear to be very solid and well built, and if you want to go all out they have a tilting version. You did say that money was no issue.
    2003 Deuce
    Triked with Frankenstein 34" Hot Rod rear
    Chrome everywhere - the Deuce comes that way
    My last VW trike build
    Contributing Member wingking51's Avatar
    Dec 2009
    Friedens, PA
    I triked my 06 GL1800 in March. It has the CRT suspension. I had a problem with too much camber on rear wheels that caused premature tire wear. Champion has corrected the problem at no expense to me through the dealer that built my trike. I thought it rode and handled great before the change to the suspension. It rides and handles even better now!
    When I was shopping for my trike, I asked the dealer about the difference between the solid axle and CRT suspension,and what would justify the extra money for the independent. He told me that I wouldn't notice the difference in ride as much as my wife would. It would be smoother over bumps, RR tracks, etc. My wife absolutely loves the ride she gets on the trike and she feels much safer on 3 than 2 wheels. This was our first riding season on a trike and we rode over 8000 fantastic miles:yes:
    Jun 2010
    Indianapolis, In.
    Specific to the exact question you asked. That answer is up to you to determine. No one can tell you which one is best for you.
    General consensus seems to be:
    Solid Axle=Better cornering, IRS= Smoother ride no matter the brand.
    Now, not asked but IMHO there are many I would choose ahead of Champion!
    Such as Hannigan, CSC and Motor Trike for IRS. I did not find solid axle versions to my liking, nor did my wife. Nor did we care for the Champion IRS(very early model and may have suffered from the Camber problem widely suffered by many of the early kits.
    What made the biggest difference was the IRS brand I choose lengthened the wheel base, which provided a smoother ride for me and a much smoother ride for my wife. It is also the widest on the market( not sure what benefit that provides).
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    1250+ Posts katfish16's Avatar
    Feb 2008
    Gallion, Alabama
    Quote Originally Posted by glawrence7 View Post
    Welcome to the board, U have gotten some very good advise. Some of the things U might want to do as suggested,, ride as many different models as U can.. We all love the conversion we have, so U have to find the one that suits U and ur co-rider.. Also make sure if u are having the trike built to add the things that might come in handy ie" extra gas tank??? That might be good if U ride in a area where the gas stations are few and far between.. Then do U want ground effects??? There are threads already on all of these..
    If U cannot find the threads ask,, we will be glad to help...
    Best of luck, and make sure Ur co-rider is involved in every decision,,,,:Bow Down:
    Steve & Cathy
    Alabama
    U.S. Coast Guard (retired)
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    WELCOME to TRIKE TALK.....just a tiny 2 cents from me. I have ridden both Solid Rear Axle and IRS Trikes (I own a Motor Trike IRS Gold Wing), and I prefer the handling of the IRS, even in tight twisties. The IRS requires some "personalization" of the air pressures, but I can "flick" mine really well now...:wtg:....just a matter of personal preferance...
    <div class="bbcode_quote">
    <div class="quote_container">
    <div class="bbcode_postedby">
    <img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>glawrence7</strong>
    <a href="showthread.php?p=50329#post50329" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
    </div>
    <div class="message">I've just joined and I'm in the process of purchasing an 1800 Honda Gold wing trike within a year. I would like to know which is the best. It does not matter the cost, I just want a very good ride for my wife and I. Thanks in advance.</div>
    </div>
    </div>
    </div>Welcome aboard. Irs for the better ride. Straight axle for better performance. But the differences are not that much.
  1. Independent suspension vs non
    By bike-ezy in forum Honda Trikes
    Last Post: 08-25-2013, 07:18 PM
  2. Independent rear suspension
    By wobray in forum Harley Trike Conversions
    Last Post: 05-17-2012, 10:04 AM
  3. New Motor Trike Independent suspension ???
    By White Knight 04 in forum Harley Trike Conversions
    Last Post: 11-15-2010, 08:14 AM
  4. Independent suspension vs straight axle
    By furofthedog in forum General Discussion
    Last Post: 04-16-2009, 02:34 PM
