I am going to replace the seals and bushings on my 2008 GW. I need to know what wt. fork oil I should use on this trike?
Thank Dannie
Thank Dannie
Standard weight should be fine. They are usually around 5 to 10 weight. Maybe a GW person will jump on here and give you a better idea.
10 weight is a good choice. I prefer Bel-Ray fork oil.
Many times fork seals leak due to contamination from dirt,sand,etc. You can buy fork seal cleaners at dirt bike supply shops. They're flexible piece of plastic you slide between the seal and fork tube to remove any debris. Also check for any pitting or rough surface on the tube, if you find some, 2000 grit sand paper will polish it out.
Cleaning the fork seal may be all you need. It has worked for many, but I failed at my attempt. Ended up bending the "tool" up too much trying to get it to slip in. They are cheap enough to give it a try. Here is their website and video showing how to do it. http://sealmate.net/
Thanks everyone. That tool might fix the leek. This trike has about 70000mi and when I first removed the seat everything under it was covered in a thick layer of what looked like limestone dust. That is why I want to take the forks apart and check everything.
Lee that is my plan, they should be here tomorrow. Next will be the air cleaner not looking forward to that. Trying to get all of this done before summer.
I always take a rag and wipe my forks off at these once or twice a week. Not a bad idea. Might save a damaged seal.
Wash Windshield - Wash Forks!! Never have had a leak.
Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
2015 GL1800/Roadsmith HTS1800
TOI - IBA #23804 (SS1K & BB1.5K)
I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
Replaced my seals & bushings over the winter. It's a CSC Cobra trike conversion. Used all Honda parts including Honda's 10 wt. Oil. Your forks may have a 1.5" spacer in them. Mine did. Guess they level the front after being triked from what I read. Most recommend fork extension to do this while others recommend progressive springs. Had I known this while it was apart I would have ordered the Progressive springs. These are on next year's list
2002 GL1800 with CSC trike kit
