gfaltersack3Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack3DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack3gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
Likes Likes:  34
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 50
Thread: Custom Build Trailer
    80+ Posts Booggerbe's Avatar
    Apr 2017
    collierville
    Default Custom Build Trailer
    Ok Forum members. Thought i would share some pics and imfo on the custom build trailer i am doing to pull behind my R/G trike. My goal is to try and match the Daytona CSC conversion i have now. Being a custom shop owner and having over 20 years of being a fabricator and a lot of experience in fiberglassing , building some of the Baddest radical baggers with many awards. I thought why not build a custom trailer .
    I am using a pair of Tri-Glide rear fenders, set of Flexride 425 half axles, small rail channel iron, a set of matching rear wheels like on my trike, some abs plastic, a razor tour pak, any way that is the basics of my parts list. Plan on keeping the total weight under 200 lbs. I have alot of pics from the start and hope i dont bore anyone LOL. got to wait on warmer weather before i want to start the glass work . Thanks for looking Booggerbe (Ron)
    Apr 2017
    collierville
    Quote Originally Posted by Booggerbe View Post
    Attachment 53261Attachment 53263Ok Forum members. Thought i would share some pics and imfo on the custom build trailer i am doing to pull behind my R/G trike. My goal is to try and match the Daytona CSC conversion i have now. Being a custom shop owner and having over 20 years of being a fabricator and a lot of experience in fiberglassing , building some of the Baddest radical baggers with many awards. I thought why not build a custom trailer . I am using a pair of Tri-Glide rear fenders, set of Flexride 425 half axles, small rail channel iron, a set of matching rear wheels like on my trike, some abs plastic, a razor tour pak, any way that is the basics of my parts list. Plan on keeping the total weight under 200 lbs. I have alot of pics from the start and hope i dont bore anyone LOL. got to wait on warmer weather before i want to start the glass work . Thanks for looking Booggerbe (Ron)Attachment 53260
    OK can some one tell me why my pics are upside down HELPPPP HElppp
    Apr 2017
    collierville
    Default Trying pic
    Name:  small one 1.JPG
    Ok just a test if pic size is correct think i have it now
    Apr 2017
    collierville
    Default a few more pics
    Maybe these will come out right
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Keep pics and updates coming 👍🏼
    Apr 2017
    collierville
    Default pics upside down
    Quote Originally Posted by trikeman View Post
    Keep pics and updates coming ����
    Trike man , I have alot of the build pics to share but they keep coming up up side down or side ways. Tried going to a site that Papa suggested but couldnt get them to load right and post here. Ill keep trying. Ron
    Apr 2017
    collierville
    Default Dang thought i had it figured out
    Attachment 53485
    Attachment 53488
    Maybe soon ill have this figured out LOL
    Apr 2017
    collierville
    Default still trying
    Just keep turning your puter up side down sorry. Ron
    Apr 2017
    collierville
    Default Maybe if have it now
    LOL is your neck hurting now
    Apr 2017
    collierville
    Default Hey trike man
    Think i have it now. Just some random pics now . I can answer any questions on the build if any one cares . These pics are where and how i am going to use a Razor tour pak to get into the inside of the trailer storage. Just cutting the bottom out to get inside
    Apr 2017
    collierville
    Default Pic size makes it diff
    Ok maybe i have it now. Think my pics were to large to post. The pics are out of order but you can get the general idea of what i am building . Hope these work again. Thanks for looking . Ron
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    I commend you on your project.
    It looks good and unique.
    How do you plan to fasten the tourpak to the body ?
    The later model tourpak (2006...) is pretty flimsy and needs some kind of base plate maybe on inside and outside too.
    That is quite a job but you stir the (I want to make my own too) passion inside me at the same time.
    Click image for larger version.
    Jim Murphy
    Iron Butt Rider 2001
    Apr 2017
    collierville
    Default tour pak on body
    Lee i will cut the bottom of the tour pak , leaving a 2" edge around the bottom on the inside of the tour pak. Ill then 3-m and bolt the pak to the top side of the body. I have it already mounted and it is part of the body. Using the tour pak top as the opening to access the storage compartment. Heck the tour pak is stiffer now than before. If i can help you on a trailer build give me a shout. This is not my first , but just couldnt see paying the big dollars when i could build my own and have it like i wanted. A few pics of the top . Thanks for looking . Ron
    Apr 2017
    collierville
    Default Trailer front under heat
    Ok got the heat lamps on the front curing the 3-M . Still alot of fiberglassing to do and fabricating more pieces. Thanks again
    Apr 2017
    collierville
    Default Enough for now
    Ok forum . Hope i am not boring you with these pics but for now this is enough .I had to split the Tri-Glide fenders to fit my matching rear wheels on my trike. Thanks to all of you that have looked . Ill post more as i do this build .
    Thanks Booggerbe (Ron)
    Oct 2010
    Awesome! Sure looks like you got it going In the right direction. Not boring but very interesting. Keep posting pics and plan designs.
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Looks good Ron! Looking forward to seeing the finished product! Keep up the awesome job!
    Apr 2017
    collierville
    Default For Lee
    Lee , Maybe this pics will help you understand how i did the tour pak. Thanks again RonName:  smal 46.JPG
  19. #19
    Martinsburg, WV
    Yes, that turned out very good. I can see it is very solid indeed ! More pictures !!!!
    Jim Murphy
  20. #20
    20+ Posts BVG123's Avatar
    Aug 2016
    Morrilton
    Default custom build trailer
    looking good .what is the estimated weight and have you considered brakes
  1. DK Custom Ironhead build - Photo Heavy
    By DK Custom in forum 2 Wheelers
    Last Post: 02-07-2019, 11:24 PM
  2. my new trailer build
    By BVG123 in forum Trailers / Campers
    Last Post: 03-09-2018, 11:01 PM
  3. Help DK Custom Products Build a Trike
    By DK Custom Products in forum Harley Trike Conversions
    Last Post: 12-19-2014, 02:09 PM
  4. trailer build
    By mtn rider in forum Trailers / Campers
    Last Post: 03-24-2014, 09:52 PM
  5. new trailer build
    By Drpepper in forum Trailers / Campers
    Last Post: 02-19-2014, 12:49 PM
