Likes Likes:  19
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 68
Thread: Anyone install an LED brake/running/turn signal light on the trunk?
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Default Anyone install an LED brake/running/turn signal light on the trunk?
    I'm wanting to install an LED light were the reflector is below the trunk lock.
    Anyone done this?
    I found a few different styles I like the look of about 15-18" long.
    I have not determined the best way to wire it, I'm thinking just run the wires up under the seat to the rear lighting plug & tie in there.
    I'm open to suggestions/comments.
    Oct 2017
    St. Louis, MO USA
    Nobody?
    10+ Posts Dameatman's Avatar
    Oct 2017
    Alsip Il USA
    I was thinking about your post, Do you want to do this to get rid of the lights on the fenders? I'm not a big fan on the license plate location. I want to mount it on the bumper. Your putting different ideas in my head about what I want to do.
    20+ Posts Sahuarita John's Avatar
    Nov 2017
    Tucson arizona
    I use the LEDs from
    customdynamics.com
    my buddy sold his LED light company to them years ago and I have been following them and they seem to be holding the quality and products line to a high standards.
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by Dameatman View Post
    Welcome. No, I do not want to remove the OEM tail lights. I have a thread about converting them to LED & I have already done that. I am talking about, at a minimum, adding a LED running/brake light on the back of the trunk in that wasted real estate there to brighten things up & the lights I have looked at have turn signal functions also, so that's an option.
    I had also looked at HD's LED strip that goes on the underside of the airwing luggage rack, but l thought the lights just look weak to me.
    I make also add a brake light modulator after all this is done.
    If you google the FW, I have seen Europe models that have a license plate bracket on the lower part of the trunk, that might be an option for you, but to me, they looked pretty bulky.
    Oct 2017
    Alsip Il USA
    I you google the FW, I have seen Europe models that have a license plate bracket on the lower part of the trunk, that might be an option for you, but to me, they looked pretty bulky.
    I like the idea of having more lights. I also seen the air wing brake light , and thought the same thing, Lets wait and see the ideas out there
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by Sahuarita John View Post
    I use the LEDs from
    customdynamics.com
    Could you maybe post a pick of what you used & how you mounted/wired it please.
    I like Custom Dunamics & used their inserts in my front turn signal/running lights.
    Nov 2017
    Tucson arizona
    Here are a a couple of pix of my leds.
    I use strips under my gas tank for the orange
    Strips under my floor boards for the purple.
    I shaped the peace sign with strips for the back of the bears head. The bear is my main passengers.
    I am showing the bear pix using a 9 volt batteries. hope to wire it this weekend
    The strips stick really good.
Size:  135.4 KBName:  right side led and purple.jpg
    Oct 2017
    St. Louis, MO USA
    Thanks for posting pics John.
    I'm just looking for a light assembly to put on the back of the trunk below the lock.
    No bears please. I would never be able to keep that with grandkids/Great grandkids.
    100+ Posts haute pursuit's Avatar
    Aug 2016
    houston, texas, usa
    I deleted the rear fenders and lights from my Free and used a Radiantz ZFlex led array mounted to the recess on the top of the trunk.
    Jun 2017
    RoTTENchester, NY, USA
    Quote Originally Posted by haute pursuit View Post
    Do you have photos?
    Aug 2016
    houston, texas, usa
    Quote Originally Posted by DayWalker View Post
    Do you have photos?
    I will in about a week or two. They are putting it back together after paint and making a few last minute changes right now. I'll post them when I get the bike back.
    Jun 2017
    Waiting!?!?
    Aug 2016
    houston, texas, usa
    Waiting!?!?
    I will have it back next week. The guy that helped me build it took it to a bike show in Kingwood, TX today. About to head over there and will try to get a few pics while there. We had an issue with getting all 3 functions (brake, running and turns) going, but I found out that Radiantz makes an add-on circuit pigtail that should solve the problem. The lights are super bright.
    950+ Posts Free Bird's Avatar
    Mar 2018
    Saint Louis
    Found the thread....
    https://www.ebay.com/i/111058118547?chn=ps&dispItem=1
    $33
    Surface mount Red LED 6.5" long... Would likely work on the Freewheeler trunk as a replacement for the stock reflector assembly.. A rubber gasket could be employed to account for the curved rear surface or perhaps some well cut rubber fender welting?
    Might work... much cheaper than the standard issue bagger vertical lights from places like Bad Dad etc.
    Oct 2017
    St. Louis, MO USA
    I have a few LED's in mind. The ones I found were in the 12" range.
    I was just curious what others had done, but apparently, not many had added a light in back.
    Mar 2018
    Saint Louis
    [QUOTE=MDO;568573]I have a few LED's in mind. The ones I found were in the 12" range.
    Yes there are a number of great options with nice bezels and mounting hardware. I am looking too, only my motivation is a little different. I am putting wide tires on my trike and was thinking of using a long multi-functional LED light on the body vs fender locations for the brake etc. lights. The issue I kept running into was the curvature of the body. The nice 18" assemblies would not conform to the curve.
    I will be interested in your final solution. Good luck.
    Oct 2017
    St. Louis, MO USA
    I may go with this, just for a running/brake light & then install a brake light modulator.
    That should get people's attention.
    https://www.superbrightleds.com/more.../Photos&Videos
  19. #19
    Mar 2018
    Saint Louis
    Yep... saw that one. Let me know how it goes... I am working on fenders for my fat tire install.... will need an alternative to OEM
    Click image for larger version.
  20. #20
    Oct 2017
    St. Louis, MO USA
    That company, https://www.superbrightleds.com/ is located in St. Louis.
  1. **DK Custom-LED Running/Brake Light for License Plate Relo**
    By DK Custom Products in forum DK Custom Products
    Last Post: 09-06-2018, 02:13 PM
  2. Replies: 0
    Last Post: 01-05-2018, 02:13 PM
  3. flashing brake light install
    By schiel1 in forum Honda Trikes
    Last Post: 08-10-2015, 06:33 PM
  4. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  5. auxillary brake light.,turn signal running light conversion
    By fogrider in forum Harley Trike Conversions
    Last Post: 08-25-2013, 09:24 AM
