Likes Likes:  17
Results 1 to 15 of 15
Thread: rear tires on front sidecar
    150+ Posts ragsflh's Avatar
    Feb 2018
    rush springs,ok usa
    Default rear tires on front sidecar
    would you run rear tires backwards on sidecars and on front of bike too? is michelin a good brand?
    Meme Master
    Jan 2014
    Farmington, NH USA
    For what it's worth Paul, in the final years that Harley Davidson manufactured and sold sidecars they used to setup the sidecars with a Dunlop front tire mounted to run arrows facing "forward" on the sidecar and regular stock Dunlop front tires on the bike again, arrows running forward.
    Doubt Dunlop would have given HD the green light to "reverse" mount any of their "directional" tires. Today, most HD dealerships will not "reverse" mount any tire that leaves their service depts. due to liability reasons.
    Never Run a Michellin on any bike I've owned so not much help, but there are several discussions of tire brand/fitments in the threads on here if you dig around.
    Isn't it weird that in AMERICA, our flag and our culture offend so many people...but our benefits don't???
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Quote Originally Posted by peteg59 View Post
    I'm looking for a set of pads for a 90~94 vintage Harley FLT parking brake.
    Parking brake was an option for the sidecar kit, & HD doesn't make them any more.
    New, used, &/or abused works for me as both pads somehow disappeared into thin air!
    Pete, Did you ever find these ???
    Jim Murphy
    Iron Butt Rider 2001
    Meme Master
    Jan 2014
    Farmington, NH USA
    ^...No I never did Jim.
    It would be nice to have a working parking brake, but I've found that in most cases it really isn't needed. I've improvised without it by parking on a hill rear wheel/bumper against the curb, as well as keeping a wheel chock in the sidecar when simply leaving in 1st gear won't "hold" the rig...
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    I suspect that the original kit was 44103-90A up to 1999 and the 2000 and later was 44103-02A. Both of these kits are discontinued. It appears that the caliper changes between these 2 kits but the brake pads remained the same. Pads 44113-90 might be available though NOS.
    I will do a crossover number check tomorrow and see what I can find.
    I did find this:
    https://www.ebay.com/itm/STOCK-HARLE...53.m1438.l2649
    Worse case you could cut down a larger set to fit using the above and resell the above ........ a little crude but it works.
    Who would see it ???
    Jim Murphy
  6. #6
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
  7. #7
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    That was one of the sites that showed them, but that doesn't mean they had them. I was going to call tomorrow to see. Thanks Jack......
    Jim Murphy
  8. #8
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Lee H. Mann View Post
    I shop there a lot great prices free shipping on 99 dollars and more
    I was surprised on my way home from MN last year at how big that dealership is
  9. #9
    Meme Master
    Jan 2014
    Farmington, NH USA
    Sorry for hijacking your post Paul.
    Thanks Jim & Jack! That is the same kit I have, that you have pictured from ebay, Jim.
    Looks like Boardtracker HD has the pads in stock. I'm gonna get in touch ASAP on them, as I have been unable to locate any anywhere near me.
    They will be good to have, as that will bring back added holding power when parking on uneven surfaces.
    The original factory supplied pads friction surfaces were merely RTV'd together to the backing steel of the pad. I found this out when changing a rear tire a few years back. Once I got the wheel lowered away from the calipers, the pads fell out of the parking brake caliper, hit the floor & separated on impact!
    Kinda flimsy & poorly designed IMO, but they're not really designed to be used to stop the bike going down the road.
    Hopefully they're improved from what they were originally, but even if not, I'll still get them if for no other reason than to get a template to use in making a more rugged set from something else.
    Thanks again, Gents.
  10. #10
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Good Luck Pete
    I think you will like dealing with those guys in Wisconsin
    I have Never had a problem with them, and they saved me tons of money with their prices
  11. #11
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Pete, I just called my local HD dealer and he said they are still available ... asked 'how many I wanted ?'
    They retail for $39.00 .... how about that .... under $100.00.......
    Off hand, do you remember what the pads looked like ????
    If you get them, take some pictures of the pads and caliper for posting......
    Jim Murphy
  12. #12
    Meme Master
    Jan 2014
    Farmington, NH USA
    Working from faded memory Jim, I remember them being about 1-1/2" square with no holes to retain them in the caliper?
    When I get back from running errands, I'm going to order them from Boardtracker unless they're on the shelf at my local.
    Thanks again for chasing down the part# on these. I'll try to post up pics when I have them in hand...
  13. #13
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Pete, Just curious ???? Did you get them yet ???
    Jim Murphy
  14. #14
    Meme Master
    Jan 2014
    Farmington, NH USA
    Not yet Jim.
    I did check my local dealer, and they can order them and have them in 1 week. They list for $39.99 but with my MVP discount, they'll be less. We're still in the thick of winter here with lots of salt still on our roads, so I've still got a few weeks to go before the bike comes out of "hibernation".
    I'm really interested to see if they made them any better, quality wise, and will update when I get em.....
  15. #15
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Back to Paul’s question, I run Michelin’s on my 2 wheeler. It has directional arrows as to front or rear. I have no reason not to like them.
  1. Nitrogen in rear/front tires?
    By Winger68 in forum Honda Trikes
    Last Post: 01-24-2016, 09:06 PM
  2. Front tires
    By Pappys Pal in forum Harley Trike Conversions
    Last Post: 06-28-2013, 10:06 PM
  3. Front tires
    By Dwight in forum Harley Trike Conversions
    Last Post: 07-17-2011, 05:05 AM
  4. Tires front and rear
    By kiorana123 in forum Harley Trike Conversions
    Last Post: 12-28-2010, 03:59 PM
  5. Front Tires
    By skuuter in forum Honda Trikes
    Last Post: 09-24-2010, 09:30 AM
