Gernerwa10Jack KlarichNew Member Introduct...New Member from Bellingham, WA
Gernerwa10trike ladyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GorillaNew Member Introduct...New Member from Bellingham, WA
Gernerwa10rhino 2New Member Introduct...New Member from Bellingham, WA
Gernerwa10Marc HNew Member Introduct...New Member from Bellingham, WA
Gernerwa10Uncle FesterNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ZammyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10hardwickbvNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ol' schoolNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GernerwaNew Member Introduct...New Member from Bellingham, WA
Speed Bleeders
Too Pa Pa Zook
Likes Likes:  2
Results 1 to 13 of 13
Thread: Ground wiring
    250+ Posts
    Dec 2010
    oly,wa
    Default Ground wiring
    Good morning
    does anyone know where all the grounding points are on the stallion
    Thank you
    Dragon
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Chuck I doubt if anyone but maybe Richard can answer that question. No wiring diagram specific to the Stallion has ever been released. We have always been referred to the 2007 Ford Ranger diagram. I'm sure there are several all along the frame.
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    If you are in doubt about a ground and cannot find the info you need You can check your bike for grounds with an ohm meter or quicker yet a test light
    I found best if in doubt add more grounds
    Connecting a test light to the positive on your battery
    Any metal surface you touch with the pointed end of test light will light up if the system has a good ground
    I hope this helps
    One more thing, a good clean ground at the battery negative cable end is a BIG PLUS
    use these type of washers for your body and frame grounds, clean the contact surfaces good before grounding with new hardware
    250+ Posts
    Dec 2010
    oly,wa
    Thank You
    Richard said the only grounds were by fuse box frame, and ground wire by pcm .
    Dragon
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by Dragon View Post
    Thank You
    Dragon
    That's interesting as I was told different? What about your battery ground or the ground behind the rear seat for the Air compressor, etc ? Tomg
  6. #6
    250+ Posts
    Dec 2010
    oly,wa
    that's what he emailed me, I asked about the ground for the valve body, he didn't answer back on that question. isn't the battery ground on the frame by the fuse box? so please if you know of more grounds post where. that was my original question
    Thank You Dragon
  7. #7
    350+ Posts Doc7402's Avatar
    Mar 2013
    Thonotoassa ,Fla ,USA
    Good morning
    Thank you
    Dragon
    i added a ground from the battery through the trunk then added battery posts for the pos and neg terminals for jump starting or ECT.
  8. #8
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    The battery is the main ground
    That said, more grounds are better
    Ford used to ground the exhaust pipes
    Their idea more is better
    They were right
    Voltage has a way of running thru bearings causing etching and premature failure
    IMO I would ground every component to be sure ( IE anything electrical could have a ground wire run to the frame) OR better still if all possible return ALL grounds to the Negative post of the battery JMO
    You could use this for a ground strop of your battery for more connections
  9. #9
    250+ Posts
    Dec 2010
    oly,wa
    Thanks guys
    I am going to add a ground, I'm having problems with my air system and it just dumps the air and stays at zero so thought it was ground somewhere
    thanks
    Dragon
  10. #10
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Thanks guys
    thanks
    Dragon
    Bad or no grounds cause all kinds of problems
    Once you get them repaired, keep them clean and tight to keep your grounds secure
    An extra ground strap from the battery to the frame can be a BIG plus
    The heavier the ground strap the better
  11. #11
    Oct 2009
    Titusville, Florida
    Thanks guys
    thanks
    Dragon
    I had problems with the air bag system and I reversed the wires on the switch and it corrected my problem. Why ? But it worked for me. If that hadn't worked, I was going to switch the wires with the pedal controls to see if it was the switch. Those are easy trouble shooting ideas. Good luck.
    Tomg
  12. #12
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by tomg View Post
    Tomg
    Tom, before you reversed your wires was the pump not delivering air but bleeding it out instead? I wonder if reversing the polarity acts like a dump valve?
  13. #13
    Oct 2009
    Titusville, Florida
    No, actually I couldn't get it to add pressure but it would release so I switched the wires and now it works. Don't know why but it works! If you call me , there are a couple of things I can explain to you about the Air system to test it. I'm not good about getting photos on the site but I can text it to you from my cellphone to show you what to look for.
    321 268 5889 is my home number.
    Tom
  1. CSC Ground Effects & Bra
    By Bronson512 in forum Honda Trikes
    Last Post: 03-09-2017, 07:58 PM
  2. Ground Hog Day
    By pcombe in forum General Discussion
    Last Post: 02-03-2014, 01:55 PM
  3. Headlights to low to the ground!
    By Sand Piper in forum Honda Trikes
    Last Post: 05-20-2013, 10:20 PM
  4. Wheel off the ground
    By jim peacock in forum General Discussion
    Last Post: 11-01-2011, 10:07 PM
  5. Need 1 more tire on the ground
    By DTR 11TG in forum New Member Introductions
    Last Post: 09-04-2011, 10:15 AM
