Over the next month I am going to reinstall a stock air cleaner
I want to see what this change will make in over all engine heat
With the Power Vision I will track it on the same road with and with out the change
If I am right there will be very little change
Why? The M8 runs not nearly as lean out of the box as does the Twin Cam
I am seeing temps @ 288 degrees when the Engine Management kicks on
This is with the Love Juggs on and the air deflectors from D K Customs
I have put my stock (gutted ) mufflers back on ditching my modified Fishtails for now
My mileage did go down .3 mpg
Not a big deal, how ever this also shows me the M8 can be tweaked very easy
The M8 also cools down much faster, dropping About 1 degree per minute after shut down
The Twin Cam holds the heat much longer
Ever heard of a heat soaked Twin Cam having trouble starting?
If not you probably will
With the DK Customs Outlaw air cleaner, PV Tuner, heads vented to a catch can with a drain and modified fish tails I was seeing 44.7 mpg with Engine Temperatures of 300 degrees
After installing the D K Customs air deflectors and Love Juggs Mighty Mites the temp dropped a good solid 25 degrees this past summer
I will post my results in a couple of weeks, good or bad ( The M8 has bigger and full circle) cooling fins compared to engines in the past
I am sure the engineers @ HD know with the bigger 107, higher compression the M 8 would run hotter
Yet the metals in the engine seem to take this heat pretty good
Time will tell
I have 15,200 miles on now ( 9,000) since the new parts were added
I have maxed out the mpg IMO @ 44.7 I was hoping for more
