Likes Likes:  7
Results 1 to 8 of 8
Thread: Drum to Disc Conversion for Motortrike 9" drum brake system
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Default Drum to Disc Conversion for Motortrike 9" drum brake system
    Just completed a drum-to-disc conversion on a Valkyrie with a MotorTrike conversion. Replaced front line and both lines from the tee. Kit is available now.
Size:  232.6 KBName:  left side 01.jpg
Size:  204.7 KBName:  left side 02.jpg
Size:  194.6 KBName:  left side align.jpg
    This kit comes with or without an internal drum type parking brake.
    Jim Murphy
    Iron Butt Rider 2001
    Thumbs up
    Good stopping power
    Banned
    Jul 2016
    Felton Ca
    In automotive school I was told to never use teflon tape on brake systems and that all brake fittings must use flared fittings as brake fluid dissolves teflon tape. Other than that your kit looks wonderful.
    Quote Originally Posted by Mcahron View Post
    Me too, but times have changed in the industry Too many law suits IMO
    Wildwood does in fact want teflon tape on the brass adapter elbow on the caliper
    Read instructions below
    When I taught brake class if a guy told me this I would have freaked on him
    Not any more, albeit, be careful NOT to contaminate any passages internally when using the teflon
    Instruction Sheet for part 17
    1213:
    Wilwood Front Brake Caliper Conversion, MKII
    Parts Supplied:
    Two alloy caliper adapter brackets
    Two Wilwood calipers with high performance street brake pads
    Four grade eight 3/4
    x 1
    ¼′′
    course
    thread bolts.
    Four har
    dened 3/8
    flat washers
    Four hardened 3/8
    lock washers
    Four 3/8
    shim washers
    Two brass caliper
    to
    brake
    tube fittings
    Two stainless steel brake inlet tubes
    Installation Instructions:
    1)
    Raise the front of the car off the ground and support with jack stands
    2)
    Remove front wheels.
    3)
    Starting with the right side, turn steering wheel to full left lock.
    4)
    Find a container suitable for used brake fluid. Disconnect the solid brake hose
    from the flexible brake hose at the front inside, behind the rotor.
    5)
    Remove the two c
    aliper retaining bolts.
    6)
    Remove caliper and tube.
    7)
    Remove the sheet metal splash guard from the inside of the rotor (this will not be
    reused with the Wilwood brake system.)
    8)
    Mount aluminum caliper adapter bracket on the inside of the spindle/upright using
    the
    original
    ½′′
    fine bolts with flat and lock washers.
    9)
    Install brass fitting in caliper using Teflon tape or sealer on the threads so that the
    female inverted flare end faces down. (Do not over
    tighten; we will not replace a
    stripped caliper on warranty).
    10)
    Mou
    nt caliper with bleed screws pointing up and connection ports facing the
    inside of the aluminum adapter bracket. If required, center the caliper parting line
    on the center of the rotor using the 3/8
    shim washers provided under each of the
    top and bottom 3
    /8
    mounting bolts.
    11)
    Tighten all mounting bolts using a good anti
    seize compound such as Copaslip.
    Do not over
    tighten.
    12)
    Connect the metal brake tube provided between the brass inlet fitting installed in
    the caliper and the flex hose. Do not over
    tighten or
    crimp the lines.
    13)
    Clean the rotors with a high
    quality brake cleaner.
    14)
    Install brake pads and secure with the lock pin. Spread ends of lock pin to retain.
    15)
    Repeat steps 4 to 14 on left side of car with wheels turned to full right lock.
    16)
    Fill brake fluid reserv
    oir with high
    quality brake fluid per the vehicle
    manufacturer’s recommendations. Silicone brake fluid is not recommended. Be
    careful not to spill brake fluid on any painted surfaces.
    17)
    Bleed both halves of each caliper until a solid pedal is obtained, makin
    g sure that
    the reservoir is kept full during bleeding.
    18)
    Clean any spilled brake fluid with brake cleaner, firmly press on the brake pedal
    several times and inspect all connections for leaks.
    19)
    Re
    mount wheels and set car back on ground.
    20)
    Test drive, inspect f
    or leaks and repair as necessary.
    Martinsburg, WV
    Can you imagine how much it will cost to change all of the banjo fittings on motorcycles and cars to accommodate flared fittings !
    Jim Murphy
    With HD and ABS it is getting much better
    IMO, the aftermarket will NOT take chances with law suits
    No leaks = happy and safer riders JMO
    Too much Teflon just like too much of anything can be a bad thing JMO
    60+ Posts Wayne Harmsen's Avatar
    Nov 2008
    Hamilton , MICHIGAN
    Where can this conversion be found and bought.
    THANKS
    Martinsburg, WV
    Quote Originally Posted by Wayne Harmsen View Post
    THANKS
    www.mjtrikes.com
    http://mjtrikes.com/shop/index.php?m...roducts_id=229
    Jim Murphy
  1. Lehman Monarc II 2004 drum to disc conversion
    By Randy Cheesman in forum Honda Trikes
    Last Post: 02-09-2024, 03:17 PM
  2. Drum to Disc Brake Conversion
    By stanley175 in forum Lehman Trike
    Last Post: 12-05-2023, 08:25 AM
  3. Drum to Disc Brake
    By Lee H. Mann in forum Lehman Trike
    Last Post: 05-01-2016, 11:03 PM
  4. Brake Drum Conversion
    By stinger608 in forum VW Powered Trikes
    Last Post: 05-26-2015, 08:04 AM
  5. Motortrike Drum Brake Rattling Info
    By FLTR2008TRIKE in forum Motor Trike
    Last Post: 08-29-2012, 06:55 PM
