Likes Likes:  9
Results 1 to 20 of 20
Thread: Setting PIN
    200+ Posts
    Apr 2017
    Murphy, Texas, USA
    Default Setting PIN
    I cannot get my PIN sequence past step 5, it never scrolls ENTER PIN in the odometer window.
    Wondering if I have a misprint in my book.
    Step 2 says turn off/run to off
    Step 3 says turn ignition swith on
    Step 4 says cycle off/run switch twice, run-off-run-off-run
    Step 5 says press left turn sinal 2 times, then says ENTER PIN will scroll through odometer window. Mine doesn't scroll anything through the window.
    For those who have set their pin, does the above look correct? I've tried setting this so many times and never get past step 5. Thanks for any advice.
    Quote Originally Posted by Freewheeling Ron View Post
    Is the FOB out of range while you are trying to reset.....It should be at least 10 feet from the trike..
    200+ Posts
    Apr 2017
    Murphy, Texas, USA
    It's in the windscreen pouch, right there. And I just replaced the battery. Trike starts so all is good with fob. I've tried setting it over a dozen times at least. I may just ride to the dealer and see if they can set it. Prefer to do that however in the summer on Saturdays, bikini bike wash day.
    What i meant was ......Take the FOB Away from the trike 10 feet or more , Then try to reset the pin just like you would have to if you lost the FOB...
    150+ Posts mirider's Avatar
    Jun 2015
    West Michigan
    I reset my code after I bought the trike a year or so ago and I honestly don't remember if I had the FOB near the bike at the time. The steps the OP posted are correct as far as I know so maybe having the FOB removed from the bike might do it.
    Dave
    14 HD Tri Glide
    H.O.G. Member
    200+ Posts
    Apr 2017
    Murphy, Texas, USA
    Ahh, I get it now. I'll give it a try and follow up with you guys. Thanks for all the responses.
    200+ Posts
    Apr 2017
    Murphy, Texas, USA
    So no luck with that either. While I was following the instructions, I noticed it said to have the fob present. Really a mystery.
    Jun 2015
    West Michigan
    Just reread my owners manual and step 2 specifically states "with an assigned fob present" so I think you do need the fob present which kind of makes sense. Let us know how you make out.
    Dave
    14 HD Tri Glide
    H.O.G. Member
    750+ Posts
    Jul 2015
    Dickinson
    Quick test - see if trike will start without the fob present. Security may be not working...
  11. #10
    200+ Posts
    Apr 2017
    Murphy, Texas, USA
    So I watched a couple of youtube vids and one of them said to go through the sequence rather quickly or it won't work. So I sped it up a bit and wham, it ask me to enter the code. Yeaha, got it set! Thanks for all the feedback.
  12. #11
    60+ Posts
    Jan 2018
    Milton Mills NH
    I would have to read the instructions to my son. No way is this old brain fast enough to read, then do in a few seconds.
  13. #12
    4750+ Posts
    Mar 2015
    Texas
    Yep, if you go too slow you get dropped out of the set mode. They don't give you time to read the manual and execute the step. So if you are a slow reader you're doomed.
    American Legion Rider
  14. #13
    20+ Posts
    Oct 2019
    Reynoldsburg, OH, USA
    Default I'm still stuck on this.
    When you were switching the run/off switch, did you wait for the motor sound to stop before switching, or just go as fast as you could?
  15. #14
    20+ Posts
    Oct 2019
    Speed is once again the answer. I was finally able using this technique. Thanks to all
  16. #15
    1000+ Posts
    Aug 2016
    Des Moines IA US
    I know when I did my 2016 it took 2 tries to get it to work and on my 2018 also the same, not sure why, was either to slow or I messed up but I got it on the 2nd try, keep at it, you will get it.
    All for now Trampas
  17. DKCustoms postbit
  18. #16
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Quote Originally Posted by ZooMan55 View Post
    You are not starting the motor just cycling the run / off switch.
  19. #17
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Regarding having the fob present. That must be done so security is off. If pin could be set without fob present then anyone could do so and steal bike if ignition was not locked.
  20. #18
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    That "motor" sound your hearing is your fuel pump.
  21. #19
    450+ Posts Halfnormal's Avatar
    Oct 2019
    Flagstaff AZ
    Thanks for the information on setting the PIN. I've been trying to do this myself on and off and now I will try to speed up the process.
    Don't SEEK attention, PAY attention!
    "Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein.
    2015 Harley Tri Glide
  22. #20
    300+ Posts RedOregon's Avatar
    Aug 2015
    south of San Antonio
    Quote Originally Posted by ultrafxr View Post
    Amen! When I read "fob away from the bike" I immediately thought, "What the hell?!?!"
    2024 Tri Glide! Only modifications so far - transferred Rider backrest from old 2015 Freewheeler, just added highway pegs!
  1. Has Everyone Changed Their Pin # From The Factory Setting.
    Last Post: 09-05-2019, 10:52 PM
  2. setting on freewheeler
    By ruger in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-03-2015, 03:47 PM
  3. Preload Setting
    By MDGeorge in forum Honda Trikes
    Last Post: 05-20-2013, 05:40 PM
  4. Clock Setting
    By Las Vegas Biker in forum Stallion Trikes
    Last Post: 03-25-2013, 11:14 AM
  5. OMG - Air shocks setting - HELP...
    By Big0 in forum Stallion Trikes
    Last Post: 05-09-2011, 02:56 PM
