Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  6
Results 1 to 20 of 20
Thread: Extra spacer in Fork Tubes
    250+ Posts rhino65's Avatar
    Aug 2016
    Atwood, Illinois United States
    Default Extra spacer in Fork Tubes
    Replacing all the bushings, seals, oil in my 02 CSC Trike. Question is does CSC have an extra space that goes on bottom of stock OEM springs? Both my front forks have an extra spacer that's 1.5" tall. It's not in Honda's shop manual or any online parts microfish. Is this some kind of kit to increase the ride height for front by compressing the springs more?
    2002 GL1800 with CSC trike kit
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Quote Originally Posted by rhino65 View Post
    Depending on what you are trying to accomplish, simply raise the ride height, overcome weak springs. I have used PVC pipe to makeup for some weaker springs and restore to stock ride height. Those 1.5" spacers can go at the bottom of the spring to make it easier to assemble. If you have a raked triple tree you should consider fork tube extensions instead.
    Theoretically the additional spacer on the top of the spring should compress the spring enough to give you the same lift as the spacer is tall. However you will lose rebound by that same amount. Adding fork tube extensions on top will let you increase ride height but not lose full dampening and rebound action. JMO
    Jim Murphy
    Iron Butt Rider 2001
    Aug 2016
    Not trying to accomplish anything. Just wasn't expecting the extra 1.5" spacer in forks. I bought trike used a year ago so already in there. All back together now. Those extra spacers make it a workout getting fork caps back on
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    you are welcome !
    Jim Murphy
    2500+ Posts Gold Rush's Avatar
    May 2011
    San Angelo
    You bet they DO !! Us older gents have a hard enough time with the OEM springs only. I had a friend that used spacers. Took both of us to get his caps back on.
    Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
    2015 GL1800/Roadsmith HTS1800
    TOI - IBA #23804 (SS1K & BB1.5K)
    I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
  6. #6
    1500+ Posts
    Oct 2012
    Batavia Ohio
    I took the spacers out of my Hannigan. The suspension was rough as a cob the way it was.
  7. #7
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    2
    Adding spacers to level a low front end is not the proper fix. The proper fix is to add a set of fork extensions to compensate for the additional rake. Every rake kit I sell comes with fork extensions, 1 inch extensions come with the 4 degree and 2 inch extensions come with the 6 degree. Why a dealer would not include and install extensions with their rake kits is a mystery to me, unless they just want to put a few extra bucks in their pocket. Adding internal spacers is also not a proper fix for sagging springs. Just replace the stock springs, they only cost around $50 a set for brand new oem springs.
  8. #8
    350+ Posts
    Jul 2016
    N Ky USA
    Quote Originally Posted by Papa Zook View Post
    PapaZook although in theory I like the idea of Fork extenders but I can’t get the 70’s out of my mind. Growing up and being around many motorcycles during the chopper era with extended forks. At that time the proper way to extend your front end for that chopper look was to buy longer tubes, the quick & cheap way was to buy fork extensions. It was reported in the magazines that many were having problems with extensions breaking, some with very tragic results.
    PapaZook I would like to gain a little ground clearance but.....!
  9. #9
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    2
    Quote Originally Posted by Bronson512 View Post
    Dennis,
    Probably 99% of the trike conversions on the road have fork extensions, which are machined from solid billet and simply will not break. Had there been a failure, I am sure we would have heard about it by now, but there is really nothing to fail. Add to that, if there had been any confirmed failures, liability concerns would prohibit manufacturers from building and selling rake kits with fork extensions as they would not take the risk of lawsuits. You have nothing at all to worry about.
  10. #10
    Aug 2016
    Got mine back together but on the first fork assembly I took apart I did not pay close enough attention to where the 1.5" spacer was. On the right side it was on bottom of spring so I installed the left side on bottom as well. Now the front is sitting roughly 1/2" higher than before. Is it possible that the left fork spacer needed to be on top of spring? Or is it just the old fork oil was 40,000 mile & 7 years old? Both fork tubes are even at top of triple tree
  11. #11
    350+ Posts
    Jul 2016
    N Ky USA
    I’m assuming the fork extension screws in to the top of my current forks? I have a CSC with a rake kit but I don’t see or haven’t seen an added section. An I safe to assume the junction of the extension and the factory forks would be located between the upper & lower triple tree?
  12. #12
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    2
    Dennis, yes they do screw into the top of your forks, replacing the stock fork caps, the threaded part being roughly 3/4", so they are very well seated deep into the fork tubes. The extended tubes then slide up into the upper triple tree until they are flush with the top of the tree. Even using the longer 2" extensions, the joint is less than 1/2 inch below the bottom of the top triple tree so there is no stress or flexing of the joint. Again keep in mind, these extensions are machined from solid 60/61 billit aircraft grade aluminum that is 1 3/4 inches thick (45mm). There is no way they will ever fail.
  13. #13
    May 2011
    San Angelo
    You assume correctly.
  14. #14
    350+ Posts
    Jul 2016
    N Ky USA
    Fellows Thanks a bunch for for responses in helping ease my concerns somewhat. I did go to a couple of GoldWing/motorcycle parts and accessory sites but didn’t find any fork extensions. Is their a brand that tends to be the gold standard so to speak.
  15. #15
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    GOOGLE search "gl1800 2" fork extensions"
    https://www.google.com/search?q=gl18...utf-8&oe=utf-8
    Jim Murphy
  16. #16
    Aug 2016
    mjtrikes.com
  17. #17
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    2
    PM sent Dennis.
  18. #18
    5250+ Posts Pegasus1300's Avatar
    Oct 2011
    Spring City,Utah, USA
    Back in the day if we needed extended forks we would get them from Forking by Frank. He would build beautiful forks to match your OEM forks only longer. He is still in business amazingly enough. Did good work back then.
    http://franksforks.com/
    On another note if you have Progressive Fork Springs,they frequently put a spacer in with their spring kits.
    Happy TRAils/NSD
    Paul
  19. #19
    350+ Posts
    Jul 2016
    N Ky USA
    Quote Originally Posted by Pegasus1300 View Post
    Back in the day if we needed extended forks we would get them from Forking by Frank. He would build beautiful forks to match your OEM forks only longer. He is still in business amazingly enough. Did good work back then.http://franksforks.com/
    Thats a name from the past! If you wanted the best you bought Franks Forks or so everyone seemed to think.
    Did they change hands and keep the name or move the company? For some reason I thought they were located in Paducah, Ky. I may be mistaken!
  20. #20
    Oct 2011
    Family owned same people and still pretty much in the same area. Back in the day I bought all my replacement forks from them. They always fit right and they always worked right.
    Happy TRAils/NSD
    Paul
  1. Progressive Mono Tubes
    By rgc in forum Harley Tri Glide
    Last Post: 01-19-2016, 07:44 PM
  2. Progressive Mono Tubes Gen1
    By Haste Maker in forum Honda Trikes
    Last Post: 09-21-2015, 08:24 PM
  3. Fork tubes
    By cjmitch in forum General Discussion
    Last Post: 08-25-2013, 03:25 AM
  4. need specs on TOOLD-07 "spacer"
    By eagle1 in forum General Discussion
    Last Post: 09-03-2012, 02:16 PM
  5. Air Flow On Fork Tubes
    By njtrike in forum Harley Trike Conversions
    Last Post: 12-10-2010, 05:43 PM
